Nice!jake wrote: Friday 19 January 2018 16:29Excellent, I went through all proposals and you did a good job! I was now also able to edit the wiki myself, so I updated or clarified some little things.htilburgs wrote: Friday 19 January 2018 11:35 @Jake, login to the Wiki is restored this morning by Gizmocuz.
I've updated the Wiki (as best as I can)
- htilburgs
Re: Dashticz - General Discussions - WIKI update
Hardware:
aiolos
- Domoticz version: stable
Good work in updating the wiki! Thanks! (I might change a lot of functionality, but I'm not the best in updating documentation...)
Small remark: Not all configuration for the garbage is necessary. This is the case on more places, it might be worth to notice that somehow.
10us
After editing a lot of hours my first Dashticz dashboard is nearly ready. Is it possible to change the background of the standby screen? I think I can do this in the custom CSS, but i'm a noob in CSS editing..... Can someone tell me how i can get a black background on the standby screen? (the standard screen is greyed ?) Because of using my iPad on the wall i need a black screen as background. My blocks were also black as background with white text.
Thanx a lot for your help!
When my project is finished i will share my dashboard here for comments and ideas.
- DewGew
- Domoticz version: V4.10618
Just put this in your custom.css or yourtheme.css:10us wrote: Monday 22 January 2018 1:24 After editing a lot of hours my first Dashticz dashboard is nearly ready. Is it possible to change the background of the standby screen? I think I can do this in the custom CSS, but i'm a noob in CSS editing..... Can someone tell me how i can get a black background on the standby screen? (the standard screen is greyed ?) Because of using my iPad on the wall i need a black screen as background. My blocks were also black as background with white text.
.standby .swiper-slide {
background-color:#000000;
}Raspberry Pi 3 | domoticz | Aeon Labs Z-Stick GEN5 | RFlink gateway
10us
Thanx! That does the trick!DewGew wrote: Monday 22 January 2018 8:13Just put this in your custom.css or yourtheme.css:10us wrote: Monday 22 January 2018 1:24 After editing a lot of hours my first Dashticz dashboard is nearly ready. Is it possible to change the background of the standby screen? I think I can do this in the custom CSS, but i'm a noob in CSS editing..... Can someone tell me how i can get a black background on the standby screen? (the standard screen is greyed ?) Because of using my iPad on the wall i need a black screen as background. My blocks were also black as background with white text.
When my project is finished i will share my dashboard here for comments and ideas.Code: Select all
.standby .swiper-slide { background-color:#000000; }
- gielie
- Domoticz version: latest β
Id like to change the way my selector switch is displayed, now it looks like this.
Id like to change the color of the selected tile in the selector switch so it becomes more clear which one is selected, how can i do that?
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
- FIBARO FGS223
- Toon
- Kodi Media Server
robgeerts
- Domoticz version: 3.7067
You could add this to custom.css
label.btn.btn-default.active {
background-color: #aaa !important;
border-color: #aaa !important;
jeroenkl
thanks! Needed it as wellrobgeerts wrote: Monday 22 January 2018 21:26 You could add this to custom.css
label.btn.btn-default.active { background-color: #aaa !important; border-color: #aaa !important; }
10us
Hi, when I use a frame on the standby screen, it becomes partly transparent (greyed out). I read in previous posts that it is a part of the design? Is it already possible (via custom css?) to overrule this? It would be nice if you can also place frames that are visible on a standby screen.
Offtopic: what is the use of standby screen?
Avoid burn-in? Power saving?
10us
Power saving and for minimalistic page design on my 24/7 wall tablet.renerene wrote: Thursday 25 January 2018 0:05 Offtopic: what is the use of standby screen?
Mads
hi. have some problems with my dashticz.
the first problem is:
If i use diffrent browser etc. my phone, safari (mac), chrome (mac), chrome (pc) none of the settings is saved. Every i connect with a new browser, it ask for settings. using the same ip in the browser, not index2.html
i have config the CONFIG.js
the second problem (for now
is that i cant get the moonphases to work. nothing happend, when i load dashticz.
- Skærmbillede 2018-01-25 kl. 16.19.45.png (21.61 KiB) Viewed 5325 times
- Skærmbillede 2018-01-25 kl. 16.20.26.png (39.87 KiB) Viewed 5325 times
- Skærmbillede 2018-01-25 kl. 16.26.27.png (322.33 KiB) Viewed 5325 times
Mads
part 2
- Skærmbillede 2018-01-25 kl. 16.26.27.png (322.33 KiB) Viewed 5323 times
- Skærmbillede 2018-01-25 kl. 16.37.48.png (38.67 KiB) Viewed 5323 times
JimmyH1969
I think you need to remove the "/*" at the beginning and end of the file.
Mads
when i do that, the page wont load :/ have tried
Third problem.
Can´t make blocktitles :/ is there just somthing big wrong with my settings, nothing is happening :S
Third problem.
- htilburgs
Can you post your complete CONFIG.js (filter your keys, etc..)?
With the screenshots it's not possible to see what is going on.
Place it between (replace <> by [] )
Example:<spoiler><code>--</code></spoiler>
- Spoiler: show
Hardware:
Mads
yes offcouse
Deprecation] Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/.
send @ jquery.min.js:4
- Spoiler: show
- EdwinK
- Domoticz version: BETA
is this ' butt$' maybe a the problem?
Mads
it is because i have copy/paste from TERMINAL
Mads
Did find the problem.. (maybe)
removed the last */ at the end at the script now the moonpashse is there. and the block i made.. But now my switces is gone..
Gonna make then in the config files?
