Step by step guide: Sonos integration
- leecollings
Re: Step by step guide: Sonos integration
Yes, you can select just one speaker. Check out the documentation for the full list of commands you can use: https://github.com/jishi/node-sonos-http-api
E.g.
/{Room name}/clip/{filename}[/{announce volume}]
/clipall/{filename}[/{announce volume}]
Examples:
/clipall/sample_clip.mp3
/clipall/sample_clip.mp3/80
/Office/clip/sample_clip.mp3
/Office/clip/sample_clip.mp3/30
E.g.
Examples:
Heursqem
Works awesome, thanks!!!!leecollings wrote:Hey, you can already do this with the clipall command (if you want to play the announcement through all Sonos devices on your network).Heursqem wrote:This is what I would love to achieve
#1 - Someone pushes my doorbell
#2 - I capture the current state of my sonos player (medium, song, volume etc) and save this for later
#3 - I play my own sound through the sonos player (ding-dong)
#4 - I go back to to captured/saved state and listen to original music again
Would all of this be possible with this solution?
You can handle all of the above by using:(store your mp3 file in /static/clips/)Code: Select all
http://localhost:5005/clipall/name-of-your-mp3.mp3
junr
Sven,ironrider wrote:Hi,
i have to start server.js after a Domoticz reset.
Is ist possible to make the server.js running as a service.
Thanx
Sven
Go to the api directory
cd node-sonos-http-api Code: Select all
sudo pm2 start server.js Code: Select all
sudo pm2 save Code: Select all
Sudo rebootGreetz JUNR
RFXcom | Toon | Zware | Sonos |
RezzZ
Hi guys, I'm trying to get this working for my sonos system and got the api working.
problem now is to create that dummy device and switch:
I can create new hardware (1-Wire (System)) but it will not create any devices I can use for the selector.
What am I missing?
How do I create a dummy device? The device page doesn't allow me to create devices..9. Create a selector switch (create a dummy device and pick selector switch in the list of virtual devices ) according to the below images;
What am I missing?
junr
RezzZ
Create a Dummy switch in the hardware tab
Make a virtual sensor with Selector Switch.
in the device tab you select the dummy with
Hope it helps.
Greetz Junr
Hope it helps.
Greetz Junr
RezzZ
thanks Junr! I totally missed the dummy switch as a hardware device but it is really in the list...
thanks again!
thanks again!
RezzZ
any chance someone has already created a transparant icon set for sonos?
the file from dhanjel (posted 8-6-2016) has white corners, not transparant.
royson
Hi guys.
Im new here and have tried this great solution, but I have wierd problem.
Im running my domoticz installation with https and the switch sends commands in http. Not sure if this is the problem but it doesnt work. If I send the command directly in the browser with http it works, so the api is active. But if I use the exact same link on a selector in domoticz, nothing happends.
Which log can I start searching in for clues?
Thanks in advance for any help.
royson
Edit:royson wrote:Hi guys.
I figured it out. Nothing to do with the encryption fortunately. Domoticz just wasnt able to convert the space in "dining room". All sorted now =)
Next step is adding TTS.
Sent from my LG-H815 using Tapatalk
BakSeeDaa
Hi there!
I just had a look at the node-sonos-http-api. I haven't tried it yet, (still waiting for 2 pcs Sonos One to be delivered) but it looks really nice.
I also had a quick look at the LUA script in the initial post. It seems to be a device triggered script so it will run whenever a device changes in Domoticz. That can happen quite often and will put some burden on the Domoticz server for sure.
Looking a bit closer at node-sonos-http-api I see that there is support for a web hook. That sounds promising because using that, Domoticz wouldn't have to do polling the API for changes. Instead Domoticz can be "push noticed" whenever there is a status change. It should be much faster and more efficient than polling. One small problem is that Domoticz currently doesn't have a way to trigger a specific script using the API. Therefore to use the web hook functionality we'd need some software to interpret whats coming in and inform Domoticz about it. That wouldn't be so hard to do.
I've started a nodejs project to intercept events from node-sonos-http-api using web hooks and use them to inform Domoticz. I'll let you know when I have been able to test it in case someone is interested.
MiWa4711
I am a beginner started with domoticz 8 weeks ago. Now after all my lights are integrated I am looking for sonos.
Did installation following step by step guide but failed.
Can anyone please help me?
Thanks.
Thanks.
- npm_debug.log.JPG (68.16 KiB) Viewed 10438 times
- error2.JPG (35.79 KiB) Viewed 10438 times
- Error1.JPG (50.31 KiB) Viewed 10438 times
MiWa4711
Dear all,
now it runs. Juhu....
How you do it...i've got same problem !!!
EDIT: It's good for me.........It's alive !!!
AllesVanZelf
- Domoticz version: 12467
Heursqem wrote: Wednesday 31 May 2017 13:22But how could I store the actual state, so I can resume after the clipall command?leecollings wrote:Hey, you can already do this with the clipall command (if you want to play the announcement through all Sonos devices on your network).Heursqem wrote:This is what I would love to achieve
I noticed that this is not always working well. I have two sonos-speakers.leecollings wrote: Wednesday 31 May 2017 14:06 It stores the current state within the command. Try it out and you'll see.
I've tested it, with a Play 1 playing a song, it pauses, plays the mp3 file, and then resumes the previously playing song.
If I send a clipall command to the sonoses, the sounds plays well on both speakers, but afterwards the music does not continue where it was. I think the music starts on the playlist from one of the speakers, not always the right one.
But if I send the command to both speakers separately (two links), it works well.
Just for the record
It might be a coding error?
Gents, installed in on my Synology NAS, and can start / stop my Sonos speakers via the URL in my browser. But is doesn't start with the selector switch in Domoticz when im using the same url... Fout bij verzenden van schakelaar opdracht, controleer apparaat/hardware!
Anyone?
Anyone?
Holland
- Domoticz version: Beta Ch
@josimd
Should work. Can you share the url that you use to let it start playing
Thanks for reply;
in my browser: http://192.168.86.136:5005/woonkamer/play
(small think is when I use http://192.168.86.136:5005/woonkamer/pauze it doesn't stop)
and I use the same in Domoticz;
But then I get the error
Holland
The following url should be changed ;
to
http://192.168.86.136:5005/woonkamer/pause
What is the version of Domoticz you are running. Because, some time ago there were some issues with the selector switch. But that has been resolved.
to
I'm running on V4.9700 (synology)
Holland
Is new enough.
Can you check again, if your setup similar to the below;
- Capture.JPG (211.13 KiB) Viewed 8650 times
