Mochad compatibility with Raspbian Stretch
amercat37
Post by amercat37 »
I've been working on upgrading from a Pi B+ with Weezy and Domoticz 2.xx to a Pi 3 with Stretch and the latest Domoticz.
It seems everything is working great except for mochad. I can build it just fine, but when I echo any commands to nc 1099 it just hangs forever.
Has anyone else tried mochad with Stretch? I could just go to Jessie instead if I had to. I would just like to upgrade to the latest when possible.
I've tried mochad 0.1.16 and 17.
amercat37
Re: Mochad compatibility with Raspbian Stretch
Post by amercat37 »
So I've given up on Mochad, and X10. Time to upgrade to something more modern.
Hansbit
[SOLVED] Re: Mochad compatibility with Raspbian Stretch
Post by Hansbit »
SOLVED!
Had the same problem with Stretch and Mochad. Found a useful workaround. (after hours of searching :x )
Just add a timeout (-w1) of 1 second to your nc command:
echo "st" | nc -w1 localhost 1099
This works great for me. I've updated my domoticz_main script.
Even more secure, now mochad can never cause the proces to hang.
Thuis
Post by Thuis »
Hello, i have this also, mochad crashing domoticz after a while. I am a linux newbie, so before i go search for hours, could you tell me where or how to put:
this?
maybe i put it in rc.local or in .bashrc, really i have no clue, please could someone help me or explain to me where i can put this.
I can type it on the cli, but where do i put it so it will start when the pi starts? Thanks in advance.
Ok ill put it in ~/.bashrc
thanks for this.
If you can not handle a computer, you buy a Mac. If you can not handle domotica, you use Homeassistant!
