I have few of those sensors and i like them since they do not have the display so i van calibrate them snd it does not look confusing when display and reported info are not the same.
Digoo DG-R8H:
https://www.banggood.com/Digoo-DG-R8H-4 ... 8532015010
They are Rubicson compatible.
Also these sensors are compatible with Rubicson:
https://www.banggood.com/DANIU-433MHz-W ... 8532015010
I have found that I had to disable LaCrosse protocole to use both at the same time.
Working cheap temp/hum sensor with 433
