Does anyone have any experience with the Klik Aan Klik Uit (KaKu) ICS-2000 Home Control station?
It seems to support the old KaKu 433/868 MHz and now also Zigbee HA/LL.
I wonder if it is a good system to use instead of the Philips Hue Bridge and other bridges.
And if it is possible to control it with Domoticz.
Thanks in advance for any suggestions.
- Domoticz version: V3.8153
Hardware:
- Raspberry Pi 3B/3B+ and Banana Pi M3 with:
Honeywell evoHome (Wifi)
Philips Hue (v2)
P1-meter
SolarEdge (Web API)
- Raspian Stretch lite with:
Domoticz
- DeBaat
Re: Klik Aan Klik Uit (KaKu) ICS-2000 Home Control station
Hai.
Also related:
Can the ICS-2000 be a replacement for the RFXtrx433E?
Can the ICS-2000 be connected together with an RFXtrx433E?
At the moment, I have an RFXtrx433E working nicely with some KaKu elements.
However, I expect to have some Somfy blinds installed soon and I was wondering how to accomodate that.
A solution would be to install a Somfy Tahoma to control those blinds, but I would rather have a single system under my own control to manage all hardware.
Looking forward to any suggestions.
Also related:
- Domoticz version: L stab
Hi DeBaat,
Sorry for the late response but you can control your somfy blinds (rts) with a RFXtrx433E.
Kind regards
Koen
Kind regards
Koen
Domoicz on RPI3 (wifi) directly connected 3x ds18b20 for CV temp, Evohome (9 zone), 1 remote 220V switch based on ESP-12. RFXtrx433E, 16x AMST-606, 5 Somfy RTS motors
Domoticz on RPI3(wifi) as slave for terraruim control
More to come
More to come
- DeBaat
Hai,
No Problem. I've already figured it out.
It seems that the combination of RFXTRX433E and Domoticz works better than the original Somfy Tahoma...
Regards,
Jan
Regards,
Jan
Does anyone found out the possibility of KaKu ICS2000 being compatible with Domoticz ?
- waaren
If it is your intention to get information to and from the ICS2000 via json calls, like the homewizard plugin use to communicate with the homewizard controller, it is not according to various fora.
