if you follow the wiki, you should be able to find enough information to install it.
Python Plugin: Samsung TV
- Domoticz version: 4.10159
Re: Python Plugin: Samsung TV
it's very difficullt for me by this wiki, i'm a newbie....can you help me ?
Domoticz on AsRock j3455-ITX 8gb ram - Aeotec ZWave Usb Stick - RFLink 433Mhz
1x Fibaro Wall Plug
1x Fibaro Motion Sensor
x NeoCoolcam Wall Plug
Netatmo Weather Station - Netatmo Thermostat
Philips Hue Bridge
1x Fibaro Wall Plug
Philips Hue Bridge
- Domoticz version: V2024.4
Sorry do not have linux.. but in domoticz wiki & google etc... you should be able to find all necessary.
just to start:
https://www.digitalocean.com/community/ ... untu-16-04
http://www.domoticz.com/wiki/Using_Python_plugins
just to start:
Can anyone explain step to step how to install this plugin (ubuntu 17.04)?
1x Fibaro Wall Plug
Philips Hue Bridge
1x Fibaro Wall Plug
Philips Hue Bridge
- Domoticz version: 2020.1
I hope someone van help me out, since following the wiki and solutions in this thread didn't work for me.
when i run the command: samsungctl -i --host 192.168.1.26 --method websocket, I get:
I tried running the command: sudo cp -r /usr/local/lib/python3.4/dist-packages/samsungctl/ /usr/lib/python3.4/, but that doesn't change a thing
I can see I have to versions of Python. /usr/local/lib shows:
drwxrwsr-x 4 root staff 4096 Jul 5 12:49 python2.7
drwxrwsr-x 3 root staff 4096 Aug 2 15:33 python3.4
I really hope someone can help me out to get to the next step of controlling my samsung tv
File "/usr/local/bin/samsungctl", line 9, in <module>
load_entry_point('samsungctl==0.6.0', 'console_scripts', 'samsungctl')()
File "/usr/local/lib/python2.7/dist-packages/samsungctl/__main__.py", line 93, in main
config = _read_config()
File "/usr/local/lib/python2.7/dist-packages/samsungctl/__main__.py", line 37, in _read_config
except FileNotFoundError:
NameError: global name 'FileNotFoundError' is not defined
samsungctl require python 3. just try install it using e.g. : sudo pip3 install samsungctl
When i try to do that I get the message it's already installed:
Requirement already up-to-date: samsungctl in /usr/local/lib/python3.4/dist-packages
if you take a look to your output log :
This look like samsungctl has been installed under 2.7 environnment, uninstall it and install it with pip3.
the same for others modules.
Hi, new to this forum. Or at least posting something on itgijsje wrote: ↑Tuesday 17 October 2017 0:06 i do have the plugin.py in the folder plugins/samsungctl did try also to change the folder to SamsungTV and Samsung TV without suc6
also checked if /usr/lib/python3.5/samsungctl/remote.py and /usr/lib/python3.5/samsungctl/remote_websocket.py are there and they are
If i restart domoticz i do getif i try button mute i get2017-10-16 23:44:03.107 Error: (Samsung TV) 'onStart' failed 'ImportError'.
2017-10-16 23:44:03.107 Error: (Samsung TV) ----> Line 134 in /home/pi/domoticz/plugins/SamsungTV/plugin.py, function onStart
2017-10-16 23:44:03.107 Error: (Samsung TV) ----> Line 287 in /home/pi/domoticz/plugins/SamsungTV/plugin.py, function SamsungSend
2017-10-16 23:44:03.107 Error: (Samsung TV) ----> Line 10 in /usr/lib/python3.5/samsungctl/remote.py, function __init__
2017-10-16 23:44:03.107 Error: (Samsung TV) ----> Line 13 in /usr/lib/python3.5/samsungctl/remote_websocket.py, function __init__I do have a K series tv so maybe it does not work ue49ks7000s017-10-16 23:47:51.587 User: Admin initiated a switch command (117/Samsung TV - Volume/Set Level)
2017-10-16 23:47:51.619 (Samsung TV) Calling message handler 'onCommand'.
2017-10-16 23:47:51.619 (Samsung TV) onCommand called for Unit 3: Parameter 'Off', Level: 0, Connected: True
2017-10-16 23:47:51.621 Error: (Samsung TV) 'onCommand' failed 'ImportError'.
2017-10-16 23:47:51.621 Error: (Samsung TV) ----> Line 182 in /home/pi/domoticz/plugins/SamsungTV/plugin.py, function onCommand
2017-10-16 23:47:51.621 Error: (Samsung TV) ----> Line 287 in /home/pi/domoticz/plugins/SamsungTV/plugin.py, function SamsungSend
2017-10-16 23:47:51.621 Error: (Samsung TV) ----> Line 10 in /usr/lib/python3.5/samsungctl/remote.py, function __init__
2017-10-16 23:47:51.621 Error: (Samsung TV) ----> Line 13 in /usr/lib/python3.5/samsungctl/remote_websocket.py, function __init__
if i do samsungctl --host 192.168.0.112 --method websocket KEY_VOLUP that is working also samsungctl --host 192.168.0.112 --method websocket KEY_MUTE
I have the exact same issue. Everything works through the command line, but in Domoticz it does not work and gives the same errors.
I also have a Samsung KS7000 TV.
Does anyone have the solution?
verify that you have websocket under /usr/lib/python3.5/
if not, copy it could help.
Ik ben inmiddels weer een paar stappen verder. Het bleek dat in de config file verwezen werd naar de 0.6.0. versie ipv de 0.7.0 versie. Dit heb ik handmatig aangepakt waarna de onderstaande foutmelding is verdwenen
Echter, als ik het commando 'samsungctl -i --host 192.168.1.26' geef dan krijg ik 'Error: Connection refused'
Bij 'samsungctl -i --host 192.168.1.26 --method websocket' krijg ik: 'Error: Operation now in progress'
Op mijn tv heb ik geen popup gezien of ik toestemming wilde geven en ook in de device lijsten op de tv zie ik niets geblokt. Momenteel is alleen in deze device lijst mijn telefoon verbonden met de televisie.
Model tv wat ik heb is de SAMSUNG UE48J6200
I had the same issue when I upgraded to 0.7.0, could not find out why. So I downgraded to 0.6.0 and could connect through command line. But still nothing through Webinterface. Will double check everything tonight, but I think everything is okay.desertdog wrote: ↑Wednesday 22 November 2017 10:32 Ik ben inmiddels weer een paar stappen verder. Het bleek dat in de config file verwezen werd naar de 0.6.0. versie ipv de 0.7.0 versie. Dit heb ik handmatig aangepakt waarna de onderstaande foutmelding is verdwenenEchter, als ik het commando 'samsungctl -i --host 192.168.1.26' geef dan krijg ik 'Error: Connection refused'Code: Select all
2017-10-16 23:44:03.107 Error: (Samsung TV) 'onStart' failed 'ImportError'. 2017-10-16 23:44:03.107 Error: (Samsung TV) ----> Line 134 in /home/pi/domoticz/plugins/SamsungTV/plugin.py, function onStart 2017-10-16 23:44:03.107 Error: (Samsung TV) ----> Line 287 in /home/pi/domoticz/plugins/SamsungTV/plugin.py, function SamsungSend 2017-10-16 23:44:03.107 Error: (Samsung TV) ----> Line 10 in /usr/lib/python3.5/samsungctl/remote.py, function __init__ 2017-10-16 23:44:03.107 Error: (Samsung TV) ----> Line 13 in /usr/lib/python3.5/samsungctl/remote_websocket.py, function __init__
Where did you find the config file for redirection of the version number?
I use python3.4 (quote was from another user). But yes, the directories are copied to /usr/lib/python3.4/
samsungctl and websocket both together
Everything works seemles with the command line, but in Domoticz I get these errors when controlling volume for example....
Can anybody help me out or point me in some direction?
2017-11-22 20:59:06.099 Error: (TV) 'onCommand' failed 'ImportError'.
2017-11-22 20:59:06.099 Error: (TV) ----> Line 170 in /home/pi/domoticz/plugins/SamsungTV/plugin.py, function onCommand
2017-11-22 20:59:06.099 Error: (TV) ----> Line 287 in /home/pi/domoticz/plugins/SamsungTV/plugin.py, function SamsungSend
2017-11-22 20:59:06.099 Error: (TV) ----> Line 10 in /usr/lib/python3.4/samsungctl/remote.py, function __init__
2017-11-22 20:59:06.099 Error: (TV) ----> Line 13 in /usr/lib/python3.4/samsungctl/remote_websocket.py, function __init__
2017-11-22 20:59:06.099 Error: (TV) ----> Line 22 in /usr/lib/python3.4/websocket/__init__.py, function
2017-11-22 20:59:06.099 Error: (TV) ----> Line 26 in /usr/lib/python3.4/websocket/_abnf.py, function
edit: figured it out!
When checking status of websocket-client I saw that six.py is required.
Six was always installed, but in a previous python environment.
Solution: copy six.py to right directory, in my case:
cp -r /usr/lib/python3/dist-packages/six.py /usr/lib/python3.4
thanks @Jostice that should help others
hi guys,
i am a month tring to install samsungtcl but omg guide is not clear.
i installed samsung tcl
ok then (by guide)
ok i understand that path is 3.5 but 3.5 folder dist-packages is empty (there isn't samsungctl)
look /usr/local/lib/python3.4/dist-packages/samsungctl/ and it's empty.
i don't understand why....
python3 -V give me 3.5.2
:-$ samsungctl -version
samsungctl 0.7.0
File or directory not exist
1x Fibaro Wall Plug
Philips Hue Bridge
1x Fibaro Wall Plug
Philips Hue Bridge
@dextm80
there is lots os different configuration possible.
all need to be adapted at your env.
in your case, looks like you have python 3.5, so path should be /usr/lib/python3.5/ (need to be verified)
And as you use linux, probably python 2.7 is also installed and you need to use pip3 instead pip.
i've xubuntu 16.04 and i ve py 2.7 and py 3.5 path installedzak45 wrote: ↑Monday 27 November 2017 20:07 @dextm80
i use pip3 but nothing change, can you guide me?
1x Fibaro Wall Plug
Philips Hue Bridge
1x Fibaro Wall Plug
Philips Hue Bridge
Check also the folder site-packages in your python3.5 folder, could be it's installed there...dextm80 wrote: ↑Tuesday 28 November 2017 16:41i've xubuntu 16.04 and i ve py 2.7 and py 3.5 path installedzak45 wrote: ↑Monday 27 November 2017 20:07 @dextm80
i use pip3 but nothing change, can you guide me?![]()
so something like: /usr/local/lib/python3.5/site-packages/
- Domoticz version: 3.8153
I have exactly the same problem.Jostice wrote: ↑Wednesday 22 November 2017 19:03I had the same issue when I upgraded to 0.7.0, could not find out why. So I downgraded to 0.6.0 and could connect through command line. But still nothing through Webinterface. Will double check everything tonight, but I think everything is okay.desertdog wrote: ↑Wednesday 22 November 2017 10:32 Ik ben inmiddels weer een paar stappen verder. Het bleek dat in de config file verwezen werd naar de 0.6.0. versie ipv de 0.7.0 versie. Dit heb ik handmatig aangepakt waarna de onderstaande foutmelding is verdwenenEchter, als ik het commando 'samsungctl -i --host 192.168.1.26' geef dan krijg ik 'Error: Connection refused'Code: Select all
Do you you have it already fixed?
Users browsing this forum: FireWizard and 1 guest
