But then you're using config['garbage_icalurl'] and not config['garbage_zipcode'] and config['garbage_housenumber']? Zipcode and housenumber are used by the veldhoven parser.Moosjes wrote: Wednesday 10 January 2018 16:59I found the sollution to my own problem. I had selected the company 'Veldhoven' instead of 'veldhoven' (mind the capital V). After changing this it still did not work.Moosjes wrote: Wednesday 10 January 2018 14:32 I have added the Garbage calander of Veldhoven to my Dashticz but all I get in the dashboard is 'Laden...'
After I changed the company to 'ical' it worked![]()
Dashticz - Module - Garbage collector Topic is solved
aiolos
- Domoticz version: stable
Re: Dashticz - Module - Garbage collector
AndreFR
Hi Rob/aiolos,robgeerts wrote: Monday 08 January 2018 21:30 Hmm indeed, we cannot use the afvalkalender.container-beheer.nl website.
But I've read on the website of Rotterdam that you should be able to use mijnafvalwijzer.
Try choosing this in dashticz-settings and enter your zipcode and house number.
I’ve requested to have our city to be included to the ‘mijnafvalwijzer.nl’ website, it works if I use another ‘postcode’....
jake
garbage.js needs an update. Indeed kliko.png has moved, but not yet in the code.htilburgs wrote:When using config['garbage_icon_use_colors'] = false; in your config.js, no icon is showed.
When checking I think the problem is:
While it should be img/trashcan/kliko.pngCode: Select all
<img class="trashcan" src="img/kliko.png" style="opacity: 1;">
instead of "img/kliko.png", it should be "img/garbage/kliko.png"
- EdwinK
- Domoticz version: BETA
Was just going to post about thisjake wrote: Thursday 11 January 2018 22:25garbage.js needs an update. Indeed kliko.png has moved, but not yet in the code.htilburgs wrote:When using config['garbage_icon_use_colors'] = false; in your config.js, no icon is showed.
aiolos
Thanks for noticing. I made a PR to fix it.
geertvercamer
- Target OS: -
There is a problem with the 'ophaalkalender' method for Belgium.
In the function mapGarbageType() a mapping is done from 'blue' to 'papier', however that should be 'PMD (line 350)'. 'brown' should map to 'papier'
In my region we only have 'pmd', 'restafval' and 'p-k', but there are more in ie. Gent:
- GFT: green
- Glas: yellow
- Grof huisvuil afroep: purple
- Kerstboom: lightgreen
- P-K: brown
- PMD: blue
- Restafval: grey
and it may be nice to have a config/setting variable for the date format.
Thanks.
- GFT: green
- Glas: yellow
- P-K: brown
- PMD: blue
- Restafval: grey
Thanks.
- EdwinK
I still miss a 'thank you' button
So, thank you
robgeerts
- Domoticz version: 3.7067
It's merged
- EdwinK
Thanks again
maceddy
- Domoticz version: 12723
Any chance you will implement 'Area Reiniging'?
http://www.areareiniging.nl/home/bewone ... -digitaal/
It shows a Calendar in some sort of frame and there is a possibility to download iCal, but I can not get it to work..
You may use my ZIP and house number (request per DM please
) if you plan on testing it.
Regdul
- Domoticz version: 3.8153
is there any change to add "de friese meren' garbage calendar? same as maceddy, i cant get it to work. there is an option for Ical
https://dfm.afvalalert.nl/#
thanks!
thanks!
pkrabben
- Domoticz version: 3.5877
Hi All,
De Garbage collector is not working anymore in Almere
can you add http://afvalportaal2.2go-mobile.com/mod ... /calendar/
Thanks In advance
Thanks In advance
aiolos
pkrabben wrote: Monday 15 January 2018 11:57 Hi All,
Thanks In advance
Both these garbage collection calendars are added. See this PRmaceddy wrote: Saturday 13 January 2018 21:16 Any chance you will implement 'Area Reiniging'?
You may use my ZIP and house number (request per DM please) if you plan on testing it.
The garbage company configuration is:
config['garbage_company'] = 'area';
and
config['garbage_company'] = 'almere';
Please note that for Almere the GFT & Rest are combined, they show up as a green bin, this can of course be changed with selecting another bin for this type of garbage.
Both calendars use the same (or a very alike) API as 'Twente Milieu'. I expect more calendars are based on this API, which makes it very easy to add them.
I tested this with a random address in Emmen and Almere, please let me know if you experience any difficulties (after a merge of course, it is not in there yet)
I saw the 'De Friese Meren' request. Looks do-able, but I could not implement it in the short time I had available right now. I will look into it later.
pkrabben
Thanks Almere is working
- EdwinK
Is it right that the colors of the trashbin's dont change anymore?
aiolos
In this PR the support for this garbage calendar is added.Regdul wrote: Sunday 14 January 2018 23:36 is there any change to add "de friese meren' garbage calendar? same as maceddy, i cant get it to work. there is an option for Ical
thanks!
Configuration:
config['garbage_company'] = 'afvalalert';
It is very likely this company also works for other regions than 'De Friese Meren'
It does with my config (which is pretty standard for development) For various garbage companies and addresses I saw different colours of bins.EdwinK wrote: Tuesday 16 January 2018 18:25 Is it right that the colors of the trashbin's dont change anymore?
robgeerts
PR is merged!
- EdwinK
Then I've to look through all the settings (again).
- EdwinK
Looks there is something more happening.
As seen on https://www.mijnafvalwijzer.nl/nl/3161LH/27/ today is 'grof vuil' and on Friday we have 'rest'. But on dashticz it shows all the dates as 'rest'. Only 'gft' is changing colors in the text.
Part of config.js
Part of config.js
config['garbage_company'] = 'mijnafvalwijzer';
config['garbage_icalurl'] = '0';
config['garbage_calendar_id'] = '';
config['garbage_zipcode'] = '3161LH';
config['garbage_street'] = 'Jonkerhof';
config['garbage_housenumber'] = '27';
config['garbage_housenumberadd'] = '';
config['garbage_maxitems'] = 2;
config['garbage_width'] = '6';
config['garbage_hideicon'] = '0';
config['garbage_icon_use_colors'] = 1;
config['garbage_use_colors'] = 1;
config['garbage_use_names'] = 1;
config['garbage_use_cors_prefix'] = '0';
//Afval
config['garbage'] = {
gft: {kliko: 'green', code: '#375b23', name: 'GFT'},
// pmd: {kliko: 'orange', code: '#db5518', name: 'PMD'},
rest: {kliko: 'grey', code: '#5e5d5c', name: 'Restafval'},
papier: {kliko: 'blue', code: '#153477', name: 'Papier'},
// kca: {kliko: 'red', code: '#b21807', name: 'Chemisch afval'},
brown: {kliko: 'brown', code: '#7c3607', name: 'Grof Vuil'},
// black: {kliko: 'black', code: '#000000', name: 'Zwart'},
geertvercamer
- Target OS: -
Maybe this has also something to do with this function mapGarbageType()?
