Freemann
Domoticz version: >=Béta
Re: Domoticz app 2.0
Post by Freemann »
Were to put feature request?
Here or on Git?
For now I post it here;
Would be great if the Android App exposes the device battery level to Domoticz so it can be used in flows.
For example:
1. If device batterylevel is <=39% and user is @home; turn plug on to charge device
2. If device batterylevel is >70%; turn charging plug off
3. If dashboard tablet batterylevel <30%; alarm user for possible charging problem
The for 2 can be used to extends device its batterylive, also its a safety thing to switch the charge of at an certain batterylevel to prevent over charging/heat the device.
At the moment I'm using "Automate" to check the batterylevel and post the level to an Domoticz UserVariable. From there I can do some magic with it :)
Hope this could be implemented :)
Domotica/graphs "freak" :)
NUC8i3BEH(8gb/250gb),
Lubuntu 19.04,
Aeotec Z-Stick S2(Gen5)
HarmonyElite
HUE(5 bulbs, 2 blooms)
NetAtmo(complete setup)
MiLight iboxV6(2 MiLightBulbs)
IP-Cam
https://www.frijduurzaam.nl
deennoo
Post by deennoo »
9/11/2017 release
Geofence doesn't work any more, exept if i start another gps app & Domoticz.
The app doesn't lunch gps fonction i can't see small gps icône and notification on m'y screen, and or course switch associated to gps point aren't trigger.
Please come back to the previous solution who Works like à charme, as this à money feature, this need to work.
Of course app is allowed to use gps
Conf : Xiaomi mi6 / Android 7.1.1 / Domoticz app : 0.1.418
http://domo-attitude.fr
MarcelMAH
Domoticz version: v3.8025
Post by MarcelMAH »
My geofencing does work... the only thing I noticed it switches multiple times during the evening / night to ON when there was no OFF and I never left home...
I stopped using it for almost a year and reconfigured it when I saw that there was a specific update for the geofencing feature.
2017-11-10 08:19:59 Off <-- correct
2017-11-10 08:08:06 On
2017-11-10 04:37:53 On
2017-11-09 19:34:02 On
2017-11-09 17:50:34 On <-- correct
Running Domoticz on Ubuntu 16.04 on VMware with RFXCOM - RFXtrx433 and Aeotec Z-Stick Gen5
piokuc
Post by piokuc »
I found a bug. When i have turn off my RGBW by Zwave module all is ok. Swicth button is set center as other switch button. But when i turn ON it, he is moved in the left side... and is not set center as other. Look on screen.
deennoo
Post by deennoo »
deennoo wrote:9/11/2017 release
Still the same problème with 0.1.419(3641) version update yesterday
Envoyé de mon MI 6 en utilisant Tapatalk
galadril
Domoticz version: latest
Post by galadril »
Im using the Beta version of Google app, and google play services and looks like geofencing works a lot better.
to enroll the beta program for these two apps, you can follow these steps:
https://beebom.com/how-enable-google-as ... d-no-root/
ultratoto14
Post by ultratoto14 »
Hi Galadril,
I use a dedicated tablet on a wall with app widgets to control my home.
The 1x1 widget, on a tablet this could make a big button. And that's not a problem. My concern is more that on this large button only the icon in the center circle is reacting. Would it be possible to make the complete button sensible ?
U.
seblang
Post by seblang »
I am using Domoticz app on android and it's a very nice application.
But since a moment, I do not receive the alert sent by domoticz (Fire alert, open alert......)
It's a problem of app? a problem of Domoticz?
somebody can help me?
OttoBismark
Post by OttoBismark »
svenker wrote: Tuesday 24 October 2017 21:05 Hello,
THREE REQUESTS and ONE BUG for the developpers from a big user of Domoticz and Domoticz App 2.0 (paid)
I am using Domoticz for 2 years with more than 100 devices plugged on it (Z-Wave, RFCOMM, NFC...)
Hi Svenker,
a newbie here. One simple, silly, question for you: how can i have two columns on tablet instead of only one like the picture that you posted before? Is it possible to have on display some weather forecasts and a clock time?
Thank you.
bard4
Post by bard4 »
Hi guys.
I`m trying to use Domoticz Lite to connect via https to my server setup on raspberry pi. When i click on switches/temperature etc i get the debug message "Connection closed by peer". My setting IP address, username, password are correct. When I switch the protocol to http everything works fine.
Both ports (for http and https) are correctly set on my router (in port forwarding submenu).
What else can I do to get it working?
piokuc
Post by piokuc »
I use Domoticz APP beta on my Huawei P10 with Android 7.0
I use fingerprint to login to app Domoticz. But sometime when i open app and try login by fingerprint app not login and minimalize to rask manager. I must again open app and again login and works ok. Sometimes also works all ok from the first run. But sometime after second run.
In phone fingerprint to unlock phone works very very good with no problem. I write to Huawei and he tell me that it is a problem with Domoticz app.
Henrik
Post by Henrik »
paalkr wrote: Sunday 05 November 2017 0:19 In the Domoticz app I have to refresh the Android app manually.
Ideally updates should be pushed to the android app in close to real time, but an configurable auto refresh interval would be a good number two. Auto updating is especially important for android based always on control panels.
I need this too.
My plan is to have an Android tablet on the wall running the app, but the need to manually refresh is a show stopper.
serak
Domoticz version: 2024.7
Post by serak »
Exactly. Showing actual state of sensors should have a high priority in developing of this app. Especially for payed widgets make no sense to show old values.
Anyway, it's a good app, but thanks to this bug is unfortunately unusable for me and i think, for many others too.
cpighin
Domoticz version: 3.8153
Post by cpighin »
Ciao :)
I'm yet using Domoticz and few minutes ago I tryed the App for Android.
I installed the lite version into my A5 phone and I'm not able to start it: the application stops the connection procedure with advice "No route to host".
where have I mistaken?
I inserted same IP address used with my pc, port 8080!
Where can I found a Guide?
Claudio :)
Brutus
Post by Brutus »
Is there an option to Autofresh the dashboard? I have a Tablet at my wall and have the app running but after waking up the tablet for example after an hour its hasn't refreshed the devices. You need to refresh it manual (swipe down) to update all the devices.
1x Intel NUC8i5BEK (Windows 10 x64) Domoticz on Virtualbox with DietPi.
1x Aeon Labs USB Z-Stick S2
1x P1 Smart Meter USB
28x Fibaro Modules
SMA Solar System
Daikin Airco / Heating
Denon DHT-S716H & DSW-1H
cpighin
Post by cpighin »
Brutus,
unfortunately I do not think is a refresh issue, but a connection one.
Claudio :)
Brutus
Post by Brutus »
cpighin wrote: Sunday 28 January 2018 19:20 Brutus,
Claudio :)
Can you explain that? When is use the browser it works perfect.
When turning the tablet on the webpage refreshes instantly.
The app doesn't. It's even so that when you start the app and look at your devices for example energy use it will not refresh in 10 sec. So I don't think it's a connection problem.
28x Fibaro Modules
SMA Solar System
cpighin
Post by cpighin »
Brutus,
this is my problem, as reported above:
Claudio :)
cpighin
Post by cpighin »
Hallo,
maybe I understood the reason for the missing connection of the mobile A5 phone on which I installed the App for Android:
it may be the fact that I should first enable the MyDomoticz service, as reported here https://www.domoticz.com/wiki/MyDomoticz
Is it true?
Claudio :)
Bigted
Domoticz version: 2020.1
Post by Bigted »
Running version 0.1.430 (3714), when I try to add any scenes to the NFC tag, the scenes are listed, but when I select one, the app reports Connected switch N/A and doesn't switch the scene.
If I set it up to a single switch then it shows the switch correctly and switches correctly, am I missing something?
