Controlicz - Easy Domoticz to Alexa Integration Topic is solved
Re: Controlicz - Easy Domoticz to Alexa Integration
Hi @Madgeni
at first thanks a lot for your work and this skill!
Until a few days it work flawless, but now the "old" devices still work, but its not possible to add new devices/find changes at current devices (namechange). I de- an reactive the skill like you advice the user with a simillar problem. Also i test the connection in my controlicz.com account. Hope you can help me.Thank in advance!
PS: cant PM you at the Moment, not enough Posts. email is: domoticz(at)wmhdesign.de
Works again, dont know what it was. Have sent you a small donation for your work, its not much but hope it helps little bit.
thanks stefanwo - any donation is very welcome - just glad it's working
- Domoticz version: v3.8153
hi
excuse me i don't enderstand how can i made the comunication betwin google home and controlicz i m french and your prodjet is realy young to have any translation if someone can help me thanks
Thank you for sharing @Madgeni, very cool. Donation sent
Hello madegeni have you bean accept my request tout bé had tout your project?
pm me your email - also, can you post in the right topic? This is the Alexa one
thanks o have ad me does it s possible to read a temperature of domoticz capteur? i have 10 oregons and my wife hops to tell: "ok google quel temperature fait il dehors?" wel li m french and hops you can anderstand mi question
Should be ok? "What's the temperature in the <device>?
This is very cool. Got it all up and running except 1 small problem. My temperatures in domoticz are set up for Fahrenheit, but trying to ask for or set the thermostat temperature Alexa converts them as if they were Celsius. Am I doing something wrong ??
hi - i pass Celsius. I'll see if the Domoticz API provides the scale and i can change it.
It appears that it is passing the Farenheit value, but indicating to Alexa that it is Celcius value, which she then converts to Farenheit resulting in Alexa reporting that it is 159 degrees in the house instead of the 71 degrees Farenheit that it actually is.
Many thanks for all of the work and the countless hours of help.
o_0 do you live in the Sun?
The snag is that Alexa will only take Celsius, fahrenheit or kelvin - but Domoticz doesn't provide a scale in the device detail
- DieHappy
- Domoticz version: V4.10717
Wow this works really created. I have it up and running with my synology 214play. You only have to port forward 8084!!!
- DieHappy
I question: how do I ad controlicz in domoticz to use the friendly name ad my switches???
Hi - in the Devices tab of Domoticz, select 'edit' for a device, then in the Description field put Controlicz:<friendlyname> then when you rediscover, these should be in your Alexa app
- Domoticz version: 3.5877
i had to re-initiate domoticz <> controlicz <> alexa, but since then, i cannot set percentage of a scene anymore. Alexa won`t dim my scene to certain level.
In domoticz:
3x Fibaro roller shutter, configured as blinds percentage.
Scene with all these blinds
Controlicz to domoticz works, scene is imported into alexa
I can set percentage of each switch by voice, but the whole scene is not working?
Any ideas or help would be appreciated
Thanks guys!
In domoticz:
Thanks guys!
Rasp PI, Domoticz V 3.5877, OpenZWave USB Version: 1.4-2228-gbce4a88-dirty
- Domoticz version: 2023.1
Nick, just sent you a donation for a drink to say thank you for Controlicz. Keep up the excellent work.
Thank you
Thank you
Thanks dgilbert - very grateful, i've got family in Wymeswold, so lots of happy memories of your neck of the woods growing up
It can be a small world
