hello, apparently the Xiaomi Aqara Smart Socket ZigBee
https://xiaomi-mi.com/sockets-and-senso ... e-version/
is not supported in stable version, I got this message in log
XiaomiGateway: unhandled model: is it supported in Beta ?
XiaomiGateway: unhandled model: Code: Select all
2018-02-14 00:17:02.113 XiaomiGateway: unhandled model:
2018-02-14 00:17:02.113 {"cmd":"heartbeat","model":"","sid":"158d0001f28cbd","short_id":25205,"data":"{\"voltage\":3600}"} Code: Select all
2018-02-14 22:15:59.044 XiaomiGateway: unhandled model:
2018-02-14 22:15:59.044 {"cmd":"heartbeat","model":"","sid":"158d0001f28cbd","short_id":25205,"data":"{\"voltage\":3600}"} Code: Select all
2018-02-14 22:12:45.296 dzVents: Error (2.4.1): Discarding device. No last update info found: {["switchTypeValue"]=7, ["baseType"]="device", ["lastLevel"]=255, ["deviceID"]="DCB7E426", ["data"]={["unit"]=1, ["levelVal"]=94, ["usedByCamera"]=false, ["hardwareTypeValue"]=95, ["protected"]=false, ["_nValue"]=0, ["hardwareType"]="Xiaomi Gateway", ["maxDimLevel"]=100, ["hardwareName"]="MiGateway", ["_state"]="Off", ["hardwareID"]=3, ["icon"]="dimmer"}, ["switchType"]="Dimmer", ["signalLevel"]=12, ["subType"]="RGBW", ["description"]="", ["deviceType"]="Lighting Limitless/Applamp", ["id"]=1, ["lastUpdate"]="", ["name"]="Xiaomi RGB Gateway", ["changed"]=true, ["rawData"]={"0"}, ["timedOut"]=true, ["batteryLevel"]=255}
