Dashticz - Module - Spotify (new version!)
Re: Dashticz - Module - Spotify
HI rob,
thanks a lot, it looks exactly like what I am looking for as I am new to this topic at all. I saw your dashboard on the first page of this thread, do you also have any help for creating such a nice dashboard for me? Are there any documents where I can find more infos on that? Where can I find the config.js file? I do not know that much yet, but I am still learning
Thanks!!
Thanks!!
Check wiki and other posts in the How to's topic. There are configs and js.
checked it, but not successfully. Do you have any direct links to the right infos?
There are lots of examples - check hidden code and build your own.
- Domoticz version: 3.7067
3 simple steps to get started:
1.) Download Dashticz from https://github.com/robgeerts/dashticz_v2/tree/master
2.) rename CONFIG_DEFAULT (in folder CUSTOM) to CONFIG.js
3.) Change IP in CONFIG.js to the right Domoticz-ip
How to edit your dashboard, check:
Wiki: https://www.domoticz.com/wiki/Dashticz_V2
Getting started topic: http://www.domoticz.com/forum/viewtopic ... 67&t=17426
And all other topics. If you have any further questions. Do not reply to this post but go to the General Discussions-topic:
http://www.domoticz.com/forum/viewtopic ... 67&t=16526
Earlier this day it worked, but now when I add the 'spotify' block to the collumn, all domoticz devices dissapear form the page. (and no spotify player)
WHen I delete the 'spotify' block from the column, the devices/buttons are back.
I did get the login page for the webplayer, and I am logged in succesfully.
Any idea where and how I can solve this?
(ps. latets beta dashticz)
You cannot right now, I have to fix this plugin
Will be a.s.a.p.
Will be a.s.a.p.
ah ok, didn't know it was a known issue.
i know i am doing somthing wrong but i dont know what i did wrong.
i have entered this in my config:
https://ibb.co/cWgRjw
when i add the following line:
my lights disaperes and there is nog plugin.
- Spoiler: show
- Spoiler: show
Please disable spotify, not working at the moment...
New version coming (although, very busy at the moment...)
status 21-1-2018: Just tried git pull as described on https://www.domoticz.com/wiki/Dashticz_ ... stallation to test the latest version: Spotify not working; domoticz devices do not loadJust wondering if you made already some progress.
best regards, Jeroenkl
Spotify not working correctly at the moment, the update of 21-1-2018 did not fix it yet
No, unfortunately not.... currently have some other things on my mind...
just to keep this wish alive....
- Domoticz version: Beta Ch
No progress ?
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Has it ever been a consideration to use another library instead of writing own http-calls? Something like
https://github.com/JMPerez/spotify-web-api-js
Thanks, will look after this tonight!
