Midea/Inventor (and other brand) Air Condition API
LouiS22
Re: Midea/Inventor (and other brand) Air Condition API
Post by LouiS22 »
By any chance are you from Hungary?
halacs
Post by halacs »
hehe, yes :) I'm also from Budapest, Hungary.
Stanleyk
Post by Stanleyk »
somebody managed midea and domoticz please ?
expart
Post by expart »
Hey, any progress on that? Only missing piece in my project.. :(
NeoAcheron
Post by NeoAcheron »
@halacs I'm hoping that you are still watching this thread, because I want to try replicate your findings and try figuring out what is done here: http://veillard.com/embedded/midea.html
Seems like this guy had a UART sniffer on the physical dongle, and if your assumption of the Android -> Cloud -> AC data stream is correct, that link might help.
I can also assist wherever possible, I have experiance in Java and embedded hardware, I'm also looking to hook my Midea based WiFi AC into a home automation system.
BarryT
Domoticz version: 2024.3
Post by BarryT »
Also following this topic!
I have 2 airco units, with the same dongle.
1) Qlima
2) Cooper & Hunter
Hope to see a way to let it work with domoticz!
kbenni1
Post by kbenni1 »
did you saw the api for midea?
https://openapi-global.midea.com/
its used for amazon echo so maybe it can be used also for domoticz.
im not a developer so can somebody have a look on it?
Benji
LouiS22
Post by LouiS22 »
kbenni1 wrote: Sunday 03 June 2018 22:15 Hello,
Benji
404 for me
kbenni1
Post by kbenni1 »
my bad, Amazon Echo was forwarding me to this page and i was able to login with my midea credentials,
then check:
https://github.com/midea-sdk-org/android-sdk
http://iot.midea.com/android/index.html ... tener.html
https://github.com/midea-sdk-org/ios-sdk
https://github.com/midea-sdk/midea-sdk.github.io
and the skill for Amazon echo
https://www.amazon.com/dp/B077WFCD8B
so it should have some api
LouiS22
Post by LouiS22 »
kbenni1 wrote: Tuesday 05 June 2018 12:50 my bad, Amazon Echo was forwarding me to this page and i was able to login with my midea credentials,
then check:
Yeah, I googled yesterday and found the very same github ones :)
kbenni1
Post by kbenni1 »
are you going to implement it? if you want a help, contact me and maybe i can help
Stanleyk
Post by Stanleyk »
any news about midea AC ?
LouiS22
Post by LouiS22 »
Stanleyk
Post by Stanleyk »
@LouiS22
new version 0.0.3, have you try implement ?
LouiS22
Post by LouiS22 »
Stanleyk wrote: Thursday 29 November 2018 10:16 @LouiS22
I've purchased a Harmony Hub and planning to control the AC via that.
Stanleyk
Post by Stanleyk »
I have echo dot and that midea plugin not work
NeoAcheron
Hi Everyone,
So after months of struggling with the Ruby app, that uses the online API that is hosted on an Amazon server somewhere, I have decided that I'm putting in the effort to get this working as a plugin for my own use.
I have managed to use the Ruby code and the decompiled APK to reverse engineer a working Python library. My intention was to make the library abstract enough to be usable on its own, and with minimal effort I created a Home Assistant climate platform plugin. I don't know enough about Domoticz, but I have learnt a lot from this forum, hence my post here today.
Just to make it clear, I'm not intending to ever make my library support Domoticz myself, but I will accept pull requests that can enhance the library in order to use it with Domoticz, and will happily host it along side the Home Assistant version.
You can find the code and the instructions here: https://github.com/NeoAcheron/midea-ac-py
The library is also available on PyPi, and is simply called "midea".
I would like to thank everyone in this forum for the technical guidance and posting their findings in order to make this possible!
Happy hacking!
Joost996me
Post by Joost996me »
Trying to reactivate this discussion regarding incorporating AC in Domoticz. I have three units (Qlima WiFi) using NetHome Plus. Trying to find out if someone was able to use this function in Domoticz. Any help is appreciated!
Alain
Domoticz version: 2022.1
Post by Alain »
I'm interested too, as I have 4 Qlima units, of which three have the wifi module.
Hue | Zigbee2Mqtt | MQTT | P1 | Xiaomi | RFXCom | Modbus | TP-Link | Node-Red | Grafana |
Alain
Post by Alain »
I have been messing around for days, trying to integrate different plugins, combinations of versions, modifying the Daikin one, etc but I can't get anything to work. Either Domoticz doesn't see them and they don't show up in the hardware list, or I'm getting errors in all sorts.
There are lots of these units out there and I can hardly imagine that there is not a soul that doesn't want to control their airco from Domoticz.
Users browsing this forum: HansSch, pfloryann and 1 guest
