Hi, I am wondering if it is possible to send a long switch command directly to domoticz via my Fibaro FGS 223 Relays.
I can add other switches to z wave association groups and switch them by holding the button, but the command does not reach domoticz it stays within the zwave network.
The function should be as follows. Short Press. Turn off the light. Long Press, turn off all lights and turn off the heating.
Send Long Press command to domoticz with z wave Switch
mosjonathan
Re: Send Long Press command to domoticz with z wave Switch
set parameter 28 and 29 in device config
