I have the following setup:
- ibox2
- rgbw/rgbww light bulb
- 5in1 smart led controller
- led strip rgb connected to the 5in1 led controller
I've added the hardware to domoticz port: 5987, bridge type V6, Type: RGBWW.
Right now the bulb is working fine. (Whoeha)
However, the led controller (for the ledstrip) isn't.
I basically (because i was desperate) tried every hardware combination (v4/6 rgb/rgbw / rgbww / white).
Also tried some bash scripts but still no results.
On the ios milight app the strip is responding tough (using controller
)I'm pretty sure i'm not the first to cross this problem. Hope you guys have a fitting solution.
