Has someone experience with Google AIY Voice Kit and Domoticz?
I am able to to send commands with the Voice Kit to Domoticz, to switch lights on/off. This was very easy.
But I also want the communication from Domoticz to the Voice Kit. Eg. temperature is too high, let the Voice Kit say 'Temperature is too high'.
Any ideas?
Raspberry Pi 2 with latest beta version
1x Aeon Labs USB Z-Stick S2
5x Fibaro Modules
5x Fibaro Modules
- cyberclwn
Re: Google AIY Voice Kit
Hey,
I just got myself a "AIY Projects voice kit" too. Can you share some pointers or problems you ran into ?
I'll start experimenting with it soon.
Thanks in advance.
Thanks in advance.
3xPi 2B (Domoticz "live", Domoticz "sandbox", PhotoFrame)
RFXCom433(E), KaKu, Oregon Scientific, Keyes 2-relay, Logitech Media Server, MiLight, Smartwares heating controller(2x), IR Send/Receive, Keyes PIR, XH-M131 DuskSensor, DHT22/11
I'll start experimenting with it .
thanks
boris
thanks
boris
There is a good project over at https://github.com/shivasiddharth/GassistPi
Works with AIY kit.
Easy to configure for local voice control of GPIO as well as many other useful additions.
Works with AIY kit.
- Domoticz version: 3.8914
Just thought i'd share that i recently picked up a google AIY voice kit, and relatively easily, have got the kit to turn on/off switches, set switch levels and retrieve values of devices.
basically once the AIY recognises your voice and translates to text create a function to send a HTTP request in line with Domotica API information providing the speech to text matches what you said! and you remember your pre-programmed command!
test it in a browser first so you can see the returned JSON data, then you just need retrieve the object you want.
It works very well, it reads back temperature/custom text.
simple and work reliably and quickly
