I’ve got the idea of augmenting dzEvents with a Finite State Machine to build a more intelligent HA system. The idea is that dzEvents would change either device timers or timer plans depending on the the current “state” and some event.
This is possible already but using a FSM would make life a lot easier. However, it all depends on being able to read and set timers and timer plans.
Looking at the Domoticz API documentation, it looks like you can read timers but I can’t see anything about setting them and there’s no mention of timer plans.
Gareth
Accessing and setting Timers or Timer Plans
garethhowell
- Domoticz version: 3.9317
garethhowell
Re: Accessing and setting Timers or Timer Plans
Any ideas on accessing and setting timers and plans from the API?
- DewGew
- Domoticz version: V4.10618
You can change timer plan in dzVents with a json call like this:
domoticz.openURL('http://127.0.0.1:8080/json.htm?type=command¶m=setactivetimerplan&ActiveTimerPlan=0')Raspberry Pi 3 | domoticz | Aeon Labs Z-Stick GEN5 | RFlink gateway
