dzVents.lua has been running for more than 10 seconds
poudenes
Domoticz version: 3.8993
Post by poudenes »
Hi All,
Suddenly i got this error msg:
Didn't change anything. All scripts work great.
Only update to latest beta Domoticz V3.8771
Does someone have same issues or any idea to solve this?
Already disable almost all dzvents scripts to see if this was the problem.
Didn't solve. Disabled the dzvents script at all and msg is gone.
Checked the USB stick and get this problem. Can this be the problem that i get the above error?
root@raspberrypi:~# fsck /dev/sda1
fsck from util-linux 2.25.2
fsck.fat 3.0.27 (2014-11-12)
0x41: Dirty bit is set. Fs was not properly unmounted and some data may be corrupt.
1) Remove dirty bit
2) No action
? 2
EddyG
Re: dzVents.lua has been running for more than 10 seconds
Post by EddyG »
Simpel check: remove the dirty bit by selecting option 1.
poudenes
Post by poudenes »
tried but after reboot its still there
dannybloe
Post by dannybloe »
Are you doing http requests in one of your scripts. Clearly one of your scripts doesn't end.
poudenes
Post by poudenes »
Sorry for late reply:
In Some events i have this :
os.execute('/home/pi/domoticz/scripts/Peter/speech.sh Someone arrive. Scene Evening activatedf')
This let domoticz speak :) Maybe this is the problem. Have it in many events :)
dannybloe
Post by dannybloe »
yes, that is very likely the problem. Maybe you should detach the process immediately when executing. I believe you can add a & to the command:
os.execute('/home/pi/domoticz/scripts/Peter/speech.sh "Someone arrive. Scene Evening activatedf" &)
poudenes
Post by poudenes »
I update the events and see if this solve the problem. Thanks again !!
dpcreel
Post by dpcreel »
I know this is late but I haven't checked Domoticz in a while.
I had this issue several months ago. After checking all of my scripts and disabling and enabling each individual script to find the culprit, nothing was positive. I even replaced the sd card on the PI, no help. What I ended up doing to resolve the situation was deleting the Domoticz database and starting over from scratch. It was a pain but no more errors.
Not sure if this helps but this was my experience. I am using domoticz beta on a headless PI3 with an sd card.
