Hello
Can someone tell me why this isn't works?
Thanks if you can help me.
Tuinlight wont work.
- Domosapiens
- Domoticz version: V3.5981
Re: Tuinlight wont work.
I think Sunset and Sunrise is a time moment and not a time period.
Start with a simple dummy switch: IS_DARK.
IF (Time >= Sunset OR Time <= Sunrise) AND IS_DARK=Off
Do IS_DARK=On
IF (Time < Sunset OR Time > Sunrise) AND IS_DARK=On
Do IS_DARK=Off
If this works ..
You can use IS_DARK in other Blokly's.
And ... don't forget to select the type of Blockly to set on Device (on the right side)
Do IS_DARK=On
Do IS_DARK=Off
If this works ..
freijn
- Domoticz version: Stable
Please see a working blocky with sun checking.
Hope this helps you
Hope this helps you
- Capture.JPG (44.95 KiB) Viewed 1208 times
Ronnyboy
Ok, i've used your blocky, and it works!freijn wrote: Thursday 22 February 2018 13:21 Please see a working blocky with sun checking.
Hope this helps you
Thanks!!
