[REQUEST] Ikea Trådfri Gateway (smart lights hub controller) plugin?
Yossarian
Re: [REQUEST] Ikea Trådfri Gateway (smart lights hub controller) plugin?
Coap client v.0.4
Gateway Firmware just updated v.1.2.42
I run domoticz v3.8153
BTW, when i do
sudo service Ikea-tradfri statut
i get this error
ikea-tradfri.service - IKEA Tradfri COAP-adapter
Loaded: loaded (/lib/systemd/system/ikea-tradfri.service; enabled; vendor pre
Active: failed (Result: exit-code) since Fri 2017-11-17 18:45:45 CET; 21s ago
Process: 19395 ExecStart=/usr/local/bin/twistd --nodaemon --rundir=${IKEA_HOME
Main PID: 19395 (code=exited, status=217/USER)
nov. 17 18:45:45 raspberrypi systemd[1]: ikea-tradfri.service: Unit entered fail
nov. 17 18:45:45 raspberrypi systemd[1]: ikea-tradfri.service: Failed with resul
nov. 17 18:45:45 raspberrypi systemd[1]: ikea-tradfri.service: Service hold-off
nov. 17 18:45:45 raspberrypi systemd[1]: Stopped IKEA Tradfri COAP-adapter.
nov. 17 18:45:45 raspberrypi systemd[1]: ikea-tradfri.service: Start request rep
nov. 17 18:45:45 raspberrypi systemd[1]: Failed to start IKEA Tradfri COAP-adapt
but when i do
pi@raspberrypi:~ $ cd /home/pi/domoticz/plugins/IKEA-Tradfri
pi@raspberrypi:~/domoticz/plugins/IKEA-Tradfri $ /usr/local/bin/twistd -n -y tradfri.tac
I get
Removing stale pidfile /home/pi/domoticz/plugins/IKEA-Tradfri/twistd.pid
2017-11-17T21:26:47+0100 [-] Removing stale pidfile /home/pi/domoticz/plugins/IKEA-Tradfri/twistd.pid
2017-11-17T21:26:47+0100 [-] Loading tradfri.tac...
2017-11-17T21:26:49+0100 [-] Loaded.
2017-11-17T21:26:49+0100 [twisted.scripts._twistd_unix.UnixAppLogger#info] twistd 17.9.0 (/usr/bin/python3 3.5.3) starting up.
2017-11-17T21:26:49+0100 [twisted.scripts._twistd_unix.UnixAppLogger#info] reactor class: twisted.internet.epollreactor.EPollReactor.
2017-11-17T21:26:49+0100 [-] AdaptorFactory starting on 1234
2017-11-17T21:26:49+0100 [builtins.AdaptorFactory#info] Starting factory <AdaptorFactory object at 0xb6057930>
^C2017-11-17T21:27:05+0100 [-] Received SIGINT, shutting down.
2017-11-17T21:27:05+0100 [-] (TCP Port 1234 Closed)
2017-11-17T21:27:05+0100 [builtins.AdaptorFactory#info] Stopping factory <AdaptorFactory object at 0xb6057930>
2017-11-17T21:27:05+0100 [-] Main loop terminated.
2017-11-17T21:27:05+0100 [twisted.scripts._twistd_unix.UnixAppLogger#info] Server Shut Down.
I did change the pathin the ikea-tradfri.serice by changing /opt/... by /home/pi/...
BTW, when i do
i get this error
but when i do
I get
moroen
Is there a stale .pid file in the plugin-directory? If so, delete it before trying system again...Yossarian wrote: Friday 17 November 2017 21:29 Coap client v.0.4
BTW, when i do
i get this error
but when i do
I get
You might get more information if you run:
$ sudo journalctl -f -u ikea-tradfri
Regards,
M
Yossarian
I got my PSK while using the three port together instead one by one
coap-client -m post -u "Client_identity" -k "xxxxxxxxxxx" -e '{"9090":"Ikea"}' "coaps://192.168.1.95:5684/15011/9063"
Buuuuut, now i've got in domoticz log
2017-11-19 16:55:34.562 PluginSystem: Starting I/O service thread.
2017-11-19 16:55:34.562 (Ikea) Connect directive received, action initiated successfully.
2017-11-19 16:55:34.613 (Ikea) Calling message handler 'onConnect'.
2017-11-19 16:55:34.613 (Ikea) Failed to connect to IKEA tradfri COAP-adapter! Status: 111 Description: Connection refused
2017-11-19 16:55:36.520 (Ikea) Calling message handler 'onHeartbeat'.
2017-11-19 16:55:36.520 (Ikea) Not connected - nextConnect: 3
2017-11-19 16:55:38.526 (Ikea) Calling message handler 'onHeartbeat'.
2017-11-19 16:55:38.527 (Ikea) Not connected - nextConnect: 2
2017-11-19 16:55:40.533 (Ikea) Calling message handler 'onHeartbeat'.
2017-11-19 16:55:40.534 (Ikea) Not connected - nextConnect: 1
2017-11-19 16:55:40.534 (Ikea) Transport set to: 'TCP/IP', 127.0.0.1:1234.
No .pid filein IKEA-Tradfri folder
When i type
It returns
-- Logs begin at Thu 2016-11-03 18:16:44 CET. --
nov. 19 16:48:14 raspberrypi systemd[31591]: ikea-tradfri.service: Failed at step USER spawning /usr/local/bin/twistd: No such process
nov. 19 16:48:14 raspberrypi systemd[1]: ikea-tradfri.service: Main process exited, code=exited, status=217/USER
nov. 19 16:48:14 raspberrypi systemd[1]: ikea-tradfri.service: Unit entered failed state.
nov. 19 16:48:14 raspberrypi systemd[1]: ikea-tradfri.service: Failed with result 'exit-code'.
nov. 19 16:48:14 raspberrypi systemd[1]: ikea-tradfri.service: Service hold-off time over, scheduling restart.
nov. 19 16:48:14 raspberrypi systemd[1]: Stopped IKEA Tradfri COAP-adapter.
nov. 19 16:48:14 raspberrypi systemd[1]: ikea-tradfri.service: Start request repeated too quickly.
nov. 19 16:48:14 raspberrypi systemd[1]: Failed to start IKEA Tradfri COAP-adapter.
wich is weird as i have twistd already installed
When i type
$ sudo journalctl -f -u ikea-tradfrisudo journalctl -f -u ikea-tradfri
Yossarian
After restart
2017-11-19 17:19:01.709 (Ikea) Failed to connect to IKEA tradfri COAP-adapter! Status: 111 Description: Connection refused
then when i type
it shows
2017-11-19 17:19:07.635 PluginSystem: Starting I/O service thread.
2017-11-19 17:19:07.686 (Ikea) Connected successfully to: 192.168.1.95
2017-11-19 17:19:07.688 (Ikea) Received: b'{"version": "0.4", "status": "Ok", "action": "clientConnect"}'
2017-11-19 17:19:18.087 (Ikea) Received: b'{"error": "Connection timed out", "status": "Failed", "action": "setConfig"}'
2017-11-19 17:19:18.092 (Ikea) Command setConfig failed with error: Connection timed out.
2017-11-19 17:19:18.092 (Ikea) {'action': 'setConfig', 'status': 'Failed', 'error': 'Connection timed out'}
while i see in putty
2017-11-19T17:55:22+0100 [-] Loading tradfri.tac...
2017-11-19T17:55:25+0100 [-] Loaded.
2017-11-19T17:55:25+0100 [twisted.scripts._twistd_unix.UnixAppLogger#info] twistd 17.9.0 (/usr/bin/python3 3.5.3) starting up.
2017-11-19T17:55:25+0100 [twisted.scripts._twistd_unix.UnixAppLogger#info] reactor class: twisted.internet.epollreactor.EPollReactor.
2017-11-19T17:55:25+0100 [-] AdaptorFactory starting on 1234
2017-11-19T17:55:25+0100 [builtins.AdaptorFactory#info] Starting factory <AdaptorFactory object at 0xb6040910>
2017-11-19T17:56:21+0100 [stdout#info] Connected from IPv4Address(TCP, '127.0.0.1', 41152)
2017-11-19T17:56:57+0100 [-] Received SIGINT, shutting down.
2017-11-19T17:56:57+0100 [-] (TCP Port 1234 Closed)
2017-11-19T17:56:57+0100 [builtins.AdaptorFactory#info] Stopping factory <AdaptorFactory object at 0xb6040910>
2017-11-19T17:56:57+0100 [stdout#info] Disconnected
2017-11-19T17:56:57+0100 [-] Main loop terminated.
2017-11-19T17:56:57+0100 [twisted.scripts._twistd_unix.UnixAppLogger#info] Server Shut Down.
So,from what I understand (I don't know python at all ... and maybe I'm totally wrong
), I've got 2 problems :
1: my IKEA-Tradfri.service seems unable to call directly the tradfri.tac --> do I have to change Something in the IKEA-Tradfri.service file? BTW, does the User/group have to match the IKEA-Tradrfi.service folder or the /user/bin/local/twistd folder?
2: when i can call it using /usr/local/bin/twistd -n -y tradfri.tac, it can connect to the Gateway but the connection is lost because TCP port 1234 is closed. I've tried port forwarding but unsuccessfully
then when i type
pi@raspberrypi:~/domoticz/plugins/IKEA-Tradfri $ /usr/local/bin/twistd -n -y tradfri.tac2017-11-19 17:19:07.635 PluginSystem: Starting I/O service thread.
moroen
The first step is to get the adaptor and domoticz to work while running the adaptor from the command-line, and when you have successfully gotten the plugin to work from the command-line, try using systemd...Yossarian wrote: Sunday 19 November 2017 17:22 So,from what I understand (I don't know python at all ... and maybe I'm totally wrong), I've got 2 problems :
I notice a couple of things from your log:
1. 2017-11-19 17:19:07.688 (Ikea) Received: b'{"version": "0.4", "status": "Ok", "action": "clientConnect"}'
2. 2017-11-19 17:19:18.087 (Ikea) Received: b'{"error": "Connection timed out", "status": "Failed", "action": "setConfig"}'
1. indicates that domoticz is able to connect to the adapter, and
2. the adapter is unable to connect to the ikea-gateway (the second line), and is correctly returning this error to domoticz
And this line:
That shouldn't happen unless you close the adapter using ctrl-c?
Regards,
M
Yossarian
I do close the adapter using ctrl+C because nothing happens.should I wait longer?
How can I bring you more precision?
(BTW : thanks alot for your time and help)
So is the problem comming from my router? my Gateway ?2. the adapter is unable to connect to the ikea-gateway (the second line), and is correctly returning this error to domoticz
Yossarian
UPDATE :Finally got it!!!
I didn't have the right user/group set in the Ikea-tradfri.service. I tought it had to match /home/pi/domoticz/plugins/IKEA-Trafri folderbut it had to match the /lib/systemd/system/ folder
When nothing works, start again from the beginning...
I did the setup again and now it works. I guess I must have missed some sudo command ...
So I can switch on/off lights now only if i do :
Note that I have to sudo to make it works
Otherwise i get
When i close putty, nothing works anymore.
My ikea-tradfri.service status shows that it is running fine ans is in the lib/systemcl/system folder
Any suggestions?
pi@raspberrypi:~/domoticz/plugins/IKEA-Tradfri $ sudo python3 tradfri.tac Otherwise i get
pi@raspberrypi:~/domoticz/plugins/IKEA-Tradfri $ python3 tradfri.tac
File "tradfri.tac", line 14, in <module>
from pytradfri.api.libcoap_api import APIFactory
ImportError: cannot import name 'APIFactory'My ikea-tradfri.service status shows that it is running fine ans is in the lib/systemcl/system folder
Any suggestions?
moroen
It appears to be something slightly odd with your python installation. Modules installed with sudo pip3... should (as far as I know) be available to non-root users as well... The error when trying to run pytradfri.tac as a non-root user suggests that the pytradfri-module isn't available to a regular user?Yossarian wrote: Sunday 19 November 2017 22:52 UPDATE :Finally got it!!!
Note that I have to sudo to make it worksCode: Select all
pi@raspberrypi:~ $ cd /home/pi/domoticz/plugins/IKEA-Tradfri pi@raspberrypi:~/domoticz/plugins/IKEA-Tradfri $ sudo python3 tradfri.tac
Otherwise i getWhen i close putty, nothing works anymore.Code: Select all
pi@raspberrypi:~ $ cd /home/pi/domoticz/plugins/IKEA-Tradfri pi@raspberrypi:~/domoticz/plugins/IKEA-Tradfri $ python3 tradfri.tac Traceback (most recent call last): File "tradfri.tac", line 14, in <module> from pytradfri.api.libcoap_api import APIFactory ImportError: cannot import name 'APIFactory'
Any suggestions?
Anyway, as long as the adapter runs as root, the following ikea-tradfri.service file should work:
[Unit]
Description=IKEA Tradfri COAP-adapter
[Service]
Type=simple
Environment=IKEA_HOME=/opt/domoticz/plugins/IKEA-Tradfri
ExecStart=/usr/local/bin/twistd --nodaemon \
--rundir=${IKEA_HOME} \
--pidfile=${IKEA_HOME}/twistd.pid \
--python=${IKEA_HOME}/tradfri.tac
User=root
Group=root
Restart=always
[Install]
WantedBy=multi-user.target
Regards,
M
Yossarian
I did. Don't know what's wrong but in the end I can make it work.provided that you substitute IKEA_HOME for the real path to the plugin...
Anyway, thank you for your help and the great job you did with this plugin
Best regards
I've been trying to get the plugin to work, but I was having trouble with the PSK from the Pytradfri at first. I fixed this by manually adding the Gateway Identity and PSK on two places in "libcoap_api.py', but now I'm getting the following error when trying to use tradfri.tac:
Initializing gateway
Unhandled Error
File "/home/pi/.local/lib/python3.5/site-packages/twisted/python/log.py", line 103, in callWithLogger
return callWithContext({"system": lp}, func, *args, **kw)
File "/home/pi/.local/lib/python3.5/site-packages/twisted/python/log.py", line 86, in callWithContext
return context.call({ILogContext: newCtx}, func, *args, **kw)
File "/home/pi/.local/lib/python3.5/site-packages/twisted/python/context.py", line 122, in callWithContext
return self.currentContext().callWithContext(ctx, func, *args, **kw)
File "/home/pi/.local/lib/python3.5/site-packages/twisted/python/context.py", line 85, in callWithContext
return func(*args,**kw)
--- <exception caught here> ---
File "/home/pi/.local/lib/python3.5/site-packages/twisted/internet/posixbase.py", line 614, in _doReadOrWrite
why = selectable.doRead()
File "/home/pi/.local/lib/python3.5/site-packages/twisted/internet/tcp.py", line 205, in doRead
return self._dataReceived(data)
File "/home/pi/.local/lib/python3.5/site-packages/twisted/internet/tcp.py", line 211, in _dataReceived
rval = self.protocol.dataReceived(data)
File "tradfri.tac", line 76, in dataReceived
self.factory.initGateway(self, command)
File "tradfri.tac", line 275, in initGateway
self.devices = self.api(self.api(self.gateway.get_devices()))
File "/usr/local/lib/python3.5/dist-packages/pytradfri-4.0.3-py3.5.egg/pytradfri/api/libcoap_api.py", line 98, in request
File "/usr/local/lib/python3.5/dist-packages/pytradfri-4.0.3-py3.5.egg/pytradfri/api/libcoap_api.py", line 82, in _execute
Do you know how I could fix the problem?
Unhandled Error
moroen
If you have a PSK and identity from pytradfri that works, I would recommend to input them into the plugin. The default IDENT from pytradfri is pytradfri, combined with the PSK from the text file...Siopaos wrote: Wednesday 22 November 2017 0:12 Hello,
Regards,
M
I have added the PSK and identity in the plugin in domoticz as well as in the gateway_psk.txt file in the pytradfri folder, but it doesn't seem to work:moroen wrote: Wednesday 22 November 2017 9:04 If you have a PSK and identity from pytradfri that works, I would recommend to input them into the plugin. The default IDENT from pytradfri is pytradfri, combined with the PSK from the text file...
Regards,
M
IKEA-tradfri COAP-adaptor version 0.5 started (command line)!
Connected from IPv4Address(TCP, '127.0.0.1', 38238)
Data received: b'{"groups": "False", "action": "setConfig", "identity": "MYIDENTITYWASHERE", "pollinterval": "30", "psk": "MYPSKWASHERE", "observe": "False", "gateway": "192.168.1.34"}'
then the error as above
It still seems to be going wrong somehow..
moroen
just need to ask to be sure: You have reverted the changes you did in "libcoap_api.py'? What's your OS?Siopaos wrote: Wednesday 22 November 2017 9:23I have added the PSK and identity in the plugin in domoticz as well as in the gateway_psk.txt file in the pytradfri folder, but it doesn't seem to work:moroen wrote: Wednesday 22 November 2017 9:04 If you have a PSK and identity from pytradfri that works, I would recommend to input them into the plugin. The default IDENT from pytradfri is pytradfri, combined with the PSK from the text file...
Regards,
M
Regards,
M
dalecooper
moroen wrote: Monday 20 November 2017 19:30It appears to be something slightly odd with your python installation. Modules installed with sudo pip3... should (as far as I know) be available to non-root users as well... The error when trying to run pytradfri.tac as a non-root user suggests that the pytradfri-module isn't available to a regular user?Yossarian wrote: Sunday 19 November 2017 22:52 UPDATE :Finally got it!!!
Any suggestions?
Anyway, as long as the adapter runs as root, the following ikea-tradfri.service file should work:provided that you substitute IKEA_HOME for the real path to the plugin...Code: Select all
[Unit] Description=IKEA Tradfri COAP-adapter [Service] Type=simple Environment=IKEA_HOME=/opt/domoticz/plugins/IKEA-Tradfri ExecStart=/usr/local/bin/twistd --nodaemon \ --rundir=${IKEA_HOME} \ --pidfile=${IKEA_HOME}/twistd.pid \ --python=${IKEA_HOME}/tradfri.tac User=root Group=root Restart=always [Install] WantedBy=multi-user.target
Regards,
M
Fwiw, had the same problem.
Made the installation with sudo while logged in throught putty with pi user.
My plugins folder is /home/pi/domoticz/plugins/.
Had to edit user and group settings in the config file.
- bitjeverkeerd
I have this very cool (development version) of the ikea tradfri plugin working. Observe changes and add group as devices are both on. Debug is off.
I can switch the lights from Domoticz and I can see that the status of the lights changes when I switch them with the Tradfri remote.
My question is whether it is possible to see the status of the Tradfri remote in Domoticz. Then I could also switch other devices with this remote..
djac
How do you get the bulb connected to both GW and remote? When I try to connect the remote the bulb loose connection to the GW?bitjeverkeerd wrote: Monday 11 December 2017 16:32 I have this very cool (development version) of the ikea tradfri plugin working. Observe changes and add group as devices are both on. Debug is off.
Domoticz on Rpi, Z-wave, Hue with Philips and Ikea bulbs
moroen
Sorry for the late reply, I've been occupied elsewhere for a while. At the moment it's not possible to monitor the remotes directly. You could work around this by assigning a bulb to the remote, and then use event-scripts (python, lua or dzVents) for this bulb to trigger a scene or the other devices. Due to the way observations are done at the moment, there will be somewhat of a delay, but it should work.bitjeverkeerd wrote: Monday 11 December 2017 16:32 I have this very cool (development version) of the ikea tradfri plugin working. Observe changes and add group as devices are both on. Debug is off.
Regards,
M
- bitjeverkeerd
Thanks for the reply. For the time being I will use my old zwave switches to switch on the tradfri lighting. Maybe in the future I will completely switch to zigbee/ikea tradfri. Thanks for all the work you have put into this plugin. I keep testing.
JCred
I'm also trying to get the plugin to work on a raspberry pi running raspbian Jessie, but I am getting stuck at getting a PSK.
after I type in:
>$ coap-client -m post -u "client_identity" -k "MY-GATEWEY-KEY" -e '{"9090":"IKEA"}' "coaps://MY-IP:5684/15011/9063"
I get the following reponse:
> v:1 t:CON c:POST i:1135 {} [ ]
> Dec 25 14:52:13 ALRT 115 invalidate peer
> Dec 25 14:52:13 WARN received alert, peer has been invalidated
I have googled the ALRT 115 error, but could not find any leads. Can anyone help me get past this step?
after I type in:
moroen
It's a subtle fault in your command, Client_identity is with a capital C, so the correct line would be:JCred wrote: Monday 25 December 2017 15:20 I'm also trying to get the plugin to work on a raspberry pi running raspbian Jessie, but I am getting stuck at getting a PSK.
after I type in:
$ coap-client -m post -u "Client_identity" -k "MY-GATEWEY-KEY" -e '{"9090":"IKEA"}' "coaps://MY-IP:5684/15011/9063"
Regards,
M
