Control Your Harmony Hub with Domoticz (RaspberryPi (Linux))
Dynamic
Re: Control Your Harmony Hub with Domoticz.
Post by Dynamic »
Bought an Harmony too! Really nice piece of equipment....
Derik
Post by Derik »
Yep...
Realy Nice toy, and is working perfect!!!.
Missing so far a lot of icoons ..
Wacht movie, listen music, play games..
When there are more icoons for beautiful things would be nice
For other things, Phone, home or not ...
And what ever the options are.
drogert
Post by drogert »
Yep, I want one! 8-)
RPI 3b+, PiFace 2, RFcom, Aeon Zwave USB, Aeon Home Energy Meter Gen 5, several Shelly switches, several ESP8266 sensors.
mbliek
Post by mbliek »
You can find icons at: https://www.iconfinder.com
Derik
Post by Derik »
New topic?
How to add a new icon?
I see a lot of options for me...
Only how... :cry: :cry:
gb160
Post by gb160 »
Hi there, hoping someone can help a noob with what I'm hoping is a really stupid question.
I'm running Domoticz on a raspberry pi, I've got my lights and central heating all working and can operate my harmony hub with no issues.
i have an air conditioner operated via the harmony hub, however it only has one power button, the same o button turns it on and off.
I've got the switch setup so that it operates ok, on turns it on, off turns it off.
However I've set up a scene called bedtime that switches all my lights off in the lounge, turns the air conditioner off, and turns on the bedroom lights.
The issue is, when i go to bed, the air con gets turned on if it is currently off....if the air con is running when i hit the bedtime scene, it turns off correctly.
Im banging my head against the wall as i can't see a solution....anyone ???
Raspberry Piet
Post by Raspberry Piet »
gb160 wrote:Hi there, hoping someone can help a noob with what I'm hoping is a really stupid question.
A toggle is a really bad thing for use in home automation.
You need discrete on & off infrared codes.
You can contact logitech and ask them for it or contact the manufactury of the airconditioning.
You also might look here:
http://files.remotecentral.com/library/3-1/index.html
Or make a bash/lua bedtime_script that will send IR signal only if status is on.
gb160
Post by gb160 »
Many thanks for replying....and I thought that was the case,I don't think there's any chance to get the discreet codes for the device so I have been 'attempting' to use the bash method with a php script to check the current switch status, but with my limited programming skills this is proving a bit tricky !!
I didn't think it would be so difficult to do something as simple as "if device is on, do not send on command"....is this explained in more detail anywhere?
Raspberry Piet
Try this:
mkdir /home/pi/domoticz/scripts/bash
touch /home/pi/domoticz/scripts/bash/AC_Off.sh
chmod +x /home/pi/domoticz/scripts/bash/AC_Off.sh
nano /home/pi/domoticz/scripts/bash/AC_Off.sh
Put this in your AC_Off.sh script:
#!/bin/bash
DOMO_IP="127.0.0.1"
PORT="8080"
idx_AC="14"    #Air Conditioner idx number
curl -s "http://$DOMO_IP:$PORT/json.htm?type=devices&rid=$idx_AC" | grep "Status" | grep "On"
    if [[ $? -eq 0 ]] ; then
		   	echo "Air Conditioner is on, let's turn it off"
			curl -s "http://$DOMO_IP:$PORT/json.htm?type=command&param=switchlight&idx=$idx_AC&switchcmd=Off&level=0"
			echo "Air Conditioner is allready off"
    fi
Invoke your AC_Off.sh through your domoticz bedtime scene => Edit=> Off Action: script://home/pi/domoticz/scripts/bash/AC_Off.sh
markk
Post by markk »
I would love to be able to integrate my Harmony Hub with Domoticz but I'm running mine on a windows PC. The wiki only explains how to do it with a Pi. Any help would be much appreciated. Thank you.
gb160
Post by gb160 »
Raspberry Piet wrote: Invoke your AC_Off.sh through your domoticz bedtime scene => Edit=> Off Action: script://home/pi/domoticz/scripts/bash/AC_Off.sh
Mate, thanks so much for taking the time to help me, I've followed every stage to perfection , but for some reason, the AC_Off.sh is not being triggered when i enter bedtime scene.
When i run the script from the command line, it works perfectly....if the AC is on it gets turned off, If the AC is off it stays off...but no joy if i select the scene from the gui :(
I feel frustrated right now because it seems like this solution is 99% complete....just need to get that script to trigger.
Is there any reason you're aware of that would stop this script triggering?
Is there any sort of log that i can view which might help?
Again...thanks for assisting me.
Update....Its working, no idea why, it just started working.Thanks
As far as the harmony control is concerned this works a treat, my only wish would be for domoticz to be updated if I switch activity via my harmony remote, like the ios app does, apart from that it works perfectly.
markk
Post by markk »
markk wrote:I would love to be able to integrate my Harmony Hub with Domoticz but I'm running mine on a windows PC. The wiki only explains how to do it with a Pi. Any help would be much appreciated. Thank you.
Sorry to bang on about this again but I would really appreciate a pointer in the right direction on this please. The wiki gives instructions for installing on a Pi but I'm running Domoticz on windows. I'm stuck here:
mbliek
Post by mbliek »
Take a look here:
http://sourceforge.net/projects/harmony ... rce=navbar
You need Microsoft Visual Studio 2010 on you windows PC.
Don't know how to install this and how to use it with domoticz, sorry
markk
Post by markk »
mbliek wrote:Take a look here:
Thanks v much for the pointer.
joske522
Re: Control Your Harmony Hub with Domoticz (RaspberryPi (Lin
Post by joske522 »
Hi guys,
I'm stuck :(
Did everything in the wiki, but the last step gives me following error:
make: cc: Command not found
make: *** [HarmonyHubControl.o] Error 127
This happens when I execute: make HarmonyHubControl
Any ideas how I can work around this?
gb160
Post by gb160 »
joske522 wrote:Hi guys,
I'm stuck :(
I'd try the native support first...although I can't get it working on the Pi, others seem to have it working on other platforms.
http://www.domoticz.com/forum/viewtopic.php?f=4&t=3311
mbliek
Post by mbliek »
I'm stuck :(
You ned to install GCC on your raspberry.
Please use google on how to do that.
joske522
Post by joske522 »
Allright, it worked with the native support in the beta build! 8-)
Thanks guys! I tried installing the GCC first but my head started spinning and I don't really know which procedure to folluw with all the different builds and versions...
Do I need it for something else?
gb160
Post by gb160 »
joske522 wrote:Allright, it worked with the native support in the beta build! 8-)
Is this on the pi mate?...glad to hear it works for you.im having no luck with native support though :( seems to work ok for about two or three switches
Which beta version are you using ?
I've had to revert to the old method, it's very reliable, only drawback is that domoticz doesn't update if I switch the harmony from the remote, I can live with it though...I'd really like to get this native support working though.
mbliek
Post by mbliek »
Domoticz should update the switch when using the remote. Take a look at the wiki page again.
There is a script that checked every 10 min for an active activity.
