I'm trying to track down a problem which I suspect (but don't know for sure) is a Controlicz issue - each morning one of my living room lights is ON even though I switch it OFF the night before.
It's a LightwaveRF light switch connect to Domoticz running on a Raspberry Pi with a RFXLink.
- The problem had never happened before I got an Echo/Controlicz
- Controlicz Works great to control the lights throughout the day
- There is NOTHING logged on Domoticz regarding a light ON command (which is weird!)
- I've taken the batteries out of the LightwaveRF controller in case its gone bad.
- I do see some incoming connections in to Domotocz overnight (see below) but that's all on the log except backups.
2017-12-13 23:34:23.286 Incoming connection from: 208.113.204.247
2017-12-14 00:48:27.492 Incoming connection from: 198.143.158.180
2017-12-14 01:19:47.271 Incoming connection from: 158.85.81.121
2017-12-14 02:04:46.352 Incoming connection from: 218.28.0.150
2017-12-14 04:12:30.467 Incoming connection from: 82.221.105.6
Any help or pointers what to try next really appreciated!
