S_DIMMER not working after restart
Flopp
Post by Flopp »
I am using v3.8740
When using S_DIMMER I get a device with Type=Light/Switch and Subtype=AC. I add it to see I can see it under Switches.
Under Switch I edit the device to be a Dimmer(Switch Type)
I can change it and my Node can request the device number. I request for V_PERCENTAGE. In my Node I get a value between 0-660.
I can pull the "dot" and it change value in Domoticz I change TAB to eg. Dashboard and go back to Switches it still have the value that I change to.
But if I restart Domoticz after I have add the device it will always be the value it was when I restarted Domoticz. I can still pull the "dot" and value change but when I to other TAB and back to Switched it have the last value since restart.
Anyone have seen this?
