Fetching and processing SolarEdge JSON data with 2.4
dannybloe
Post by dannybloe »
Hi folks,
While developing and testing dzVents 2.4 I used this script to read my SolarEdge solar panels. So instead of using the hardware plugin (which is kind of inefficient if you have multiple converters) I use the new asynchronous http call functionality to fetch some json data from SolarEdge's API and stream the results into two virtual devices:
  • SolarEdge (Electric (Instant/Counter, set to type 'Return', energy read from 'device'))
  • SolarEdge: revenue (Custom, axis label 'Euros').
Assuming you have activated and retrieved your API key and Site ID, this is the code:
local KEY = 'your api key'
local SITE_ID = 'your site id'
		timer = { 'every 5 minutes at daytime' },
		httpResponses = { 'SolarEdge' } -- matches callback string below
	execute = function(domoticz, triggerItem)
		if (triggerItem.isTimer) then
			-- get data from SolarEdge
			domoticz.openURL({
				url = 'https://monitoringapi.solaredge.com/site/' .. SITE_ID .. '/overview?api_key=' .. KEY,
				method = 'GET',
				callback = 'SolarEdge'
		elseif (triggerItem.isHTTPResponse) then
			-- we got data, let's update our devices
			local response = triggerItem
			if (response.ok and response.isJSON) then
				local lifeTime = response.json.overview.lifeTimeData.energy
				local current = response.json.overview.currentPower.power
				local revenue = response.json.overview.lifeTimeData.revenue
				domoticz.devices('SolarEdge').updateElectricity(current, lifeTime)
				domoticz.devices('SolarEdge: revenue').updateCustomSensor(revenue)
				-- oops
				domoticz.log('Error fetching SolarEdge data', domoticz.LOG_ERROR)
				domoticz.log(response.data, domoticz.LOG_ERROR)
API docs can be found here (look for Overview p.19 as of this date)
elmortero
Domoticz version: 3.9639
Re: Fetching and processing SolarEdge JSON data with 2.4
Post by elmortero »
This will help me convert my current scripts to 2.4(1)
McMelloW
Domoticz version: V2024.1
Post by McMelloW »
Thanks Danny,
Will check this out to see how this works for me.
Actually, I am trying to read my SolarEdge via the local ip and Modbus TCP/LAN according to this document
Greetings McMelloW
McMelloW
Post by McMelloW »
@dannybloe
To my surprise the result of the HTTP call is finally put in respone.json .. and not in a temporary file. Very nice. See the picture for the comparison of the hardware (Actueel Vermogen) and your script (SolarEgde)
The hardware don't shows the total produced power, but the total of todays produced power on the second line. Nice example of the new asynchronous http call functionality.
Greetings McMelloW
dannybloe
Post by dannybloe »
You generate quite some power!
McMelloW
Post by McMelloW »
dannybloe wrote: Friday 26 January 2018 10:52 You generate quite some power!
Yeah it is a top day with this cloudy weather :)
Greetings McMelloW
McMelloW
Post by McMelloW »
Finally, I have a working solution to get data direct from my SolarEdge The Sunspec-Monitor Although it is a Perl script it works OK. Next step is to get it running every 5 minutes within Domoticz.
It reads the complete registers and this is the output
INVERTER:
             Model: SolarEdge  SE3500
  Firmware version: 3.2173
     Serial Number: 73xxxxxx
            Status: SLEEPING
 Power Output (AC):            0 W
  Power Input (DC):            0 W
        Efficiency:         0.00 %
  Total Production:      165.755 kWh
      Voltage (AC):       234.30 V (50.01 Hz)
      Current (AC):         0.00 A
      Voltage (DC):         0.50 V
      Current (DC):         0.00 A
       Temperature:        30.95 C (heatsink)
I think this is more like it, instead of being depended on the SolarEdge website
Greetings McMelloW
florisi
Domoticz version: 2020beta
Post by florisi »
McMelloW wrote: Friday 26 January 2018 10:49 @dannybloe
Is it possible to get the revenue rounded at two decimals?
elmortero
Post by elmortero »
[/quote]
[/quote]
You can use the dzVents round function
florisi
Post by florisi »
I've tried, but can't get it to work
freijn
Domoticz version: Stable
Post by freijn »
thanks for sharing. will give it a go later this weekend!
McMelloW
Post by McMelloW »
florisi wrote: Saturday 17 February 2018 10:28 Is it possible to get the revenue rounded at two decimals?
Try this:
domoticz.devices('SolarEdge: revenue').updateCustomSensor(domoticz.utils.round(revenue,2))
Also look at the dzVents wiki page, that's where I found it.
Greetings McMelloW
florisi
Post by florisi »
it works.
I did forget the Domoticz.utils part in the code.
thanks
McMelloW
Post by McMelloW »
florisi wrote: Saturday 17 February 2018 14:46 it works.
thanks
Yes, I found it too not easy and clear how to use these attributes and methods. But if you do, then it is simple and it works great.
Greetings McMelloW
florisi
Post by florisi »
I've reinstalled Domoticz.
Now I have an error:
Error: dzVents: Error: An error occured when calling event handler SolarEdge
2018-03-10 08:20:01.265 Error: dzVents: Error: ...domoticz/scripts/dzVents/generated_scripts/SolarEdge.lua:11: attempt to index local 'triggerItem' (a nil value)
Any idea how to solve?
dannybloe
Post by dannybloe »
You need dzVents 2.4. Use the latest beta.
florisi
Post by florisi »
How to update to latest beta?
I'm running Domoticz v3.8153 on a raspberry pi 3
dannybloe
Post by dannybloe »
You can download it from the website.
florisi
Post by florisi »
works like a charm
florisi
Post by florisi »
It stopped yesterday at 14:20, no clue why.
