I use Domoticz v3.8796.
To preserve the peace and the privacy into my home, I'd like to disable switches log, and specifically the "Last Seen" info and the log buttons.
In "Setup / Settings" I set "Log History" for "Light/Switches" to 0 day, but it does not produce the expected result.
Do you know any way to achieve this need ?
Thanks.
Disable "Last Seen" on switches
- Domoticz version: 2023.1
Re: Disable "Last Seen" on switches
So my quick&dirty is to hide these infos by adding this in css/legacy.css
and not checking the log file when my kids tell me the time they came back last night ...
#dashSwitches #lastupdate {
display: none;
#itemtablenostatus #lastupdate {
display: none;
#itemtablenostatus .btnsmall[data-i18n="Log"] {
display: none;
- Egregius
- Domoticz version: v2024.7
You can remove the entries from the database.
That's one way, but i don't know what will happen after an updatejpaul wrote: ↑Saturday 30 December 2017 15:54 So my quick&dirty is to hide these infos by adding this in css/legacy.cssand not checking the log file when my kids tell me the time they came back last night ...Code: Select all
#dashSwitches #lastupdate { display: none; } #itemtablenostatus #lastupdate { display: none; } #itemtablenostatus .btnsmall[data-i18n="Log"] { display: none; }
Interesting issue. I must admit that at times I use the log to see what time people come home (kids) or go to sleep. What is your situation that you want to have hidden? Just curious.
- Domoticz version: current
The new Aurora theme has privacy options based on this issue.
Users browsing this forum: Google [Bot], zicht and 1 guest
