#2215 Custom Icons uploader Implemented
aDAMrus
Re: #2215 Custom Icons uploader Implemented
Post by aDAMrus »
I trying to upload custom icons. I can choose and save new icon in sensor edit menu, but in floorplan this sensor looks like domoticz logo. Same situation with standart icon set if I use "custom sensor" - in floorplan they all are "domoticz logo". Whats wrong I do?
Thank
___
V3.8394 (on prev. beta same)
RPi2
wm62
Domoticz version: 4.97
Post by wm62 »
Look here
viewtopic.php?f=6&t=14435&hilit=floorplan+custom+icons
wm62
Post by wm62 »
@Domoticz Team
Still not possible to 'customize' sensors and smoke detectors ????
aDAMrus
Post by aDAMrus »
wm62 wrote: Sunday 05 November 2017 13:53 Look here
Its helped. Thank you!
htilburgs
Post by htilburgs »
Yeelight Smart Light Strip
YeeLED.zip
(7.62 KiB) Downloaded 303 times
Hardware:
febalci
Post by febalci »
Logitech Harmony Touch
domoticz_HarmonyTouch.zip
(7.38 KiB) Downloaded 345 times
febalci
Post by febalci »
Philips Hue Go:
domoticz_HueGo.zip
(9.88 KiB) Downloaded 308 times
febalci
Post by febalci »
Philips Hue
domoticz_HueBulb.zip
(6.78 KiB) Downloaded 338 times
htilburgs
Post by htilburgs »
Nest Thermostaat
Nest Thermostaat48_On.png (4.66 KiB) Viewed 9941 times
Nest Thermostaat48_Off.png (3.95 KiB) Viewed 9941 times
Nest Thermostaat.zip
(11.22 KiB) Downloaded 398 times
Hardware:
mraichura
Domoticz version: 3.8153
Post by mraichura »
Here is a toggle icon set based on Font Awesome font icons
domoticz_custom_icon_Toggle Switch.zip
(2.34 KiB) Downloaded 360 times
1 x RASPBERRY PI 1 MODEL B+ running Domoticz since June 2016
1 x RASPBERRY PI 3 MODEL B running Domtoicz since August 2017
Charley
Domoticz version: V3.9030
Post by Charley »
I have made two icon sets
One for Audio
and One for Bose Soundtouch
Audio.zip
(9.07 KiB) Downloaded 357 times
Bose.zip
(7.7 KiB) Downloaded 285 times
HM31
Post by HM31 »
custom icon for Sengled Pulse Bluetooth speaker/light bulb
Sengled-Pulse.zip
(5.79 KiB) Downloaded 270 times
HM31
Post by HM31 »
Zipato Mini-Keypad
Zipato Min-Keypad.zip
(9.04 KiB) Downloaded 285 times
HM31
Post by HM31 »
Zooz Zen06 plug with USB ports
ZoozZen06.zip
(5.65 KiB) Downloaded 271 times
remb0
Post by remb0 »
thanks HM31!!
LiPeR
Post by LiPeR »
3D Printer Switch
3dPrinter.zip
(5.32 KiB) Downloaded 323 times
schumi2004
Domoticz version: 4.10603
Post by schumi2004 »
htilburgs wrote: Wednesday 21 June 2017 14:46 Yeelight Color LED Bulb Icons
Thanks for the icons but for some reason i only see them on floorplan and not in dashboard or switches overview.
Is this a known issue?
FireWizard
Post by FireWizard »
Hi All,
For switches you have the option to select Custom Icons, if you have uploaded these to Domoticz.
You will see them both in the "Switches Tab" and on the Floor plan.
If you define a Custom Sensor and use a Custom Icon you will see these in the "Utility Tab", but on the Floor plan you will see the Domoticz Logo.
This question has raised before, approx. 2 years ago and it seemed that there was a solution. However I do not see the solution.
Or is this functionality still not implemented for other sensors except switches?
Last edited by FireWizard on Tuesday 17 September 2019 23:03, edited 1 time in total.
RduPre
Post by RduPre »
I tried to upload custom icons on several Domoticz systems, running latest beta, but they all fail
The error is (in Dutch) "Probleem met uploaden van de pictogrammen: undefined"
I used this before, many months ago and at that time it worked.
There is no error in the logs..
Misiek
Post by Misiek »
Two more icons - led halogen and xiaomi air purifier.
purifier.zip
(7.72 KiB) Downloaded 250 times
halogen.zip
(12.28 KiB) Downloaded 245 times
