Alexa, Google Home and Siri
Madgeni
Post by Madgeni »
so it's a Scene in Domoticz? Can only be turned on? Controlicz handles those
bueno79
Domoticz version: 4.9700
Post by bueno79 »
Madgeni wrote: Thursday 01 February 2018 15:32 so it's a Scene in Domoticz? Can only be turned on? Controlicz handles those
no it is a normal switch. Not a scene. But it a "Push On Button" and not a "On/Off"
Madgeni
Post by Madgeni »
so "Activate" seems like the right method
bueno79
Post by bueno79 »
yes but it will reply : ok, I activate garage light...
alanlsmith
Domoticz version: Latest β
Post by alanlsmith »
bueno79 wrote: Thursday 01 February 2018 15:00 so, how to deal with switch like this ? My workaround is to say : ok google, activate garage.
And how could it be possible for google to understand it is NOT a light ?
Someone has an idea ? Or Google see only lights and thermostat ?
cheers
For my curtains I have a push on switch which activates a motor, the motor then runs untill the curtains reach a stop and then the motor resets itself so it runs in the opposite direction the next time the switch is turned on.
So I have a variable that records whether the curtains are open or closed and use 2 virtual switched to open and close the curtains, these activate the push on switch and are controlled by Google shortcuts. So 'Hey, Google, open the curtains' translates to 'Turn the curtains on'
Also this allows 'open the curtains' to be ignored if they are already open and vice-versa .
Last edited by alanlsmith on Thursday 01 February 2018 23:26, edited 1 time in total.
Domoticz Latest β, RPi 4B with 110Gb SSD for Domoticz, RPi 4B with 110Gb SSD for Node-Red & a RPi 2B for logging / IP addressing. RFXCOM, PiZiGate, Z-Wave, Harmony, Hue lamps and a bit of Broadlink.
kimhaak
Post by kimhaak »
Hi!
Thank you for adding me to the google-test. However, the instructions is a bit unclear, as i do not know what we are trying to achieve, and how conversions.com are related.
I received one link : https://console.actions.google.com/proj ... atorcreate which just says "There was an error completing your request, try again". (Link is censored, in case there was an unique ID in it)
If i follow the conversions guide, i kind of end up with my own project, which i don't think is correct.
Could someone explain to med what the link (https://console.actions.google.com/proj ... atorcreate) is for?
Am i supposed to import this in my actions.google.com account somehow?
Sorry if this is comes of as negativity, i just did not understand what to do, and why. (And i am generally not a n00b in these kind of things)
If this project works and is good, i will definately donate to support the work.
Kim
frenchyyii
Post by frenchyyii »
bueno79 wrote: Thursday 01 February 2018 15:35
Transform your push switch in a normal on/off one (or create a new one as a scene) that send the same command wether it's on or off.
DewGew
Domoticz version: V4.10618
Post by DewGew »
@Madgeni I can login to controlicz.com but I can't find settings anymore.
EDIT: Nevermind I got it working.. :)
marco.bag
Post by marco.bag »
@Madgeni thank you for your software (i've donated).
Unfortunately even if i've followed the instruction and the Controlicz(Test) device can be found in the device that i can add if i click on that i'm prompted for the account information, than i'm asked to allow google full access (and obviously i allow it)... than login information again, spinning wheel but returns to the "device page" without adding Controlicz.
Any help?
Regards.
kdu33
Post by kdu33 »
Great job! Could you had me to your project?
-Nico-
Ascari
Post by Ascari »
@marco.bag I have the same issue :(
marco.bag
Post by marco.bag »
Ascari wrote: Friday 02 February 2018 12:06 @marco.bag I have the same issue :(
Let's hope it's a temporary issue than. ;)
Ascari
Post by Ascari »
Ok I have the solution for me.
You must add your device in the Plan Domoticz an it's work.
Thank Nick great job really.
Madgeni
Post by Madgeni »
marco.bag wrote: Friday 02 February 2018 10:02 @Madgeni thank you for your software (i've donated).
Any help?
Regards.
Hi :)
Can you check that the devices you want to control are in a Room Plan on your Domoticz?
marco.bag
Post by marco.bag »
Ascari wrote: Ok I have the solution for me.
Madgeni wrote: Friday 02 February 2018 16:59
Hi :)
Thank you so much... i feel so stupid :D works like a charm! Congrats!!!
peteralm
Post by peteralm »
Something has been going a bit wrong today...
First I couldn't sync devices without an error and in order to try and fix it I unlinked and tried to re-link in Google home...
I get the authorise message (twice) and then this from the controlicz site..
404: Not Found
Error: Not Found
at /opt/bitnami/apps/Controlicz/app.js:77:11
at Layer.handle_error (/opt/bitnami/apps/Controlicz/node_modules/express/lib/router/layer.js:71:5)
at trim_prefix (/opt/bitnami/apps/Controlicz/node_modules/express/lib/router/index.js:310:13)
at /opt/bitnami/apps/Controlicz/node_modules/express/lib/router/index.js:280:7
at Function.process_params (/opt/bitnami/apps/Controlicz/node_modules/express/lib/router/index.js:330:12)
at next (/opt/bitnami/apps/Controlicz/node_modules/express/lib/router/index.js:271:10)
at /opt/bitnami/apps/Controlicz/node_modules/express/lib/router/index.js:618:15
at next (/opt/bitnami/apps/Controlicz/node_modules/express/lib/router/index.js:256:14)
at next (/opt/bitnami/apps/Controlicz/node_modules/express/lib/router/route.js:121:14)
at Layer.handle_error (/opt/bitnami/apps/Controlicz/node_modules/express/lib/router/layer.js:67:12)
at next (/opt/bitnami/apps/Controlicz/node_modules/express/lib/router/route.js:129:13)
at loaded (/opt/bitnami/apps/Controlicz/node_modules/oauth2orize/lib/middleware/transactionLoader.js:36:25)
at SessionStore.load (/opt/bitnami/apps/Controlicz/node_modules/oauth2orize/lib/txn/session.js:27:22)
at transactionLoader (/opt/bitnami/apps/Controlicz/node_modules/oauth2orize/lib/middleware/transactionLoader.js:42:24)
Home
peteralm
Post by peteralm »
Although I now get the same on hive... Two attempts at authorisation and then a 404 error
The British gas site says this is an oauth workflow issue. Wonder if Google have changed something today?
So, now for my tinkering I have nothing working! 😂 Ho hum the price of testing and beta ... Patience...
Madgeni
Post by Madgeni »
erk - i'll take a look!
Ok, so it failed for me - same as you - i then tried again, and it worked. I'll take a look, something has changed, but i've not touched Controlicz in a few days
so the request from Google was missing the response_type in the oauth2 call - but it could have coincided with an error in a users request restarting Controlicz. If there's an error with a users request, it forces Controlicz to restart, which might have coincided with you (and then me) reauthing.
I'll keep an eye on it, let me know how you get on
peteralm
Post by peteralm »
I left it over night and it is still doing it this morning.
I have tried Hive and Lightwaverf but they are also failing. Looks like a Google thing.
Do you have any access to Googlers? Thanks for looking though.
P
Update: After a lot of googling I tried an old phone with an older version of Google home and it worked (with an error that looked like it failed but hadn't). So it is either that or the fact there was only one Google account on that phone.
Madgeni
Post by Madgeni »
Ok, that's strange - maybe it's an update they've pushed which is causing the issue?
I have a meeting with Google on Tuesday evening to discuss Controlicz, as they wanted to only allow lights & switches, not thermostats.
I'll update after that
