Controlicz - Easy Domoticz to Alexa Integration Topic is solved
Alexa, Google Home and Siri
Ro8in
Re: Controlicz - Easy Domoticz to Alexa Integration
Post by Ro8in »
Ok never mind I could update my profile..
Now i got another problem. If i let Alexa routine set a switch, it will only set it to 93%. Is there a way to just set it ON or 100% ?
Scoobydoo
Post by Scoobydoo »
Hi.
Was wondering if it's possible to add timers to the skill so for instance you could say 'Alexa turn off the bedroom lights in 5 mins or turn on the heating at 8am' .
Would be a very useful feature if it's possible to implement?.
Madgeni
Post by Madgeni »
Hi, i like that idea - will make a feature request for Alexa
Madgeni
Re: Easy Domoticz to Alexa Integration
Post by Madgeni »
skybehind wrote: Saturday 16 December 2017 22:21
farhanito wrote: Thursday 02 November 2017 16:34 hi @madgeni,
what's proper device type/subtype for a door lock? it's a Yale ZigBee doorlock (as dummy switch)
this is the only thing that isn't working for me..
I want to follow up on this as the door lock doesn't work for me either. I can say turn on or turn off, but Alexa sees it as a light switch, rather than a door lock
Hi skybehind -
can you PM me your email address, and i'll take a look at this
Madgeni
Post by Madgeni »
Ro8in wrote: Monday 18 December 2017 0:34 Ok never mind I could update my profile..
Hey - can you PM me your email address, and try this again? I'll take a look at the logs, and see what's being passed back.
IDANIT
Post by IDANIT »
Did you change, in switches, icon from "Light/Switch" (light bulb) to "Generic" (red button)?
markcame
Post by markcame »
Hi Madgeni, i'm a user of controlicz i'm very happy for this skill and they work like a charme but in the last periods i lost the functionality for the reading of the temperature, in my domoticz i have a tem+humidity sensor for external temperature (and this work ok) but my evohome thermostat zones that previously report correct temperature now doesn't work anymore and when i ask to alexa fot the temperature, alexa respond alwaysreading the temperature of the external temperature sensor.
can you help me ?
thanks
slash909
Post by slash909 »
Hi Madgeni - another suggestion for you.. how about adding a log view feature to the controlicz web page so us folks can help ourselves when stuff doesn't quite work? maybe save you some time trawling logs for us..? OR you think you'll just get more questions about the log syntax ;) Obviously need to filter the log by user ID for data protection etc.
cheers
Stu
RedRaven
Post by RedRaven »
Madgeni wrote: Sunday 17 December 2017 17:02 Yep, pretty sure. What you've linked to is how to roll your own custom skill "Alexa ask the house what light is on" etc etc. All those intents need to be created and handled.
What you have with controlicz is a bona fide Alexa smart home skill, with direct interaction, however it depends on them adding functionality on their side.
The latest version provides status reporting ( everything reports it's state to controlicz), but won't be available to query until Alexa add the relevant request intents
Thanks for the heads up. Just wanted to point to something relevant, in case you missed it :)
Alexa has lots of potential but it is crippled! Another thing I have been wanting was timers with devices, not sure if that's supported either. It would be pretty cool to say "Switch off Living Room Lights After 30 Minutes"
Madgeni
Post by Madgeni »
How far we've come - six months ago, there was no easy voice control for Domoticz, now our list of demands becomes increasingly complex ;-)
This is an excellent feature request, and i've already raised it via the 'Feature Request' forum on the Alexa Dev site.
RvdB
Post by RvdB »
Hi Madgeni, I like the skill, it has raised the WAF factor considerably... Have a beer on me, donation is coming your way.
Madgeni
Post by Madgeni »
Hi RvdB - glad she approves! Thanks for the donation, really appreciate it :)
rathmannm
Domoticz version: 3.8153
Post by rathmannm »
Hey,
I have a strange issue with my Controlicz setup:
I can ask Alexa for the temperature that my thermostat is set to and it responds with the correct value. However when I ask to set the temperature Alexa just says "I'm not quite sure what went wrong". It was working fine in the past and I can still set the thermostat temperature in Domoticz without any problems. I've tried forgetting and discovering the devices in Alexa but that hasn't made any difference.
Any ideas?
Thanks,
Manuel
sach
Post by sach »
Same issue here.
mbulles
Post by mbulles »
I have been using Controlicz before with this same setup and it worked well when trying to discover my switches from domoticz.
Also re-discovery usually was not an issue!
Today I had to do a new discovery as I have added new switches but unfortunately Alexa cannot find anything anymore.
I have verified that my external connectivity does still work and is using https and the controlicz/domoticz user.
I have checked via the Controlicz website that it is able to reach my Domoticz host, which it does.
Any other idea on how to further troubleshoot this?
Domoticz
Platform: Raspberry Pi B
Protocols: X-10 / RFY / HomeMade P1 Smartmeter USB TTL-RS232-WE on Kampstrup
Hardwarre: CM15Pro / RFXTRX433E
Madgeni
Post by Madgeni »
let me take a look - can you PM me your email address?
Madgeni
Post by Madgeni »
mbulles wrote: Saturday 23 December 2017 9:34 Hi,
Can you disable and re-enable the Controlicz skill in your Alexa app please?
mbulles
Post by mbulles »
Madgeni wrote: Saturday 23 December 2017 9:36 let me take a look - can you PM me your email address?
Done....you should have it...
Domoticz
mbulles
Post by mbulles »
Madgeni wrote: Saturday 23 December 2017 9:42
Hi, that actually did the trick, everything is back working again! Sometimes it can be just as easy as that....
Thanks you for the quick reply! Have a nice Christmas and I'll make a donation as well to keep up the good work!
Domoticz
Madgeni
Post by Madgeni »
thanks mbulles - glad it's working :) Merry Christmas!
