Hi. Well I guess that the difference between your configuration and mine is that I'm using a 'Dimmer' instead of a Blind.getget wrote: Thursday 08 February 2018 20:34Thanks for the answer.Fred78 wrote: Wednesday 07 February 2018 15:27Hmmm...funny. Because when I say "Ouvre le volet du salon", it works fine. I mean it says "ok j'allume la lumière volet du salon" and it opens the shutter.getget wrote: Wednesday 07 February 2018 14:18 Hello, today, no 404
l have blinds defined in domoticz. What should I say to open them ?
When I say "ouvre le velux" (open the blind called velux in french) Google says "ok J'allume la lumière velux" (ok I turn on the light velux" ans the blind .... Closes.
What kind of device are you using for you're blinds? My shutter is managed by a Qubino Zwave module that is recognized by domoticz as a dimmer.
My device is recognized as a dimmer and I never tried to switch the declaration to a 'Blind'.
I've just checked in Domoticz and there's a 'Blinds Inverted' type. Would switching to this type solve your problem?
EDIT :
I've just tried out the 'Blinds Percentage Inverted'. It works fine. If I say 'Ouvre le volet du salon' it opens the shutter. I a say 'Ferme le volet du salon', it closes the shutter. If I say 'Règle le volet du salon à 40%', it opens (or closes) the shutter up the 40%.
So try to switch from 'Blinds' to 'Blinds Inverted' in your domoticz configuration.
