Domoticz harmony hub does not show up in homekit Topic is solved
drewthor
Post by drewthor »
Version: 3.8153
Platform: Debian stable latest
Hardware: harmony hub
Description:
I have set up home bridge and installed domoticz homebridge and set up my config file. I can add the bridge to my home.app on iOS, but the harmony hub that I have added as a device in domoticz does not show up. Do I also need to set up harmony hub control? Anything I am missing? The harmony hub is not in the excluded devices, and the harmony hub activities show up in Devices. Do I need to set up scenes or something else in Domoticz?
Thanks for help, I am new and have searched all I can, but seem to be stuck.
Here's what I get when querying one of the harmony activities in the devices section of domoticz
"ActTime" : 1517716494,
"status" : "OK",
"title" : "Devices"
Switching the on/off button in domoticz for the activities (which weirdly the activities are duplicated) does not appear to actually do anything. However, the logs are up to date to when I use the harmony remote.
Marci
Domoticz version: 3.8153
Re: Domoticz harmony hub does not show up in homekit
Post by Marci »
Post me a screenshot of your Activities as displayed in Domoticz please...
Extended Domoticz homebridge-plugin for latest Homebridge - adds temp/humidity/pressure sensors, power consumption sensors, DarkSkies virtual weather station support, YouLess Meter support, general % usage support & switch/lamp status checking!
drewthor
Post by drewthor »
Marci
Post by Marci »
You need to click the green arrows to make those devices active so that they appear under the "Switches" tab. Once that's done, Homebridge-edomoticz should just detect them as regular switches same as any other (after you've restarted homebridge).
drewthor
Post by drewthor »
Thanks so much; works perfectly for turning things on! Do you know how to get the activity to turn off when I turn the switch off in home kit?
drewthor
Post by drewthor »
Nevermind, I figured out the poweroff switch and having to be more patient with the switches updating in homekit
Marci
Post by Marci »
You just need to set up and enable MQTT for realtime updates, then commands are pretty much instantaneous (depending on Pi load). See first post in the Homebridge-edomoticz Plugin thread... "Enabling MQTT For improved realtime updates" section.
