Python Plugin: Xiaomi PM2.5 Air Quality Sensor
febalci
Post by febalci »
This plugin connects Domoticz directly to your Xiaomi PM2.5 Sensor and gets aqi index and battery status every 30 seconds. You have to place plugin.py, xiaomiaqi.py files and pyaes directory together with its files into a /xiaomi folder under plugins.
Please inform me of any bugs or problems.
Plugin Download: https://github.com/febalci/DomoticzXiaomiPM2.5
Derik
Re: Python Plugin: Xiaomi PM2.5 Air Quality Sensor
Post by Derik »
mmm Thanks for this great work!!
I see this sensor and was thinking to buy it..
Only can you please tell me what the devices are in Domoticz? [ or a screendump ]
Looks a nice peace of hardware.. only what can i do with it??
febalci
Post by febalci »
Well it's fit for purpose device. First of all it doesn't have humidity or temperature, only PM2.5 particles in the air which denotes air pollution. Like smoking, gas, CO, dust etc. When i smoke in the same area it goes directly to red zone! Very good for childrens room if the room needs any clean air. It also has a rechargeable battery which goes around 2-3 hrs. The plugin reflects the AQI value (also commenting as excellent, good, bad, hazardous etc) and battery level. I can send a screenshot tomorrow.
febalci
Post by febalci »
Hi again,
This is the device:
Screen Shot 2018-01-30 at 18.36.14.png (25.28 KiB) Viewed 6148 times
And this is the devices page:
Now that i realized, i have to use a custom device for this, because this is ppm, whereas PM2.5 is micrometers/something. And so comments doesn't fit like excellent, good bad etc.
Screen Shot 2018-01-30 at 18.40.43.png (41 KiB) Viewed 6148 times
bluedmx
Domoticz version: 3.9564
Post by bluedmx »
i have installed 2 py files and directory under plugins xiaomi folder. I have created a material and after Domoticz was crashing. Need to delete the plugin resources to be able to launch again Domoticz.
Server : Raspberry PI 3B+ Raspbian Stretch.
Domoticz release : v3.9469
Best Regards.
bluedmx
Post by bluedmx »
Hi, i have removed python 3.5 and libpython3.5 and now Xiaomi PM 2.5 is working and no longer crash when installing plugin.
sudo apt-get remove python3.5
sudo apt-get remove python3.5-minimal
sudo apt-get remove libpython3.5
sudo apt-get remove libpython3.5-minimal
Best Regard.
deennoo
Post by deennoo »
With the lastest FW update the device now need to have a token to retrieve information.
I'll try to update the plugin from github
http://domo-attitude.fr
greenwitch
Post by greenwitch »
I am on firmware version 1.4.3_8103
How do you get the token?
I am not able to get one from nodejs miio solution I used before.
I can retrieve only one for air purifier but not for air monitor.
I do not see also any instruction in any github project
https://github.com/deennoo/domoticz-AirMonitor
Can somebody help me.
Adam
greenwitch
Ok,
There is an answer:
https://python-miio.readthedocs.io/en/l ... -home-logs
With app 5.4.49 it is extremely easy!
Adam
qaigor
Post by qaigor »
Hello is there any change to make it working with a new Xiaomi MiJia Air Quality Detector (KQJCY02QP)?
It supports such dimensions:
PM2.5
TVOC
CO2a
Temp
Humidity
Ubuntu Server 18.04 LTS: Domoticz + MQTT / Xiaomi (ZigBee devices, Robot cleaner, YeeLight) , Broadlink RM pro IR+RF, RFLink (433MHz & 315MHz), ESPEasy (Sonoff, NodeMCU)
qaigor
Post by qaigor »
Finally I found a solution with HA:
https://telegra.ph/Dobavlenie-Xiaomi-Mi ... tant-08-26
Unfortunately the manual is in Russian
