Python plugin with HTTP
galinette
Post by galinette »
Dear all,
I am trying to write a plugin for a nice multichannel electrical consumption device (legrand 412000) which acts as a webserver, and provides real-time AC current measures over 5 channels in JSON format.
I started from the examples from the "Developing a Python plugin" wiki page, but none seem to work on the current Domoticz version. I always have the following message:
'onMessage' failed 'TypeError':'onMessage() takes 2 positional arguments but 4 were given'.
All examples and the documentation as well define onMessage like this:
def onMessage(Connection, Data):
But it seems that Domoticz call it with 4 arguments. Where can I find documentation (posts about API change, etc...) about this?
Dnpwwo
Re: Python plugin with HTTP
Post by Dnpwwo »
@galinette,
The onMessage interface changed some time ago, the wiki represents the new interface.
I would recommend running the current beta version and using the 2 parameter version although from memory there is an old version of the HTTP example in github history that takes 4 parameters if you really want to stick with 'stable'
galinette
Post by galinette »
I thinks this goes the other way. The old interface has 2 parameters and the new one 4 parameters.
I am using the beta release (3.8789) and the API indeed has 4 parameters for onMessage.
So I think the wiki example is deprecated.
Now I managed to get the google HTTP request example working.
I have a new issue : my HTTP "stub" plugin works on any url (internet, local, ...) except the device I am trying to implement. The Domoticz plugin system crashes upon receiving the answer from the device webserver, and before the onMessage event is triggered. It seems that the plugin system has a problem parsing the HTTP reply.
I'll file a bug, is the forum the best way to report a bug?
Dnpwwo
Post by Dnpwwo »
@galinette,
Reproducable crashes are easy to fix. If you post your plugin and the URL I can have a look at it.
As to the parameter thing, there is something wrong at your end somewhere. Are you building from source or downloading pre-built?
If you look at all the example plugins (https://github.com/domoticz/domoticz/tr ... s/examples) they have a definition of:
    global _plugin
    _plugin.onMessage(Connection, Data)
and the Domoticz code that calls it is:
	// Data is in a dictionary
	if (m_Data)
		pParams = Py_BuildValue("OO", m_pConnection, m_Data);
		Callback(pParams);
		Py_XDECREF(m_Data);
