Domoticz version from .bashrc
All kinds of 'OS' scripts
htilburgs
Post by htilburgs »
I'm using the following command to determine the version of Domoticz in my /home/pi/.bashrc script:
curl -s -X GET "http://127.0.0.1:8088/json.htm?type=command&param=getversion" | /bin/grep "version :" | awk {'print $3'} | /usr/bin/cut -d '"' -f 2 | /usr/bin/cut -d '"' -f 1
The result is:
3.8872
The reason is there is twice the word version
   "DomoticzUpdateURL" : "http://www.domoticz.com/download.php?channel=beta&type=release&system=linux&machine=armv7l",
   "HaveUpdate" : false,
   "Revision" : 8872,
   "SystemName" : "linux",
   "build_time" : "2018-01-29 16:59:49",
   "dzvents_version" : "2.4.1",
   "hash" : "fc97f529",
   "status" : "OK",
   "title" : "GetVersion",
   "version" : "3.8872"
Now my knowledge stops... How can I solve this, so I see only the Domoticz version, in this case 3.8872 ??
Hardware:
Damsee
Domoticz version: 4.10717
Re: Domoticz version from .bashrc
Post by Damsee »
You can add another grep command to remove the dzvents version.
Add it before your 1sr grep : grep -v dzvents
Hope that helps ;-)
RPI3 Raspbian Buster + Domoticz v2020.1 stable + RFXtrx433E + Z-Stick Gen5 + Amazon Echo (alexicz)
x5 THGN810 / x5 ZMNHJD1 / x2 Flood sensor FGFS101 / x1 Smoke sensor FGSD002
x1 ZMNHAD1 / x2 FGS213 / x3 Wallplug FGWPE/F / NodOn Soft remote CRC-3-6-0
htilburgs
Post by htilburgs »
Yes! That did the trick. Thnx.
Hardware:
htilburgs
Post by htilburgs »
For who is interested: Edit the file /home/pi/.bashrc and put at the end the following code:
echo "$(tput setaf 2)
`date +"%A, %e %B %Y, %r"`
Hardware Model............: `(tr -d '\0' </proc/device-tree/model)`
OS Version................: `/usr/bin/lsb_release -s -d  | grep Raspbian | awk {'print $1,$3,$4'}`
Kernel....................: `uname -srmo`
Domoticz Version..........: `curl -s -X GET "http://127.0.0.1:8088/json.htm?type=command&param=getversion" | /bin/grep -v dzvents | /bin/grep "version" | awk {'print $3'} | /usr/bin/cut -d '"' -f 2 | /usr/bin/cut -d '"' -f 1`
Domoticz Release..........: `curl -s -X GET "http://127.0.0.1:8088/json.htm?type=command&param=getversion" |grep -Po '(?<=channel=)[^&]*'`
Domoticz Servicebuild.....: `curl -s -X GET "http://127.0.0.1:8088/json.htm?type=command&param=getversion" | /bin/grep "build_time" | awk {'print $3,$4'} | /usr/bin/cut -d '"' -f 2 | /usr/bin/cut -d '"' -f 1`
$(tput setaf 1)
Uptime....................:  `exec --  uptime -p`
Memory....................:  `cat /proc/meminfo | grep MemFree | awk {'print $2'}`kB (Free) / `cat /proc/meminfo | grep MemTotal | awk {'print $2'}`kB (Total)
Running Processes.........:  `ps ax | wc -l | tr -d " "`
IP Addresses..............:  `sudo hostname -I`
Free Disk Space SD........:  `df -Pk | grep -E '/root' | awk '{ print $4 }' | awk -F '.' '{ print $1 }'`k on /root
CPU Temperature...........:  `exec -- /opt/vc/bin/vcgencmd measure_temp | cut -c "6-9"` C
$(tput setaf 2)
Domoticz Service status...: `sudo service domoticz status | grep Active | cut -c "11-54"`
The result:
Schermafbeelding 2018-02-01 om 00.04.33.png (52.08 KiB) Viewed 2443 times
Hardware:
Nice overview of your system. If you want to get the version of domoticz even if not active at the moment:
"path to domoticz dir"/domoticz --help | grep Giz | awk {'print $4'}
Siewert308SW
Domoticz version: Stable
Post by Siewert308SW »
Or you could do it a bit cleaner with a double grep.
You could grep the entire piece: '"version" :'
So it becomes:
curl -s -X GET "http://127.0.0.1:8080/json.htm?type=com ... getversion" | /bin/grep '"version" :' | awk {'print $3'} | /usr/bin/cut -d '"' -f 2 | /usr/bin/cut -d '"' -f 1
Setup:
- DS923+ Docker
Domoticz Latest Stable
Mosquitto / ZwaveJSUI @ Aeotec Z-Stick Gen5+ / PiHole Unbound
P1 USB Gas/Power, HW watermeter
- A lot of Zwave switches, contacts, plugs, smoke/Co2 ect
- DiY 7.5kWh Solar Storage @ GitHuB
htilburgs
Post by htilburgs »
Siewert308SW wrote: Thursday 01 February 2018 6:57 Or you could do it a bit cleaner with a double grep.
So it becomes:
Thnx for this 'cleaner' version. I'm learning by the day.
Implemented, tested and it works...!
Hardware:
sincze
Domoticz version: 2024.4
Post by sincze »
htilburgs wrote: Thursday 01 February 2018 8:07
So it becomes:
   "HaveUpdate" : true,
   "Revision" : 9227,
   "build_time" : "2018-03-30 12:51:25",
   "hash" : "617c5526",
   "python_version" : "3.5.3 (default, Jan 19 2017, 14:11:04) \n[GCC 6.3.0 20170124]",
   "status" : "OK",
   "version" : "3.9138"
Thanks, you just saved my day. :D I use this to make a backup of my domoticz and store the value of the current version in the filename. domoticz-server-v3.9138-15-04-2018-17.43.32.tar
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
