ZigBee USB dongle recommendations for a computer as DIY Home Automation Gateway?
I was wondering if anyone have any tips for inexpensive ZigBee USB dongles that supports all ZigBee protocols and profile specifications?
Specifically I would like one that supports ZigBee Home Automation, ZigBee Light Link, ZigBee Smart Energy, as well as ZigBee PRO.
I run Domoticz on an x86/x86-PC mini-PC so I need a ZigBee USB dongle (and not a Raspberry Pi or Arduino shield adapter).
I'm on a low-end budget and wish to start with the new inexpensive Ikea Tradfri ("Trådfri") series of smart lights and a few Xiaomi smart home sensors.
http://home.bt.com/tech-gadgets/tech-ne ... 4101204450
http://xiaomi-mi.com/smart-home/xiaomi- ... -home-kit/
It would be really nice if it would work with Domoticz out-of-the-box & supported most common ZigBee profiles specification if not all.
PS: Does anyone know why there is not a "ZigBee" subforum yet here in the Domoticz comumity forums? => https://www.domoticz.com/forum/viewforum.php?f=54
ZigBee based sensors are getting more and more popular worldwide as ZigBee sensors tend to be way cheaper than Z-Wave.
Re: ZigBee USB Dongle recommendations for DIY Home Automation Gateway?
Anyone have experience and feedback about these or other ZigBee USB dongles to recommend with Domoticz?
Sena ProBee-ZU10 (ZU10-G01)
https://adaptivemodules.co.uk/index.cfm ... uct_ID/746
http://www.senanetworks.com/products/in ... e/zu10.php
http://www.senanetworks.com/download/da ... e-ZU10.pdf
http://www.senanetworks.com/download/ma ... v1.5.3.pdf
Telit ZE51 ZigBee USB Dongle
https://adaptivemodules.co.uk/index.cfm ... egory_ID/7?
http://www.telit.com/fileadmin/user_upl ... asheet.pdf
http://www.telit.com/fileadmin/user_upl ... de_r10.pdf
I am even having a hard time telling if these even supports all ZigBee profile specifications or not?
Anyway, I would prefer one with replacable RP-SMA antenna, but need to support all specifications.
No one have any experience with ZigBee USB dongles for Domoticz to recommend (or not recommend) hardware?
Does anyone know if ZigBee USB dongles plugged into a PC with Domoticz should work without too much hassle?
How about ConBee USB dongle from Dresden Electronic?
https://www.dresden-elektronik.de/funkt ... f81b62b2bd
Dresden Electronics says that their open source gateway software "deCONZ" support to use the ConBee USB dongle to control ZLL lights from Osram, Philips, and Dresden Elektronik FLS ballasts.
https://github.com/dresden-elektronik/d ... est-plugin
https://github.com/dresden-elektronik/basic-aps-plugin
Specifications says it supports ZigBee Home Automation, ZigBee Light Link, and ZigBee 3.0, and should be compatible with Windows 7 / 8 / 8.1 / 10, Ubuntu Linux / Raspbian.
https://www.dresden-elektronik.de/funkt ... docID=5046
https://www.dresden-elektronik.de/funkt ... docID=5042
Not way too expensive either:
https://www.amazon.com/NEW-gateway-comp ... B01FDWOIHK
https://www.amazon.co.uk/NEW-gateway-co ... ConBee+USB
https://www.amazon.de/dp/B01FDWOIHK
ZatarraNL
- Domoticz version: 4.10717
Re: ZigBee USB dongle recommendations for a computer as DIY Home Automation Gateway?
I have this exact question myself. Did you try one of these usb dongles? Can you share your experience?
deennoo
Just get a RaspBEE premium GPIO Device, let's try it first, then let's try to make it works with Domoticz (or not...will see)
http://domo-attitude.fr
Netsurfer24
Hi @all!
Any new findings concerning this topic?
Greetings
Gunther
Greetings
Gunther
deennoo
À zigate plugin is on thé way. www.zigate.frNetsurfer24 wrote:Hi @all!
Greetings
Gunther
Netsurfer24
@deennoo:
Thanks for the tip - looks promising.
Maybe someone can answer my question if it is also possible to use an "Amazon Echo Plus" with its integrated ZigBee-Smart Home-Hub?
Will this network (initiated by the Echo Plus) be "visible" for Domoticz so that one could control the devices in the network? Or is there any additional hardware needed?
Many thanks in advance for any helpful answer!
I wish you all a Merry Christmas and happy House Automation
Gunther
Gunther
- LouiS22
Hey denno, any ETA on that plugin? Hope you mean Domoticz plugin for the Zigate hardwaredeennoo wrote: Friday 22 December 2017 15:56À zigate plugin is on thé way. www.zigate.frNetsurfer24 wrote:Hi @all!
Greetings
Gunther
Apparently there's now a working plugin working for Zigate: https://www.domoticz.com/wiki/Zigate
Anyone tried it?
Anyone tried it?
