new zwave plus thermostat valves
micha_pr
Re: new zwave plus thermostat valves
Post by micha_pr »
ropske wrote: Saturday 09 December 2017 9:41 thanks, i got them working now :D
Really? And you can set the temperature? Setpoint? And room temperature will be reported?
Michael Pruefer
http://www.zwave-review.com (German only)
http://www.SmartHome.Work (German only)
ropske
Domoticz version: V3_8394
Post by ropske »
That is correct, setpoint is working, so if i set setpoint at 20° for example and i go to the valve and check it, it is at 20° .
Also if i set the valve directly at 21° for example and i check domoticz, the value has changed to 21°
Room temperature is also working, standardly it is set at 5 => to send updated value of changement of 0.5°C
But i changed it to 3 => 0.3°C
micha_pr
Post by micha_pr »
Can you please add the information what Domoticz / OpenZwave version you are using? Will be helpful for other users where it was not working before.
Thanks for reporting!
Michael Pruefer
ropske
Post by ropske »
ok, my Domoticz version: V3.8720
OpenZwave version: Version: 1.4-2713-ge2021e46-dirty
i000
Post by i000 »
MrPozor wrote:These new Fibaro Heat Controllers look really great. They are expensive but if you look at the features and the design, it could be justified. Looks like they put a lot of thought into the design of the product.
I have ordered one to test. Should arrive next week and I will report back.
Thanks Pozor, we wait your comments!
brommetje
Post by brommetje »
@ropske can you please share your eur_spiritz.xml and from your manufacturer_specific.xml that you added or changed.
So I can try to make it work if have the same OpenZwave version: Version: 1.4-2713-ge2021e46-dirty
Thanks.
ropske
Post by ropske »
brommetje wrote:@ropske can you please share your eur_spiritz.xml and from your manufacturer_specific.xml that you added or changed.
Thanks.
Ok, i will do this tonight when im back home.
ropske
Post by ropske »
hi,
put eur_spiritz.xml in /Config/eurotronic
this is the part of Eurotronic in my manufacturer_specific.xml:
<Manufacturer id="0148" name="EUROtronic">
<Product type="0001" id="0001" name="EUR_STELLAZ Wall Radiator Thermostat Valve Control" config="eurotronic/eur_stellaz.xml"/>
<Product type="0002" id="0001" name="EUR_COMETZ Wall Radiator Thermostat Valve Control" config="eurotronic/eur_cometz.xml"/>
<Product type="0003" id="0001" name="EUR_SPIRITZ Wall Radiator Thermostat Valve Control" config="eurotronic/eur_spiritz.xml"/>
</Manufacturer>
After this is done/added, i restarted my domoticz and waited 10minutes (so all existing nodes where found)
Then i started to include my eurotronic valves one by one.
I followed this method:
* insert the batteries
* go to the room where the valve needs to be mounted (but do not mount it yet!!)
* include the valve, when its included it will show the nodenumber, and after some seconds it will show again INS
* mount it on the radiotor and when this is done, press again the boost button so the valve will calibrate itself, when it is done calibrating, it will show the current setpoint and you are ready
(85.58 KiB) Downloaded 285 times
eur_spiritz.xml
(3.97 KiB) Downloaded 407 times
brommetje
Post by brommetje »
Thanks Ropske, ill will change the files tomorrow and if i'am lucky i received my spirit in one or two days.
Regards, Martin
barbaar
Post by barbaar »
MrPozor wrote: Friday 08 December 2017 10:52 These new Fibaro Heat Controllers look really great. They are expensive but if you look at the features and the design, it could be justified. Looks like they put a lot of thought into the design of the product.
I'm getting mine tomorrow. Hope they work way better that the Danfoss LC13!
ropske
Post by ropske »
brommetje wrote: Monday 11 December 2017 22:16 Thanks Ropske, ill will change the files tomorrow and if i'am lucky i received my spirit in one or two days.
Regards, Martin
ok, if you need help just ask ;)
brommetje
Post by brommetje »
Ropske rececived my spirit thermostat, how many devices do you see?
I expected also a temperature device (temperature in The room) I this right?
Which devices do you have?
Martin
ropske
Post by ropske »
There is a valve temperature meter, i see your id is 0D
Check your complete devices, there be somewhere a temperature device with 0D wit with less 000
ropske
Post by ropske »
For example, my ID for this valve is 15
as you can see a temp device is added with ID: 1501
2017-12-21 17_34_51-Microsoft Edge.jpg (35.07 KiB) Viewed 4110 times
micha_pr
Post by micha_pr »
@ropske: Can you try the "open window detection" with your installation?
1) set in config the "Open Window Detection" to "3" (high sensibility) (maybe check in OZW panel)
2) set thermostat in heating mode - as sample 22 degree
3) open window
-> After some seconds the Thermostat will go to "OFF"
(Please check - will it be changed in Domoticz? - I think yes)
4) close window
5) After some time Thermostat will go back to heating mode
-> What about Domoticz state? Will it be changed back?
It would be important for scripting / scenes...
Thanks for testing!
Michael Pruefer
Robert
Post by Robert »
Hi everyone.
I purchased 4 Spirits Eurotronic thermostat valves and managed to include them.
First issue is the Temp. reading. Room became 22 degrees celsius while the thermostat showed 19,5 degrees. The setpoint was 20 degrees.
I decreased the MeasuredTempReport from 5 to 3, but even then no accurate reading. I'm trying to set 2 and see if this threshold works better.
Had any of you any trouble with the setpoint compared with room temp.?
Does any of you played with the ValveopenReport setting? Is i possible to request valve condition?
I had also timeout of my thermostat valves. changing setpoint will update the zwave communication. This seems logic because non of my settings had changed in 2 days.
Hope to hear your experience :-)
Merry christmas !!
ropske
Post by ropske »
'Room temperature' is actually the temperature of the valve.
I actually mostly never use the 'valve temperature' i use another temperature sensor, for example the fibaro motion sensor or the fibaro smoke sensor, both have temperature sensors in it.
ryen
Domoticz version: 3.8153
Post by ryen »
I have installed a Eurotronic spirit. I updated and added the configuration files as instructed by ropske in this thread. Including and installing went without problems.
I have a problem, though. I can set the heating and economy temperatures, and I can read the valve temperature. However, I can't switch between these.
I have a Thermostat Mode device, but this doesn't seem to do anything. I can switch modes in the Hardware settings of my Z-wave USB stick, so the hardware is working.
Any ideas?
Anyway, have a nice new year's eve and a happy new year! :)
Screen Shot 2017-12-31 at 14.51.52.png (107.07 KiB) Viewed 3820 times
ropske
Post by ropske »
sorry for the late response, i dont use the thermostat modes actually, mine is Always on Heat mode.
juste take caution, the thermostat setpoints are from 8°C - 28°C
i also have some popp thermostats and these are from 4°C - 28°C
ryen
Post by ryen »
Thanks, Ropske. This solution works and is acceptable. I hope a future upgrade will make switching between modes possible. I am switching between 18 and 24 degrees, so no problem with the range.
