Mac Based presence script
goshi0
Post by goshi0 »
This is a variation of a few scripts wich mostly are depenents of the ip address this one search your device with your mac and make a ping to double check the presence in the net
you will need to install arp-scan from repositories
sudo apt-get install arp-scan
tested from 2 weeks in a raspberry but must work in every linux distro
#!/usr/bin/python
import http.client
import requests
from subprocess import check_output
#################config ######################
mac = "Your Mac address"
idx = domoticz idx
# ARP checking
out = check_output(["sudo","/usr/bin/arp-scan", "-l"]).decode('utf-8')
#look for mac
if mac in out:
#look for mac's ip
  for elemento in out.split("\n"):
  #mac ruben 'ac:c1:ee:2e:92:e6'
     if mac in elemento:
       linea = elemento.strip()
       ip = linea[linea.find("192"):linea.find(" ")]
  ping = check_output(["/bin/ping","-c 2" ,ip]).decode('utf-8')
  #2 pings to the ip f
  if '2 packets transmitted, 2 received' in ping:
   # if the ip answers to ping turn the switch on
   r = requests.get('http://192.168.1.101:8080/json.htm?type=command&param=switchlight&idx=60&switchcmd=On&username=Y29tZWRvcg==&password=ZmFuaHVudGVy')
  else:
  #  If not turn the switch off
    r = requests.get('http://192.168.1.101:8080/json.htm?type=command&param=switchlight&idx=60&switchcmd=Off&username=Y29tZWRvcg==&password=ZmFuaHVudGVy')
else:
   #The mac isnt in the arp tables turn switch off
   print ('nadie en casa')
   print (r.text)
