Python Plugin: Broadlink RM2 V3
zak45
Domoticz version: V2024.4
Re: Python Plugin: Broadlink RM2 V3
Post by zak45 »
@hrushchov
may reason should be wrong IP address or not reachable.
@vchecco
I actually decided to use this one :
http://jarvishome.fr/index.html
Can ask for question like Room Temp / outside temp / Should it rain in next hour etc ...
Able to manage in the way I want and all stay local.
MikeNg
Post by MikeNg »
TigroEHOT wrote: Monday 14 August 2017 6:00 If i delete the hardware and create new with 127.0.0.1 I get the discover device. If i turn it on i get this in the log:
2017-08-14 13:56:05.018 User: Admin initiated a switch command (228/Broadlink RM2 - Discover/On)
2017-08-14 13:56:05.051 (Broadlink RM2) Calling message handler 'onCommand'.
2017-08-14 13:56:05.051 (Broadlink RM2) onCommand called for Unit 1: Parameter 'On', Level: 0 , Connected : False
2017-08-14 13:56:05.051 (Broadlink RM2) All plugin system is on pause for 5s...
2017-08-14 13:56:10.058 (Broadlink RM2) Found 1 broadlink devices
2017-08-14 13:56:10.071 Error: (Broadlink RM2) 'onCommand' failed 'TypeError':'sequence item 0: expected str instance, bytes found'.
2017-08-14 13:56:10.071 Error: (Broadlink RM2) ----> Line 210 in /home/pi/domoticz/plugins/BroadlinkRM2/plugin.py, function onCommand
2017-08-14 13:56:10.071 Error: (Broadlink RM2) ----> Line 397 in /home/pi/domoticz/plugins/BroadlinkRM2/plugin.py, function Discover
2017-08-14 13:56:10.072 Error: (Broadlink RM2) ----> Line 203 in /usr/lib/python3.5/broadlink/__init__.py, function auth
2017-08-14 13:56:10.072 Error: (Broadlink RM2) ----> Line 258 in /usr/lib/python3.5/broadlink/__init__.py, function send_packet
2017-08-14 13:56:10.072 Error: (Broadlink RM2) ----> Line 162 in /usr/lib/python3.5/broadlink/__init__.py, function encrypt_pyaes
2017-08-14 13:56:29.005 (Broadlink RM2) Calling message handler 'onHeartbeat'.
2017-08-14 13:56:29.019 Error: (Broadlink RM2) Error Connecting to Broadlink device....
I'm running domoticz 3.8288 on raspberri pi 3, python 3.5.2, broadlink 0.5
P.S. On the latest stable i get the same error.
I got the same issue and successfully fixed it. So this is what i did.
when i installed broadlink again and also crypo and copied both to the /usr/lib/python3.5 i noticed that the one in the 3.5 has no capitol C for Crypto
i tried to rename it but that did not work.
Then i looked in the folder /usr/lib/python3/dist-packages/ and there is saw Crypto with a lot more files then in the 3.5 one.
So i copied that one "sudo cp -r /usr/lib/python3/dist-packages/Crypto/ /usr/lib/python3.5/" restarted Domoticz and everything works.
SzymonZy
Post by SzymonZy »
Can we use Broadlink SP1 with this plugin already? I found protocol hack on net (https://blog.ipsumdomus.com/broadlink-s ... 0b4b397af1) but will it be implemented into Domoticz?
zak45
Post by zak45 »
SzymonZy wrote: Sunday 17 December 2017 12:35 Can we use Broadlink SP1 with this plugin already? I found protocol hack on net (https://blog.ipsumdomus.com/broadlink-s ... 0b4b397af1) but will it be implemented into Domoticz?
yes, the V4 is finished : could use Sp1 , sp2/sp3/sp3s, mp1, a1
publish soon.
SzymonZy
Post by SzymonZy »
Does git repository at this moment include support for this sockets?
omnisxin
Post by omnisxin »
hi ,zark45:
I use domoticz 3.8791, python 3.4 in raspberry pi, for attached json files ,jsonSubIr.rar is backup seven months ago,jsonSubIr.zip is backup today,all from same phone e-control app,
jsonSubIr.rar can be generated correctly, but jsonSubIr.zip informs error "Error with json files to import "
trace the error ,maybe caused by these lines in plugin.py:
try:
with open(path+"jsonIrCode") as code_name:
data_code = json.load(code_name)
except ValueError: # includes simplejson.decoder.JSONDecodeError
return False
jsonSubIr.rar
(374 Bytes) Downloaded 124 times
jsonSubIr.zip
(547 Bytes) Downloaded 112 times
zak45
Post by zak45 »
hi omnisxin
to be able to test, I need all ini files.
omnisxin
Post by omnisxin »
As described ,jsonSubIr.rar can generate ini files, I'll upload later,but jsonSubIr.zip inform error, didn't generate any files.
SzymonZy
Post by SzymonZy »
@zak45 do you plan to support SC1 in V4 release?
zak45
Post by zak45 »
SzymonZy wrote: Thursday 28 December 2017 12:25 @zak45 do you plan to support SC1 in V4 release?
Not yet part of the broadlink module.
SzymonZy
Post by SzymonZy »
Are there any special circumstances that prevent adding this device in future?
zak45
Post by zak45 »
SzymonZy wrote: Tuesday 02 January 2018 11:16 Are there any special circumstances that prevent adding this device in future?
don't think so... maybe you can made a request to broadlink module devloper:
https://github.com/mjg59/python-broadlink
if this become be part of it, I can try to include into the plugin.
domoticzag
Post by domoticzag »
Hi All,
Quick question.
I have the Broadlink RM2 plugin working for the mini RM 3.
Works fine!
One thing I wanted to do, was use my TV remote controller to set devices in domoticz, so i could use the colors on the remote to set all the lights in the house to the same color :D.
But the device doesnt update if I press the teached button on the remote controller. The RM does imitate the teached code, but not update the device in domoticz.
Is this currently possible with this plugin?
RPi 3
Domoticz Béta
RFLink Gateway dipool antenna
Many kaku devices
P1 smart meter
Custom made ESP8266 devices
Hue lights / Milight ligts and strips
zak45
Post by zak45 »
domoticzag wrote: Tuesday 16 January 2018 21:54 Hi All,
Quick question.
Works fine!
What I had understood, you need some IR receiver connected to Domoticz ( made one myself using ESP8266 + IR receiver ). The RM2 device is just like your TV remote controller, only able to send some IR codes.
domoticzag
Hmm oke thanks, already thought so :o.
Did you use your own code for the ESP8266 if so could you share the code?
Or did you use the Easy ESP Firmware?
I have an ESP and IR receiver lying around somewhere :)
RPi 3
Domoticz Béta
Many kaku devices
P1 smart meter
zak45
Post by zak45 »
domoticzag wrote: Wednesday 17 January 2018 11:44 Or did you use the Easy ESP Firmware?
Yep, ESPEasy is the way to go ;-)
I created a dummy switch and a LUA script :
if devicechanged['IR'] == '16595143' then
    commandArray['433-VoletCuisine'] = 'On REPEAT 2'
    commandArray['433-VoletSAM'] = 'On REPEAT 2'
elseif devicechanged['IR'] == '16586983' then
    commandArray['433-VoletCuisine'] = 'Off REPEAT 2'
    commandArray['433-VoletSAM'] = 'Off REPEAT 2'
elseif devicechanged['IR'] == '16631863' then
elseif devicechanged['IR'] == '16642063' then
elseif devicechanged['IR'] == '16582903' then
elseif devicechanged['IR'] == '16593103' then
elseif devicechanged['IR'] == '16589023' then
    commandArray['Portail'] = 'On'
elseif devicechanged['IR'] == '16635943' then
    if otherdevices['Garage - Porte'] == 'Closed' then
        commandArray['Garage - open'] = 'On'
        commandArray['Garage - close'] = 'Off'
So, in this way I can use my Logitech Harmony as Domoticz remote control
domoticzag
@Zak45 Thanks!
RPi 3
Domoticz Béta
Many kaku devices
P1 smart meter
SzymonZy
Post by SzymonZy »
zak45 wrote: Sunday 17 December 2017 12:40
publish soon.
Any release date scheduled?
ChopCZ
Post by ChopCZ »
I am having a strange issue.
It took me long time to locate the problem but I have found that when I comment out the line
import broadlink
in the plugin.py file
then plugin starts and creates two new devices for discover and remote.
Of course in the log there is an error
2018-01-24 20:30:41.931 (Xiaomi Gateway) Temp (Xiaomi Temperature)
2018-01-24 20:30:42.000 Python EventSystem: Initalizing event module.
2018-01-24 20:30:42.000 EventSystem: Started
2018-01-24 20:30:42.000 EventSystem: Queue thread started...
2018-01-24 20:30:42.094 PluginSystem: Entering work loop.
2018-01-24 20:30:42.370 (Broadlink) Entering work loop.
2018-01-24 20:30:42.370 (Broadlink) Initialized version 3.0.0, author 'zak45'
2018-01-24 20:30:42.373 (Broadlink) Debug log level set to: 'true'.
2018-01-24 20:30:42.373 (Broadlink) 'Version':'3.0.0'
2018-01-24 20:30:42.373 (Broadlink) 'Author':'zak45'
2018-01-24 20:30:42.373 (Broadlink) 'DomoticzVersion':'3.8841'
2018-01-24 20:30:42.373 (Broadlink) 'DomoticzHash':'b86cc8ab'
2018-01-24 20:30:42.373 (Broadlink) 'Address':'127.0.0.1'
2018-01-24 20:30:42.373 (Broadlink) 'Key':'BroadlinkRM2'
2018-01-24 20:30:42.373 (Broadlink) 'Mode3':'no'
2018-01-24 20:30:42.373 (Broadlink) 'Mode5':'9000'
2018-01-24 20:30:42.373 (Broadlink) 'Mode6':'Debug'
2018-01-24 20:30:42.373 (Broadlink) 'Port':'0'
2018-01-24 20:30:42.373 (Broadlink) 'Mode1':'000000000000'
2018-01-24 20:30:42.373 (Broadlink) 'HardwareID':'6'
2018-01-24 20:30:42.373 (Broadlink) 'HomeFolder':'/home/pi/domoticz/plugins/Broadlink/'
2018-01-24 20:30:42.373 (Broadlink) 'Name':'Broadlink'
2018-01-24 20:30:42.373 (Broadlink) 'Mode4':'no'
2018-01-24 20:30:42.373 (Broadlink) 'DomoticzBuildTime':'2018-01-24 15:06:19'
2018-01-24 20:30:42.373 (Broadlink) 'Mode2':'/home/pi/domoticz/broadlink_ini'
2018-01-24 20:30:42.373 (Broadlink) Device count: 2
2018-01-24 20:30:42.373 (Broadlink) Device: 1 - ID: 52, Name: 'Broadlink - Discover', nValue: 0, sValue: 'Off'
2018-01-24 20:30:42.373 (Broadlink) Device ID: '52'
2018-01-24 20:30:42.373 (Broadlink) Device Name: 'Broadlink - Discover'
2018-01-24 20:30:42.373 (Broadlink) Device nValue: 0
2018-01-24 20:30:42.373 (Broadlink) Device sValue: 'Off'
2018-01-24 20:30:42.373 (Broadlink) Device LastLevel: 0
2018-01-24 20:30:42.373 (Broadlink) Device: 254 - ID: 53, Name: 'Broadlink - Remote', nValue: 0, sValue: ''
2018-01-24 20:30:42.373 (Broadlink) Device ID: '53'
2018-01-24 20:30:42.373 (Broadlink) Device Name: 'Broadlink - Remote'
2018-01-24 20:30:42.373 (Broadlink) Device sValue: ''
2018-01-24 20:30:42.374 (Broadlink) Device LastLevel: 0
2018-01-24 20:30:42.374 (Broadlink) Connecting to: 127.0.0.1:000000000000
2018-01-24 20:30:42.374 Error: (Broadlink) Error Connecting to Broadlink device....
But when I uncomment the import line and restart my Domoticz then it freezes everytime and it is not responding.
I have tried to use broadlink module directly and my test script
import broadlink
devices = broadlink.discover(timeout=5)
print(devices)
is working fine when I run it from the console.
Any advices?
zak45
Post by zak45 »
ChopCZ wrote: Wednesday 24 January 2018 20:44
import broadlink
print(devices)
Any advices?
can you do in console :
pip show broadlink
pip3 show broadlink
