Ok I'v made it to start recognized the device.
What I did is:
1. I have added fgt001.xml and manufacture_specyfic.xml on the right places (My was /home/pi/domoticz/Config /home/pi/domoticz/Config/fibaro)
2. Now I check what changed into file manufacture_specyfic.xml from the previous one. since I have OpenZWave USB
Version: 1.4-2713-ge2021e46-dirty it's quite a lot
. So I added the missing files configuration from other manufactures. Im avoiding sytuations where I dont have config for others.
3. Now it's very simple. Restart domoticz does not do the thing! If you previously recognazied wrong your device. What you must to do is go to the
SETUP/HARDWARE ->your controler setup and then on your nodes go to your nodes managments and include the node
(CHECK PICTURE BELOW)
- 12222.png (51.41 KiB) Viewed 5985 times
That's it!!!!!
