I have Domoticz and RFX 433 Mhz.
I would like to have LED strips in the living room.
This should go on and off and I would also like to have one or more colors displayed at a certain time.
Which manufacturer would do this with Domoticz?
Is there anything with 433 MHz, WLAN or do I need a special gateway?
Which manufacturer can you recommend?
bye
Pro
RGB LED Stripes Compatible?
- htilburgs
Re: RGB LED Stripes Compatible?
I’m using a “Yeelight smart LED strip”. Is controlled over Wifi and fully supported in Domoticz.
Hardware:
ProjektC
- Domoticz version: 4.10717
Hmm, the power supply should have a loud peep.
The Amazon ratings are rather bad.
- htilburgs
Never has been an issue. No beeping here
Hardware:
- remb0
why 433?
philips hue is good but very expensive, Yeelight is a very good alternative Yeelight Smart Light Strip - RGB COLOR 19
I use also use milight it's cheaper but lower quality
ProjektC
For Milight with Domoticz and WLAN, but do I need both devices?
https://www.amazon.de/LIGHTEU%C2%AE-Wir ... ds=milight
and ?
https://www.amazon.de/LIGHTEU%C2%AE-Wir ... light&th=1
and ?
- remb0
The gateway (wifi)
Mi Light iBox 2 2.4GHz WiFi iBox Controller
for the leds:
MiLight 2.4G WiFi LED Light Strip Controller
but you don't need the wifi box if you have an rflink gateway.
for the leds:
ProjektC
Your FUT035 is the same as my FUT038.
Yours makes RGB and mine makes RGBW?
Do I need one WLAN Box per WLAN Stripe Controller or can a WLAN Box control several WLAN Stripe Controllers in different ways?
I don't have a rflink gateway, just Harmony Hub, but it's not really involved in Domoticz.
Does the extra charge for Mi Light pay off compared to the low-cost WLAN?
https://de.aliexpress.com/store/product ... 47651.html
