All local at bottom of script
poudenes
Domoticz version: 3.8993
Post by poudenes »
Hi There,
I tried but didn't work. Is there a way to put all the local variables at the bottom of a script.
So i see the script instead of scrolling down to edit?
BakSeeDaa
Re: All local at bottom of script
Post by BakSeeDaa »
Doing what you described would change the scope of the variable and will probably change how it works.
myVar = 123 -- Assign 123 to a global variable
local myVar  --  Define a new different variable (a local scope variable) using the same name
myVar = 123 -- 123 will be assigned to the local variable myVar from now on.
It's all about the variables scope. You can read about it.. This has nothing to do with dzVents, it's pure Lua.
So don't change your scripts like that. ;)
poudenes
Post by poudenes »
