Domoboard - Feature requests
Domoboard is a dashboard for Domoticz based on Python Flask.
Moderators: leecollings, wez3
Forum rules
Before posting here, make sure you are using the latest Beta or Stable version.
In order to fix issues or add features these have to be reported on the Domoboard Github pages.
This makes it possible to keep track of issues/features on a centralized place.
Refer to the issue of the github tracker when possible.
This subforum is meant to discuss issues and/or feature requests, or anything else related to Domoboard.
wez3
Post by wez3 »
This topic is used to discuss feature requests.In order to fix issues or add features these have to be reported on one of the the Domoboard Github pages:
https://github.com/wez3/domoboard
https://github.com/wez3/domoboard-plugins
wez3
Awst6000
Re: Domoboard - Feature requests
Post by Awst6000 »
Is it possible to get local raindata from buienradar and put the information in a bar graphic?
In this way we can see for the next half an hour if it is going to rain. (Subdivided by 5 minutes)
Here is a topic about a Python script.
http://www.domoticz.com/forum/viewtopic.php?t=13938
Awst6000
Post by Awst6000 »
Maybe create a default template with an embedded YouTube video to show the possibilities of Domoboard.
The video-URL itself preferrably defined in the *.conf file.
Something like viewtopic.php?f=66&t=15128&p=114888&hil ... be#p114888.
Txs.
squandor
Domoticz version: 3.5837
Post by squandor »
Jep we already did but for iframes. With the block plugin you can give an src URL and the plugin shows this as an template in domoboard :)!
But for YouTube it could be the same if we copy the block plugin and change the template to import an YouTube src
GuyTreepbush
Post by GuyTreepbush »
Would like to skip the login screen. Only users on my netwerk can access the page.
Alternatively do not require login each time on an iPad.
squandor
Post by squandor »
GuyTreepbush wrote:Would like to skip the login screen. Only users on my netwerk can access the page.
hmm i will look into that, i maybe found an solution for this without stripping the secure api requests.
squandor
Post by squandor »
Just created an feature to add autologon functionality to domoboard.
If you get the latest develop update you can add autologon to the domoboard section in general settings and add True or False like this:
  [[domoboard]]
    time = False			# True/False: show time in top bar
    date = False			# True/False: show date in top bar
    autologon = False 		# True/False: enable autologon
squandor
Post by squandor »
Awst6000 wrote:Hi,
Txs.
I tried this with the block plugin and you know what, it actually works instant :) you only need to add /embed/ to the youtube url like: https://www.youtube.com/embed/watch?v=lAsXqfzRiWQ
for example:
  [[block]]
  src = https://www.youtube.com/embed/watch?v=lAsXqfzRiWQ
Awst6000
Post by Awst6000 »
Great!
I think it is wise to add this to the default example.conf.
This weekend I'll try to get a default YouTube-playlist in Domoboard.
Awst6000
Post by Awst6000 »
Is it possible to change the background color of the dashboard?
Or to have a picture as background?
FuTuReD
Re: Domoboard - Feature requests - Thermostat button
Post by FuTuReD »
Now the thermostat is a slider in Domoboard. I want to have a + and - button. Is that possible?
Because a slider is not accurate enough to operate with touch.
I don't know how can I make this. Can someone help me?
thanks!
squandor
Post by squandor »
I think if you change the setpoint_slider to setpoint it should work and you will get en up and down option.
