dzVents Tab in Log
emme
Domoticz version: latest
dzVents Tab in Log
Post by emme »
Ciao, happy new year to you all!!!
Could it be an idea to add a dzVents tab in the log screen and add a dropdown selection for the specific script? (maybe gathering the mark strings specifies in the Logging section?)
I'm aware about the existence of the search string... but this way it would be much nicer and easy to use :P
ciao
M
"We always done this way"
dannybloe
Re: dzVents Tab in Log
Post by dannybloe »
Nice idea. Wouldn't it be better even that a script is more like an identity in Domoticz like a device with it's own log. So you can get a similar list as with a switch where you can see when the script was executed (and perhaps due to which rule/event).
But then.. I want a more advanced IDE for editing dzVents scripts in Domoticz as well where I can edit my scripts, see the script-logs, maybe test scripts directly from the GUI with dummy data (kind of unit testing) etc etc.
But there's only so much a single person can do and I don't like the javascript front-end architecture enough to start doing this myself.
