please set "Debug" to "True" and PM me the results.manjh wrote: Thursday 01 February 2018 12:41 Hmmm. replaced the code in the plugin.py, restarted Domoticz, and enabled the plugin.
2018-02-01 12:40:01.517 Error: (WAN IP checker) 'onHeartbeat' failed 'ValueError'. 2018-02-01 12:40:01.517 Error: (WAN IP checker) ----> Line 151 in /home/pi/domoticz/plugins/WAN-IP-CHECKER/plugin.py, function onHeartbeat 2018-02-01 12:40:01.517 Error: (WAN IP checker) ----> Line 102 in /home/pi/domoticz/plugins/WAN-IP-CHECKER/plugin.py, function onHeartbeat 2018-02-01 12:40:01.517 Error: (WAN IP checker) ----> Line 153 in /usr/lib/python3.4/urllib/request.py, function urlopen 2018-02-01 12:40:01.517 Error: (WAN IP checker) ----> Line 440 in /usr/lib/python3.4/urllib/request.py, function open 2018-02-01 12:40:01.517 Error: (WAN IP checker) ----> Line 258 in /usr/lib/python3.4/urllib/request.py, function __init__ 2018-02-01 12:40:01.517 Error: (WAN IP checker) ----> Line 284 in /usr/lib/python3.4/urllib/request.py, function full_url 2018-02-01 12:40:01.517 Error: (WAN IP checker) ----> Line 313 in /usr/lib/python3.4/urllib/request.py, function _parse 2018-02-01 12:40:03.075 dzVents: Warning! WAN IP has changed!
Python Plugin: Wan IP Checker
- ycahome
- Domoticz version: lat Beta
Re: Plugin - Wan IP Checker
https://www.youtube.com/siakavelisgr
manjh
- Domoticz version: 2025.2
Doneycahome wrote: Thursday 01 February 2018 13:20please set "Debug" to "True" and PM me the results.manjh wrote: Thursday 01 February 2018 12:41 Hmmm. replaced the code in the plugin.py, restarted Domoticz, and enabled the plugin.
Hans
- ycahome
you forgot the "https://" prefix on the Check My IP URL.
Seems that "except" cannot catch "ValueError"
manjh
Yes, that did it!
I think it would be useful to add a check on this. People are so used to typing the URL without the prefix.
For instance, when I type "hashemian.com/whoami/" in my browser address line, it will automatically add the
prefix "https://www." to create the full URL.
Alternatively, add a text on the window to make sure people type the complete, full URL...
Hans
manjh
Last question on testing: in order to test the whole string of actions, I would like to see a mail coming into my mailbox from the plugin.
Is there a way to force this? Can I manually change the "kept" URL to trigger this? Where is it stored?
Hans
- ycahome
You put me on a close pressing,manjh wrote: Thursday 01 February 2018 13:55 Last question on testing: in order to test the whole string of actions, I would like to see a mail coming into my mailbox from the plugin.
Ok, update it once more. You are going to find some interesting features.
Enable notifications and Debug mode, put check interval at "60". Notifications are triggered on every 5 minutes (1st and 5th minute)
I hope you like it,
manjh
Yes, I hear that a lot. I have worked several years as professional SW tester for a worldclass IT company, so I guess it's in my blood...ycahome wrote: Thursday 01 February 2018 15:40You put me on a close pressing,manjh wrote: Thursday 01 February 2018 13:55 Last question on testing: in order to test the whole string of actions, I would like to see a mail coming into my mailbox from the plugin.
Is there a way to force this? Can I manually change the "kept" URL to trigger this? Where is it stored?![]()
Hans
manjh
changed and restarted...
Also found that after restart there were suddenly two entries in the HW overview, different IDX's.
After a bit of thought removed both and added a new line.
2018-02-01 16:52:12.526 (WAN IP checker) Initialized version 1.2.1, author 'ycahome'
2018-02-01 16:52:12.581 (WAN IP checker) Debug log level set to: 'false'.
2018-02-01 16:52:16.845 (P1 meter) P1 Smart Meter (Power)
2018-02-01 16:52:18.303 (RFLink De Meern) Temp + Humidity (Alecto V4)
2018-02-01 16:52:24.864 (WAN IP checker) WAN IP Updated to:145.129.114.127
2018-02-01 16:52:24.866 (WAN IP checker) Running WAN IP Notifications
2018-02-01 16:52:24.870 Incoming connection from: ::1
2018-02-01 16:52:24.873 Error: (WAN IP checker) HTTP Request error: HTTP Error 401: Unauthorized URL: http://localhost:8080/json.htm?type=command¶m=sendnotification&subject=WAN-IP-Changed&body=145.129.114.127
Hans
- ycahome
Lets not talk about Testing and troubleshooting, will overrun this forum.manjh wrote: Thursday 01 February 2018 16:53 changed and restarted...
2018-02-01 16:52:12.526 (WAN IP checker) Initialized version 1.2.1, author 'ycahome' 2018-02-01 16:52:12.581 (WAN IP checker) Debug log level set to: 'false'. 2018-02-01 16:52:16.845 (P1 meter) P1 Smart Meter (Power) 2018-02-01 16:52:18.303 (RFLink De Meern) Temp + Humidity (Alecto V4) 2018-02-01 16:52:24.864 (WAN IP checker) WAN IP Updated to:145.129.114.127 2018-02-01 16:52:24.866 (WAN IP checker) Running WAN IP Notifications 2018-02-01 16:52:24.870 Incoming connection from: ::1 2018-02-01 16:52:24.873 Error: (WAN IP checker) HTTP Request error: HTTP Error 401: Unauthorized URL: http://localhost:8080/json.htm?type=command¶m=sendnotification&subject=WAN-IP-Changed&body=145.129.114.127
what is your Domoticz Http port? obviously not 8080
manjh
Could it be caused by that duplicate HW line? The same plugin was defined twice somehow. I removed them and re-installed, and now it doesn't crash. But I don't see any new options, and no mail getting into my mail box...ycahome wrote: Thursday 01 February 2018 16:58It is 8080.manjh wrote: Thursday 01 February 2018 16:53 changed and restarted...
Hans
- ycahome
Did you set :
- plugin "Notifications" = Notify?
- plugin "Debug" = True?
- Domoticz Email Settings?
- Waited 5 minutes?
Have you got any new errors on your log?
I think that you should leave your Testing Hat and work on your troubleshooting skills
- Waited 5 minutes?
manjh
ycahome wrote: Thursday 01 February 2018 17:18 Did you set :
- plugin "Notifications" = Notify? YES
- plugin "Debug" = True? YES
- Domoticz Email Settings? checked, all is correct
- Waited 5 minutes? YES
Have you got any new errors on your log? NO
I think that you should leave your Testing Hat and work on your troubleshooting skills![]()
Hans
manjh
got this again:
2018-02-01 17:25:47.455 (WAN IP Checker) WAN IP retrieved:145.129.114.127
2018-02-01 17:25:47.455 (WAN IP Checker) Previous WAN IP:145.129.114.127
2018-02-01 17:25:47.455 Error: (WAN IP Checker) Debug is on. Trigering IP Change:
2018-02-01 17:25:47.456 (WAN IP Checker) WAN IP Updated to:145.129.114.127
2018-02-01 17:25:47.456 (WAN IP) Updating device from 1:'145.129.114.127' to have values 1:'145.129.114.127'.
2018-02-01 17:25:47.817 (WAN IP Checker) Running WAN IP Notifications
2018-02-01 17:25:47.823 Error: (WAN IP Checker) HTTP Request error: HTTP Error 401: Unauthorized URL: http://localhost:8080/json.htm?type=command¶m=sendnotification&subject=WAN-IP-Changed&body=145.129.114.127
2018-02-01 17:26:44.980 (WAN IP Checker) Calling message handler 'onHeartbeat'.
2018-02-01 17:26:44.980 (WAN IP Checker) onHeartbeat called
2018-02-01 17:26:46.427 (WAN IP Checker) IP Discovery Site's response len is:15
2018-02-01 17:26:46.427 (WAN IP Checker) WAN IP retrieved:145.129.114.127
2018-02-01 17:26:46.427 (WAN IP Checker) Previous WAN IP:145.129.114.127
2018-02-01 17:26:46.427 (WAN IP Checker) WAN IP the same. Skipping
Hans
manjh
Yeah, testers can be a real pain-in-the-youknowwhat...
Are you sure this is a valid URL on a Raspberry-Pi : http://localhost:8080
Hans
- ycahome
Is it a Raspbian jessie? or something different?manjh wrote: Thursday 01 February 2018 17:34 Are you sure this is a valid URL on a Raspberry-Pi : http://localhost:8080
Also, you have set your Domoticz for "http"? "https"? or both?
Do you have authentication (password) set on your Domoticz?
P.S.: try to run from your PC by replacing <domoticz ip> with your server's IP:
http://<domoticz ip>:8080/json.htm?type=command¶m=sendnotification&subject=WAN-IP-Changed&body=145.129.114.127
manjh
When done from my Win10 laptop,it comes back with this:ycahome wrote: Thursday 01 February 2018 18:01Is it a Raspbian jessie? or something different?manjh wrote: Thursday 01 February 2018 17:34 Are you sure this is a valid URL on a Raspberry-Pi : http://localhost:8080
status: "OK",
title: "SendNotification"
I use Jessie. On the settings, I have this in local networks: 10.0.0.*; 127.0.0.*; 10.8.0.*
10.0.0 is my lan IP range. 127.0.0 for local, and 10.8.0 for access via VPN.
The good news is that I now see an email in my inbox! So if we tackle the triggering, we're all done!
Hans
- ycahome
Do you have password protection on your domoticz?
- ycahome
Check a new minor version 1.2.2
manjh
Yes I do. But anything coming from within my network (10.0.0.*) comes in free. As wel as 127.0.0.*, and 10.0.8.*.
Hans
- ycahome
try to add "::1", I saw that connections from localhost logged as "Incoming connection from: ::1"
Don't forget to use version 1.2.2. Contains some corrections.
