Scene as trigger not working
Kerel
Post by Kerel »
Guys, I have no clue what I am overlooking, but this is not working as expected:
This is my dzvents script:
	active = true, -- set to false to disable this script
		scenes = {
			'asdf'
	execute = function(domoticz, scene)
		print('test!')
When I call my scene, I'd excpect the string being printed in the logs, but it isnt:
2017-11-22 22:14:06.064 User: Admin initiated a scene/group command
2017-11-22 22:14:06.065 Activating Scene/Group: [asdf]
And thats it..
It works fine when using a device.
Anyone any luck with scenes as triggers?
lrybak
Re: Scene as trigger not working
Post by lrybak »
I have exactly the same issue.
I'm running stable v3.8153
HW: HP dc7900 USD running ESXi, RaspberryPi (few of it), AEON S2 USB stick, Fibaro modules (Dimmers, switches), 1-wire (DS18B20, DS2423), DSC Alarm with Envisalink ethernet module, MySensors, RFLink
lrybak
Post by lrybak »
Kerel wrote: Wednesday 22 November 2017 22:14 Anyone any luck with scenes as triggers?
Scripts are triggered correctly in dzVents 2.3.0 (v3.8551)
dannybloe
Post by dannybloe »
You need 2.3 for this. Time to upgrade :)
Kerel
Post by Kerel »
I'm using domoticz Version: 3.8153, which is the latest one.
How can I upgrade dzvents?
Kerel
Post by Kerel »
Ah, it's in the beta ;).
Kerel
Post by Kerel »
Updated to Version: 3.8755.
Re-ran the above script:
Still no luck:
2017-11-30 19:01:55.355 User: Admin initiated a scene/group command
2017-11-30 19:01:55.356 Activating Scene/Group: [asdf]
Other thoughts?
dannybloe
Post by dannybloe »
So, first of all, is dzVents enabled in the settings? If so, activate debug logging there and see what happens when you trigger the scene. You should see this in the logs: ''Event trigger type: scenegroup'. And a lot more that might indicate what's going wrong.
Kerel
Post by Kerel »
This seems rather strange:
Updated to the most recent beta version, but still seeing dzVents version 2.2.0..
dannybloe
Post by dannybloe »
That's strange indeed. Looks like a caching issue.
SweetPants
Post by SweetPants »
Hmmm, I'm on the same Beta version but no dzVents version on my screen (cleared both caches)
dannybloe
Post by dannybloe »
In the current beta you can check dzVents' version in Domoticz' about page.
Kerel
Post by Kerel »
Thanks for your help!
Managed to get it working by clearing caches before updating to the beta version.
Users browsing this forum: iw2fag and 1 guest
