Madgeni
ok, that isn't a Controlicz issue - I had the same right at the start
try this?
https://www.techwalls.com/home-control- ... -home-app/
try this?
fergalom
That was it, thanks!! Bloody hell that was well hidden if you dont have a google home deviceok, that isn't a Controlicz issue - I had the same right at the start
try this?
Madgeni
Yep, it's a pain! Still, once you've enabled Controlicz, Home Control stays in your menu
nounours0000
Hi Madgeni,
I just registered, can you please tes beta program controlicz.
My email perr****@gmail.com
Thank you !
Thank you !
holybob
Please can you add me to the beta program. My Google account is Gavin@se***.com
lrachet
Hi Madgeni, Could you please add me too - my e-mail: lrachet****@gmail.com
Thank you !
Thank you !
- DewGew
- Domoticz version: V4.10618
I can't link my account in home control. it says " couldn´t update setting. check your connection".
Any ideas?
Any ideas?
Madgeni
Hi thereDewGew wrote: Wednesday 20 December 2017 13:30 I can't link my account in home control. it says " couldn´t update setting. check your connection".
Any ideas?
if you go into your Profile on Controlicz, you'll find the new improved 'test connection' button - this will verify that Controlicz has access to your Domoticz instance? If this fails, check you can access your Domoticz via HTTPS from an external source, and that the uid/pwd you've specified work.
Madgeni
ticranou wrote: Friday 15 December 2017 17:14 no problem
well... with a colleague, we made a test within his Controlicz account. His connection test also uses the getVersion request, but he has a user specified in the log related to the request. But I don't... ???
Hi there -
i've re-written the test functionality, should be robust now - care to try again?
- DewGew
The test is ok. I have connection. json call works also in my browser. Seems to be something on google. I manage to link yesterday and I had some problems then i unlinked it today and now I can't link it back.Madgeni wrote: Wednesday 20 December 2017 13:48Hi thereDewGew wrote: Wednesday 20 December 2017 13:30 I can't link my account in home control. it says " couldn´t update setting. check your connection".
Any ideas?
EDIT: Never mind. it linked back now for some reason
Last edited by DewGew on Wednesday 20 December 2017 14:05, edited 1 time in total.
Madgeni
urgh - stupid Google, and their stupid app. I've not found a clean way of fixing this, all I can suggest is clearing app cache, force stopping and keep trying - sorry!
- DewGew
Never mind. it linked back now for some reasonMadgeni wrote: Wednesday 20 December 2017 14:04 urgh - stupid Google, and their stupid app. I've not found a clean way of fixing this, all I can suggest is clearing app cache, force stopping and keep trying - sorry!
Madgeni
good and bad i guess!
nairolFlo
Hi Madgeni,
I just registered to Controlicz.
Could you please add me in your beta program.
My email is flo***********@gmail.com
Thanks in advance,
Thanks in advance,
waow29
Hi Madgeni,
I register on Controlicz the 05/12/17, my email is [email protected]
Could you add me please?
bldewit
- Domoticz version: Stable
Hi Madgeni,
It's working better and better for me. There is however one thing: if I want my shutteres closed, I have to say "open shutters" and vice versa. On and Off works fine by the way, where On equals Close I can of course add dummy buttons to reverse this, but that would not be my preferred option. Do you know of a solution to reverse these commands within Google (or domoticz perhaps)?
Thx!
Thx!
Running on rPi 4b (main) and rPi 3b (somfy), both RFLink
IthoRemote, Xiaomi Gateway, KAKU
wimfabries
Hi Madgeni,
Great work. Can you add me for google-beta, my adress is wim***@cas****.**
Wim
Wim
miremi
Ubuntu 16.04.3, Core i5 8GB RAM 120GB SSD, RFlink, ESPeasy, Z-Stick Gen5, 8 FIbaro, 17 Neo Coolcam
deennoo
Hello Madgeni.
Can see, controlicz on m'y Home contrôle.
Have you remove m'y account ?
[email protected]
[email protected]
http://domo-attitude.fr
Madgeni
hah - that is annoying. Not sure I can do much to it, because if i inverted it, then no doubt, it would be the other way for someone else!bldewit wrote: Thursday 21 December 2017 0:05 Hi Madgeni,
Thx!
