Solved: Strange dzVents error
heggink
Domoticz version: 12451
Post by heggink »
A whole lot of errors in the log as follows:
2017-12-14 05:08:20.092 Error: dzVents: Error: There is no last update info for
with no device mentioned
2 scripts seem to cause it which are quite similar:
        active = true,
                devices = { 'HS *' }
        execute = function(domoticz)
                local message
                local someone_home = 'Off'
                -- first filter on name staring with HS
                local homestatus = domoticz.devices().filter(function(device)
                        local name = device.name
                        return (string.sub(name,1,3) == 'HS ')
		end)
                -- then loop over the results
                homestatus.forEach(function(sensor)
			if (sensor.state == 'On') then
                                someone_home = 'On'
		end)
                if (someone_home == 'On') then
                        domoticz.devices('SomeoneIsHome').switchOn()
                        domoticz.devices('SomeoneIsHome').switchOff()
What am I doing wrong here?
H
Last edited by heggink on Thursday 14 December 2017 19:58, edited 1 time in total.
P1 meter & solar panel
dannybloe
Re: Strange dzVents error
Post by dannybloe »
Nothing.. it's a bug somewhere in the eventsystem that we will be fixed when we finalize dzVents 2.4.
heggink
Post by heggink »
Ah, great. I was going bonkers over this :-)
heggink
Re: Solved: Strange dzVents error
Post by heggink »
@dannybloe: what's the planning on that?
