All scripts are written when only change 1 script
htilburgs
Post by htilburgs »
No error, but just noticed.
Is it normal behavior when editing or creating 1 dzVents event-script, that all existing (and active) are saved?
2018-01-20 17:48:55.020 EventSystem: reset all events...
2018-01-20 17:48:55.022 EventSystem: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/PIR.lua
2018-01-20 17:48:55.023 EventSystem: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Ganglicht voordeur.lua
2018-01-20 17:48:55.023 EventSystem: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Zonsonderdergang.lua
Also when i look at "/domoticz/scripts/dzVents/generated_scripts $" I see them all having the date and time of saving.
Hardware:
emme
Domoticz version: latest
Re: All scripts are written when only change 1 script
Post by emme »
I think is by design:
events edited in the UI are normally stored inside the local db (domoticz.db)
Once you save any dzVents file all these events are also copied into the filesystem to allow dzvents framework to use them...
but this is my own personal idea about it :P :P
I think that once a script can be considered in 'production' you can move it into /domoticz/scripts/dzVents/scripts
"We always done this way"
dannybloe
Post by dannybloe »
Patches to the C++ code are happily accepted ;-)
