Dashticz - Bug report
Locked
aiolos
Domoticz version: stable
Re: Dashticz - Bug report
Post by aiolos »
I think some default styling for images instead of icons is missing then. There have been changes in those parts and I don't have images as icons, so I didn't really notice
Contributor to Dashticz
More on my Github profile
blacksn0w
Post by blacksn0w »
EdwinK wrote: Thursday 23 November 2017 12:16 Screen Shot 2017-11-23 at 12.15.02.pngNow I've got this little problem. Not to serious, just need to resize them myself ;)
Got the same, since im using the .svg resizing is not easy possible.
aiolos
Post by aiolos »
I created the fix for this, I expect it to be merged soon.
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
Merged :)
EdwinK
Post by EdwinK »
Thanks Rob and aiolos
you rock
htilburgs
Post by htilburgs »
In the latest beta, Dashticz won't load correct / complete in IE11.
Missing a lot of switches.
Error (in dutch):
SCRIPT5008: Ongeldige linkerkant van toewijzing (incorrect assigning on the left side)
main.js (1050,33)
line 1049 - 1051:
catch (err) {
             [html, addHTML] = handleDevice(device, idx);
For as far as I can find:
this is a Illegal assignment (JavaScript)
You attempted to assign a value to a read-only identifier. You cannot assign a value to a read-only identifier. For example, host defined objects and external COM objects. To correct this error --> Do not assign values to read-only identifiers.
Hardware:
htilburgs
Post by htilburgs »
htilburgs wrote: Friday 01 December 2017 12:07 In the latest beta, Dashticz won't load correct / complete in IE11.
Error (in dutch):
main.js (1050,33)
line 1049 - 1051:
catch (err) {
Tried it also on Microsoft Edge, same problem.
In my case my dashboard is on a Microsoft Surface RT (windows 8.1), that only supports Edge and IE11
Hardware:
aiolos
Post by aiolos »
htilburgs wrote: Friday 01 December 2017 16:16
Error (in dutch):
main.js (1050,33)
line 1049 - 1051:
catch (err) {
On IE11 I can reproduce it, on Edge it works (but that's windows 10, so that might be different.) What version of Edge do you use? (I testen on Edge 38)
It is easy to fix, but problems like this are more likely to happen if we want to use the functions of the newer Javascript versions. IE11 is a bit getting the new IE6...
htilburgs
Post by htilburgs »
I can't find the version of Edge on the Windows Surface RT. Even don't know if its the real Edge or just IE11 in another look.
For IE:
11.0.9600.18838
Update: 11.0.48 (KB4047206)
It would be disappointing if we could'nt use IE11 as browser for Dashticz.
Hardware:
aiolos
Post by aiolos »
You can find the version on https://www.whatismybrowser.com/
And yes, it would be disappointing if it doesn't work in IE anymore, but on the other hand: it is an old browser and edge is now the one to use (if you are required to use a Microsoft browser). Nevertheless this needs to be fixed, but there might be a moment where it won't be, since the new javascript functions can make the code much more readable and faster. (it's a pity Microsoft still supports IE, it would be better if they drop it completely and fully focus on Edge).
htilburgs
Post by htilburgs »
But for now, can you fix it? So I can update my dashboard with te latest settings.
Hardware:
aiolos
Post by aiolos »
Yes, a PR is waiting to be merged. But I'm also still wondering what Edge version also causes this problem.
robgeerts
Post by robgeerts »
Merged, check latest beta!
MariH
Post by MariH »
Latest Beta is not working correctly with groups/scene's
Activating this code in CONFIG.js:
blocks['s1'] = {}
blocks['s1']['width'] = 4;
blocks['s1']['title'] = 'Zitkamer';
blocks['s1']['hide_data'] = true;
will not send an 'ON' or 'OFF' command to 'group 1' but to 'switch 1'
this it out the domoticz logging:
2017-12-03 15:39:24.286 User: Admin initiated a switch command (1/Weer: Luchtdruk/Off)
status is reflected OK
this use to work in earlier versions
Hardware
1x Raspberry Pi 3
1x RaZberry2 Z-Wave Plus
1x SolarEdge convertor
1x FGBS-001 Binaire Sensor
2x FGK-101 Door sensor
1x Logitech Harmony Hub
1x Sony Bravia TV
31x FGS-221 Double Relay Switch
2x Danfoss LC0013
aiolos
Post by aiolos »
MariH wrote: Sunday 03 December 2017 15:48 Latest Beta is not working correctly with groups/scene's
Good find! The big cleanup a few weeks ago caused this. I pushed a fix for it, which Rob will merge very soon I think.
robgeerts
Post by robgeerts »
Merged!
Check out latest beta!
aiolos
Post by aiolos »
robgeerts wrote: Sunday 03 December 2017 20:11 Merged!
You're just waiting for my pull requests all day, aren't you?
MariH
Post by MariH »
Guys,
thx for the quick fix, works as a charm!
Hardware
1x Raspberry Pi 3
1x Sony Bravia TV
2x Danfoss LC0013
robgeerts
Post by robgeerts »
aiolos wrote: Sunday 03 December 2017 20:12
Yes, I've nothing better to do ;)
No, I got notifications about new mail on my devices, as my laptop is almost always on I merge your request immediately :)
htilburgs
Post by htilburgs »
aiolos wrote: Saturday 02 December 2017 19:11 Yes, a PR is waiting to be merged. But I'm also still wondering what Edge version also causes this problem.
Aiolos, first thanx for the fix. It works like a charm again.
I'm using a Microsoft Surface RT Windows 8.1. I'm not sure it's EDGE that is installed. Maybe it's just an other way to show IE11 on the Windows 8.1 way.
I've been searching, but cannot find any version information.
Hardware:
Locked
