Hi All,
Is it possible to change color to RGB(W(W)) bulbs using dzVents?
A way to control RGB(W(W))
poudenes
- Domoticz version: 3.8993
poudenes
Re: A way to control RGB(W(W))
find out that i can use this
hue i can select the color and brightness i can change the level of it
os.execute('curl "http://127.0.0.1:8081/json.htm?type=command¶m=setcolbrightnessvalue&idx=3&hue=18&brightness=50&iswhite=false"')RPi3 B+, Debain Stretch, Domoticz, Homebridge, Dashticz, RFLink, Milight, Z-Wave, Fibaro, Nanoleaf, Nest, Harmony Hub, Now try to understand pass2php
dannybloe
That's interesting. Are there more commands like these? Maybe useful to add this to the rgbw_device.lua adapter.
poudenes
You can also use this for kelvin leveldannybloe wrote: Wednesday 22 November 2017 8:17 That's interesting. Are there more commands like these? Maybe useful to add this to the rgbw_device.lua adapter.
http://127.0.0.1:8081/json.htm?type=command¶m=setkelvinlevel&idx=8&kelvin=10But for kelvin i created a dummy switch with 10 different kelvin levels :10, 20, 30, 40, 50, 60, 70, 80, 90, 100
The link i use in dzVents was needed to give my MiLight bulbs some color for specific action
BakSeeDaa
The FIBARO RGBW Controller has 5 nice animation programs built in that can be set using the Domoticz API URL.dannybloe wrote: Wednesday 22 November 2017 8:17 That's interesting. Are there more commands like these? Maybe useful to add this to the rgbw_device.lua adapter.
Predefined animation programs
6 = Fireplace
7 = Storm
8 = Rainbow
9 = Aurora
10 = LPD
As discussed here the idx parameter i the querystring is not the Domoticz device idx but a hidden "internal Z-wave device idx".
There are some oddities though. If you select an animation program and switch to solid light, it will not switch on the same animation program again (next time). That is, you'd have to turn on another animation program first (turn the animation program off first will also work). Another thing is that if you send several commands without a delay, the device will generate a z-wave timeout. If we use a short delay it will work, almost every time.
Below is an example dzVents script. In current dzVents version (2.3.1) we can not use delays for the openURL command. Thats why I use the function delayedOpenURL() in my script.
I've created a selector switch to trigger the script.
Level Level name
0 Off
10 Fireplace
20 Storm
30 Rainbow
40 Aurora
50 LPD
60 Solid REDCode: Select all
active = true,
logging = {
level = domoticz.LOG_DEBUG,
marker = 'RGBW'
devices = {
'RGBW Selector'
data = {
last_animation_program = {initial=0}
local RGB_ANIMATION_OFF = 0
local RGB_ANIMATION_FIREPLACE = 10
local RGB_ANIMATION_STORM = 20
local RGB_ANIMATION_RAINBOW = 30
local RGB_ANIMATION_AURORA = 40
local RGB_ANIMATION_LPD = 50
local RGB_DEV = 337
local RGB_ZW_INT_NODE = 75 -- See: https://www.domoticz.com/forum/viewtopic.php?t=8605
local function delayedOpenURL(url, delay)
delay = delay or 0
if delay == 0 then
domoticz.openURL(url)
domoticz.log('Requesting url '..url..' with a delay of '..tostring(delay)..' seconds', domoticz.LOG_DEBUG)
os.execute('(sleep '..delay..';curl -s "'..url..'" > /dev/null)&')
local function setRGBWAnimation(rgbAnimation)
-- Add the number 6-10 to query string, base64- and URL encoded
local url = domoticz.settings['Domoticz url']..'/json.htm?type=command¶m=applyzwavenodeconfig&idx='..RGB_ZW_INT_NODE..'&valuelist=72_'
local delay = 0
if rgbAnimation == domoticz.data.last_animation_program then
if rgbAnimation ~= RGB_ANIMATION_OFF then
delayedOpenURL(url..'MQ%3D%3D', 0) -- Switch off the animation program first
delay = 2
domoticz.data.last_animation_program = rgbAnimation
if rgbAnimation == RGB_ANIMATION_OFF then
delayedOpenURL(url..'MQ%3D%3D', delay)
elseif rgbAnimation == RGB_ANIMATION_FIREPLACE then
delayedOpenURL(url..'Ng%3D%3D', delay)
elseif rgbAnimation == RGB_ANIMATION_STORM then
delayedOpenURL(url..'Nw%3D%3D', delay)
elseif rgbAnimation == RGB_ANIMATION_RAINBOW then
delayedOpenURL(url..'OA%3D%3D', delay)
elseif rgbAnimation == RGB_ANIMATION_AURORA then
delayedOpenURL(url..'OQ%3D%3D', delay)
elseif rgbAnimation == RGB_ANIMATION_LPD then
delayedOpenURL(url..'MTA%3D', delay)
local function setRGBWChannels(vBrightness, vHex)
local url = domoticz.settings['Domoticz url']..'/json.htm?type=command¶m=setcolbrightnessvalue&idx='..RGB_DEV..'&hex='..vHex..'&brightness='..vBrightness..'&iswhite=false'
if device.level <= 50 then
setRGBWAnimation(device.level)
setRGBWChannels(100, 'ff0000') -- Solid RED
}Who is online
