Use bluetooth audio on Raspberry PI
marigo
Re: Use bluetooth audio on Raspberry PI
Post by marigo »
If you use mplayer with the "-softvol" option then you can control the volume from the command line with "9" or "0".
I am searching for an option to control the volume within domoticz with a slider button like the dimmer option. Somehow you have to parse the keystroke "9" or "0" to the mplayer proces but at this moment I am searching on how to accomplish this.
Maybe anyone have some experience to get this working?
EDIT:
This is a Lua script with a "dimmer" to control volume, but I can change it only once:
if (devicechanged['TEST'] == 'Set Level') then
        v = math.floor(otherdevices_svalues['TEST'] - 20)
        os.execute("mplayer -ao alsa:device=bluetooth -af volume='" .. v .."' /mnt/music/top40/*.mp3")
        print("radio volume " .. v)
In the log I see that the script is running for more then 10 seconds which means a loop somewhere.
Can someone advise?
EDIT2:
I have found something to control the volume and play the next track with FIFO and this is working within Domoticz
https://pbrisbin.com/posts/controlling_mplayer/
I have made three "one-push-buttons" and three scripts
1- volume up
#!/bin/bash
sudo echo volume 1 > /root/.mplayer_fifo &
2- volume down
#!/bin/bash
sudo echo volume - > /root/.mplayer_fifo &
3 - next track
#!/bin/bash
sudo echo pausing_keep_force pt_step 1 > /root/.mplayer_fifo &
You need the following line to play your audio via your bluetooth adapter:
sudo mplayer -ao alsa:device=bluetooth -softvol -af volume=-20 /mnt/music/03-Albums/*.mp3 -shuffle &
fransiefrans
Domoticz version: stable
Post by fransiefrans »
In order to get the izSynth working, I had to connect my bluetooth speaker first.
Therefor I used the BTaudio Wiki but it looks like the bluez package changed.
I can't get it to connect with my speaker.
Is there someone who got it the work with the new bluez?
Skaven
Post by Skaven »
Hello, I'm wondering if somebody can explain to my how I setup this on my raspberry pi 3 white the integrated Bluetooth chip on raspberry pi 3 board, can I use the integrated Bluetooth chip? If yes can you explain how to setting it up?
pvm
Domoticz version: 4.10538
Post by pvm »
Skaven wrote:Hello, I'm wondering if somebody can explain to my how I setup this on my raspberry pi 3 white the integrated Bluetooth chip on raspberry pi 3 board, can I use the integrated Bluetooth chip? If yes can you explain how to setting it up?
When following the wiki., what output / errors do you get?
curious
Post by curious »
I am trying to follow this wiki on my Raspberry 2.
Unfortunately I am stuck .
At first I get a message after entering
sudo apt-get install bluetooth bluez bluez-utils bluez-alsa
Reading package lists... Done
Building dependency tree
Reading state information... Done
Package bluez-alsa is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
Package bluez-utils is not available, but is referred to by another package.
However the following packages replace it:
  bluez
E: Package 'bluez-utils' has no installation candidate
E: Package 'bluez-alsa' has no installation candidate
Should not be a problem, but after that there is no audio.conf nor is there a bluetooth-agent (command not found)
I use jessie-lite
My bluetooth device is recognized when entering lsusb
What to do
freijn
Domoticz version: Stable
Post by freijn »
Very interesting this one as well.. Will read..
tontze
Domoticz version: Beta Ch
Post by tontze »
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
DewGew
Domoticz version: V4.10618
Post by DewGew »
Is BTAudio out of date?
I tried to install bluetooth bluez bluez-utils bluez-alsa but i get this:
  bluez
Is there an other way for this?
ledfreak3d
Domoticz version: 3.8025
Post by ledfreak3d »
yep no longer works wiki needs to be update
bt audio works fine from the command line
but will never work for me when run from a lua script
cant find why.
not on a rpi3 or on a oppc+ board
Unleashe the magic smoke ;)
solo111
Post by solo111 »
ledfreak3d wrote: Monday 17 December 2018 20:14 yep no longer works wiki needs to be update
cant find why.
Good day! I join you .. I have the same trouble. My script does not start when I press the button. I read that this is due to the rights of the user. But I have a user in Domoticz by default. And what user do you have?
ledfreak3d
prety sure its not a user acount issue tried root and pi does not make any difference
AllesVanZelf
Domoticz version: 12467
Post by AllesVanZelf »
edit: 30 juli 2019 - see Thorgal789 post below and my post right after that.
I started with BT-audio from the wiki page also, but I soon have found out that this does not work anymore. I assume, because of some changes to the bluetooth packages. I’m certainly not an expert, but did get a little bit further.
I want to use this bluetooth speaker to make some alert sounds as feedback.
I used pulseaudio. I believe this is preferred audio system by newer distro’s.
sudo apt install pulseaudio pulseaudio-utils pulseaudio-module-bluetooth
sudo nano /etc/bluetooth/main.conf
(/etc/bluetooth/audio.conf is not used anymore)
add (or change if exist):
# This section contains general options
    [General]
    Enable=Source,Sink,Media,Socket
Change/add the following configuration in your /etc/pulse/system.pa config.
Sudo nano /etc/pulse/system.pa
# Modify: /etc/pulse/system.pa
### Automatically load driver modules for Bluetooth hardware
.ifexists module-bluetooth-policy.so
load-module module-bluetooth-policy
.endif
.ifexists module-bluez5-discover.so
load-module module-bluez5-discover
.endif
and in this same file change, or add the line:
load-module module-native-protocol-unix auth-anonymous=1 socket=/tmp/pulseaudio.socket
The /tmp/socket makes it possible to connect to pulseaudio with different users.
I added/changed the same lines in /etc/pulse/default.pa
In /etc/pulse/client.conf
change, or add the lines:
default-server = unix:/tmp/pulseaudio.socket
autospawn = no
I had to remove all files from: /home/pi/.config/pulse/ and /root/.config/pulse/ to make this work.
Especially the client.conf file in there.
In /etc/pulse/daemon.conf I changed/added the line:
 exit-idle-time = -1
 allow-module-loading = yes
 enable-memfd = yes
First stop pulse audio:
 pulseaudio -k
Next, Start pulseaudio at boot as service (or daemon? I’m not sure about the difference)
For this part I used this source: link )
 sudo nano /etc/systemd/system/pulseaudio.service
And change or add:
[Unit]
Description=PulseAudio system service
[Service]
Type=notify
ExecStart=/usr/bin/pulseaudio
Restart=on-failure
[Install]
WantedBy=multi-user.target
Now enable and start this unit file by running the following commands:
 sudo systemctl --system enable pulseaudio.service
sudo systemctl --system start pulseaudio.service
It should be running now. You can check the status of the service with the command:
 sudo systemctl --system status pulseaudio.service
I got an error about a cookie file. I will report how I solved this later.
Now add the user who needs access to pulseaudio to the pulse and pulse-access groups:
sudo usermod -aG pulse,pulse-access <username>
And I added root too.
sudo usermod -aG pulse,pulse-access root
change <username> with pi or your normal username.
Changes to groups are effective after you logout and log back in.
Bluetooth:
On ubuntu:
sudo add-apt-repository ppa:bluetooth/bluez
sudo apt update
sudo apt upgrade
sudo apt install bluez bluetooth
sudo service bluetooth restart
sudo /etc/init.d/bluetooth start
or try using the method donwloading from kernel.org as described here: link
I'm using version 5.49
bluetoothctl -v
5.49
I also installed Bluealsa. But now I'm not sure if this is nescesary.
source
sudo apt install bluealsa
Type:
sudo bluetoothctl
then press enter and input the administrator password.
Next, enter
[Bluetooth] agent on
and press enter. Then type
[Bluetooth] default-agent
and press enter. Type
[Bluetooth] scan on
and press enter one more time. The unique addresses of all the Bluetooth devices around will appear and look something like an alphanumeric XX:XX:XX:XX:XX:XX. If you make the device you want to pair discoverable (or put it into pairing mode), the device nickname may appear to the right of the address. If not, you will have to do a little trial and error or waiting to find the correct device.
To pair the device, type
[Bluetooth] pair XX:XX:XX:XX:XX:XX
XX:XX:XX:XX:XX:XX is the device bluetooth address. Change it with the address of your speaker (for example)
Connect to the device, type
 connect XX:XX:XX:XX:XX:XX
Then:
 trust XX:XX:XX:XX:XX:XX
type 'exit' to leave bluetoothctl.
In order to pair up with Bluetooth devices, you need to add, or change the following text to the file /etc/dbus-1/system.d/pulse.conf:
 sudo nano /etc/dbus-1/system.d/pulseaudio-system.conf
Check if this file exist. In my case there where two files. One pulse.conf en this one. I merged them to pulseaudio-system.conf.
<!DOCTYPE busconfig PUBLIC
 "-//freedesktop//DTD D-BUS Bus Configuration 1.0//EN"
 "http://www.freedesktop.org/standards/dbus/1.0/busconfig.dtd">
<busconfig>
        <policy user="root">
                <allow own="org.pulseaudio.Server"/>
                <allow send_destination="org.bluez"/>
                <allow send_interface="org.bluez.Manager"/>
        </policy>
        <policy user="pulse">
        </policy>
        <policy context="default">
                <deny own="org.pulseaudio.Server"/>
                <deny send_destination="org.bluez"/>
                <deny send_interface="org.bluez.Manager"/>
        </policy>
</busconfig>
According to this same source I changed/added in the file:
/etc/dbus-1/system.d/bluetooth.conf
    <allow send_interface="org.bluez.ThermometerWatcher1"/>
    <allow send_interface="org.bluez.HeartRateWatcher1"/>
    <allow send_interface="org.bluez.CyclingSpeedWatcher1"/>
 <!-- allow users of bluetooth group to communicate -->
  <policy group="bluetooth">
  </policy>
It’s easiest to reboot the system now.
sudo shutdown -r now
After this reboot, find out the name to use for the bluetooth device to make some noise.
sudo pacmd list-sinks
(I still cannot get info without sudo. That I do not understand)
find the: bluez_sink.XX_XX_XX_XX_XX_XX.a2dp_sink” part. We will need this addres.
I use paplay like this:
paplay -p --device=bluez_sink.XX_XX_XX_XX_XX_XX.a2dp_sink --volume=65536 /home/pi/sounds/dingdong-1.wav
volume 65536 is volume set to 100%. So be careful. You could set it in a range of 0 – 65536. paplay does not play mp3’s. Mplayer can.
Another method I use is by using mplayer, like this:
mplayer -ao pulse::bluez_sink.XX_XX_XX_XX_XX_XX.a2dp_sink /home/pi/1.mp3 -softvol -volume 25
This is working well for me, but just for a while. After some time my bluetooth speaker disconnects. After that I had some trouble reconnecting.
In the next post I solved this.
Edit: some corrections
edit: 29 juli 2019 - made some changes
Last edited by AllesVanZelf on Tuesday 30 July 2019 21:15, edited 8 times in total.
AllesVanZelf
Keep Bluetooth connection alive
I did some more research and might found a way to keep bluetooth connection to the bluetoth speaker open.
But not sure yet if this will be the solution on the long run.
All feedback is more then welcome!
source 1
source 2
Make a script to reconnect the Bluetooth device:
 sudo nano /home/pi/bin/autoconnect-bluetooth-device.sh
with content:
#!/bin/bash
bluetoothctl << EOF
EOF
 chmod +x /home/pi/bin/autoconnect-bluetooth-device.sh
I save my own scripts in this /home/pi/bin directory.
The next script will check if the connection is still alive, and when not – start the last script.
 sudo nano /home/pi/bin/connect-bt-devs.sh
#!/bin/bash
address="XX:XX:XX:XX:XX:XX"
while (sleep 1)
do
  connected=$(hcitool con) > /dev/null
  if [[ ! $connected =~ .*${address}.* ]] ; then
  fi
done
chmod +x /home/pi/bin/connect-bt-devs.sh
The next step creating a service to keep checking.
sudo nano /etc/systemd/system/connectbtspeaker.service
with content:
[Unit]
Description=keep connection Bluetooth speaker alive
Documentation=https://www.domoticz.com/
[Service]
# Ubuntu/Debian convention:
Type=simple
ExecStart=/home/pi/bin/connect-bt-devs.sh
[Install]
Before the last step, make sure the device/speaker is paired and connected. Then enable the service:
 sudo systemctl enable connectbtspeaker.service
sudo systemctl start connectbtspeaker.service
sudo systemctl status connectbtspeaker.service
sudo systemctl stop connectbtspeaker.service
I’m not yet sure if the next command is nescesary.
sudo systemctl preset connectbtspeaker.service
preset to set the service to be auto-started at boot, if the local policy permits it.
Connecting was not enough. The speaker go to sleep. for this I found another solution.
Update:
I found out from here: source, that it is possible to keep the bluetooth connection alive with a hcitool spinq command.
Now put this simple script into /etc/init.d/
sudo nano /etc/init.d/bluetooth-alive
#! /bin/sh
hcitool spinq
exit 0
Then execute these.
sudo chmod +x /etc/init.d/bluetooth-alive
sudo service bluetooth-alive enable
sudo update-rc.d bluetooth-alive defaults
sudo service bluetooth-alive start
Edit (29-7-2019):
If I do something silly or stupid, please tell me!! :) But the speaker is up and running for a few month now.
Last edited by AllesVanZelf on Monday 29 July 2019 11:53, edited 2 times in total.
Thorgal789
Post by Thorgal789 »
I m sorry, I can't test it now, I have uninstalled my alexa application for the moment (and I had similar problem too, and I haven't tested so much complicated script), but be sure it will be usefull on my side ^^.
Thx for all.
AllesVanZelf
I have edited the above post a little, because I had some new findings.
I also have found out that I have to (re)start bluetooth after pulseaudio. else it will not work here.
sudo service pulseaudio restart
AllesVanZelf
hmmm still no stable connection. Anyone could review my settings?
Thorgal789
Nothing to see with your method, but on my side I m using Bluealsa.
My speaker is connected 24/24, I can say if the connection is stable during a week, because I move it a lot for test ATM. But I m just using this command to send sound.
For Wav, realy stable
aplay -D bluealsa:HCI=hci0,DEV=11:75:58:E4:71:30,PROFILE=a2dp sound.wav
for mp3, instable
mpg123 -a bluealsa:HCI=hci0,DEV=11:75:58:E4:71:30,PROFILE=a2dp sound.mp3
I already have some problem with pulseaudio.
AllesVanZelf
Hello Thorgal789,
I'm very interested in this. Could you tell me what your configuration files are?
Thorgal789
All by defaut ^^.
Sound use rapsberry speaker by defaut like a defaut configuration.
The speaker configuration is on the command line and by-pass the defaut configuration, I think there a way a set it by defaut, but I had lot of problem with sound core and I don't want to broke it again so I m using this solution.
sudo apt-get install bluealsa
Take care, perhaps conflicts with pulseaudio., don't remember all the requierement.
pi@raspberrypi: $ amixer -D bluealsa
Simple mixer control 'TimeBox-mini-audio - A2DP',0
  Capabilities: pvolume pswitch
  Playback channels: Front Left - Front Right
  Limits: Playback 0 - 127
  Mono:
  Front Left: Playback 127 [100%] [on]
  Front Right: Playback 127 [100%] [on]
I just use bluetoothctl to pair the speaker (and configure bluetooth connexion), not sure using the raspberry GUI is working all the time.
pi@raspberrypi:/var/run/bluealsa $ bluetoothctl
[NEW] Controller B8:27:EB:C3:32:96 raspberrypi [default]
[NEW] Device 11:75:58:E4:71:30 TimeBox-mini-audio
[TimeBox-mini-audio]# info 11:75:58:E4:71:30
        Alias: TimeBox-mini-audio
        Class: 0x240404
        Icon: audio-card
        Paired: yes
        Trusted: yes
        Blocked: no
        Connected: yes
AllesVanZelf
Earlier I ran into trouble with Alsa and bluetooth and bluez-alsa. I did know that bluealsa is in repository now. Maybe it was there all the time ;)
I removed pulseaudo:
 sudo apt purge pulseaudio pulseaudio-module-bluetooth
(first made some backups of configuration files).
created a file /etc/asound.conf
sudo nano /etc/asound.conf
with content:
defaults.bluealsa.service "org.bluealsa"
defaults.bluealsa.device "5D:57:C3:CB:0D:B3"
defaults.bluealsa.profile "a2dp"
defaults.bluealsa.delay 3000
And now I cam play files as:
 aplay -D bluealsa /home/pi/soundfiles/3.wav
It survived a first reboot.
Thank you very much Thorgal789 for pointing this out to me!!
Esit: The last smiley is a: - D
