Python Plugin Beta testers - please read this
- Dnpwwo
Re: Python Plugin Beta testers - please read this
There are already a number of threads on this.
The plugin system is not 'dead' but is not enabled in the current betas anymore which is a defect. Once we work out why it that has happened it will be back and essentially the same as before.
superczar
oh
In that case, is there any interim method to revert to a version that has the plugin system enabled?
Neither the current beta or stable seem to have it enabled
elgringo
- Domoticz version: Left
If you want the latest beta, which uses the new plugin system (which is preferred since the old one will be deprecated)superczar wrote:oh
You can build it locally on your Pi form source code, See: http://www.domoticz.com/wiki/Installing ... spberry_PI
After this the python plugin system will work again.
superczar
Err - Probably a silly question but Wouldn't that be the same as the current ARM beta release (3.7680)?
elgringo
no but current beta works again
@Dnpwwo
Besides the changes described in this topic, are there any other (major) changes planned for Python?
@Dnpwwo
superczar
Thanks @elgringo
building the binary from source did activate the plugin system although the plugin I had failed to work because of the call method change
However I was able to use an older commit to build a binary for v 3.5876 to get the plugin back up
- Dnpwwo
I believe Python is now enabled in the ARM beta builds again.
- Phantom
- Domoticz version: 4.11652
It is working again yes, thank you.Dnpwwo wrote:I believe Python is now enabled in the ARM beta builds again.
miljume
- Domoticz version: v3.8742
Despite that the plugin engine should be enabled again I can't get it running on my RPI3
I have followed the tutorial and upgraded Python 3 but no indication in the log that the engine has started (and no errors as well)
What can I do to investigate what is behind?
Running 3.8651
Running 3.8651
- Dnpwwo
@miljume,
Can you please post the log of Domoticz starting so we can see what is going on.
miljume
@Dnpwwo Sure, here it is
After this the sensor values are dropping into the log
2017-10-31 17:30:29.387 Domoticz V3.8651 (c)2012-2017 GizMoCuz
2017-10-31 17:30:29.387 Build Hash: 57f09fb3, Date: 2017-10-29 06:51:33
2017-10-31 17:30:29.387 Startup Path: /home/pi/domoticz/
2017-10-31 17:30:29.475 Sunrise: 07:47:00 SunSet:15:37:00
2017-10-31 17:30:29.475 EventSystem: reset all events...
2017-10-31 17:30:29.499 Active notification Subsystems: (0/13)
2017-10-31 17:30:29.501 WebServer(HTTP) started on address: :: with port 8081
2017-10-31 17:30:29.511 WebServer(SSL) started on address: :: with port 443
2017-10-31 17:30:29.514 Proxymanager started.
2017-10-31 17:30:29.573 Starting shared server on: :::6144
2017-10-31 17:30:29.574 TCPServer: shared server started...
2017-10-31 17:30:29.574 RxQueue: queue worker started...
2017-10-31 17:30:32.577 MySensors: trying to connect to: 127.0.0.1:5003
2017-10-31 17:30:32.577 MQTT: Connecting to 127.0.0.1:1883
2017-10-31 17:30:32.581 RFXCOM: Using serial port: /dev/ttyUSB0
2017-10-31 17:30:32.678 MQTT: connected to: 127.0.0.1:1883
2017-10-31 17:30:32.779 MQTT: Subscribed
2017-10-31 17:30:33.156
2017-10-31 17:30:33.232 subtype = Interface Response
Sequence nbr = 2
response on cmnd = Get Status
Transceiver type = 433.92MHz
Firmware version = 1001
Firmware type = Ext
Hardware version = 1.3
Undec off
X10 enabled
ARC enabled
AC enabled
HomeEasy EU disabled
Meiantech/Atlantic disabled
Oregon Scientific enabled
ATI/Cartelectronic disabled
Visonic disabled
Mertik disabled
AD disabled
Hideki disabled
La Crosse disabled
FS20/Legrand disabled
ProGuard disabled
BlindsT0 disabled
BlindsT1 disabled
AE disabled
RUBiCSON enabled
FineOffset enabled
Lighting4 disabled
Conrad RSL disabled
ByronSX disabled
IMAGINTRONIX disabled
KEELOQ disabled
Home Confort disabled
2017-10-31 17:30:33.577 MySensors: connected to: 127.0.0.1:5003
2017-10-31 17:30:33.578 MySensors: Gateway Ready...
2017-10-31 17:30:33.602 Incoming connection from: <my ip>
2017-10-31 17:30:34.578 MySensors: Gateway Version: 2.2.0-beta
2017-10-31 17:30:34.578 MySensors: Gateway Version: 2.2.0-beta- Dnpwwo
@miljume,
Only two things could cause this that I can think of:
- You have turned the EventSystem off in the Settings page. Strangely this disables the Plugin System as well which I've never quite understood the logic of but it is what it is
- (more likely) You are building from source and Python is not enabled. From memory you should see something like USE_PYTHON=YES when you issue a command. You might want to force a clean build as well.
cmake -DCMAKE_BUILD_TYPE=Release .
miljume
@Dnpwwo,
Thank's for the hint, I did not had EventSystem turned on in settings so I turned it on
But now Domoticz won't start the GUI, in syslog the following is seen after I have started the Domoticz service:
If I run
I get the following:
Now I can't change setting back and have no clue how to fix the problem, any hints?
Nov 1 13:30:34 raspberrypi systemd[1]: Starting LSB: Home Automation System...
Nov 1 13:30:34 raspberrypi domoticz.sh[2749]: 2017-11-01 13:30:34.130 Domoticz V3.8651 (c)2012-2017 GizMoCuz
Nov 1 13:30:34 raspberrypi domoticz: Domoticz is starting up....
Nov 1 13:30:34 raspberrypi domoticz.sh[2749]: 2017-11-01 13:30:34.130 Build Hash: 57f09fb3, Date: 2017-10-29 06:51:33
Nov 1 13:30:34 raspberrypi domoticz.sh[2749]: 2017-11-01 13:30:34.131 Startup Path: /home/pi/domoticz/
Nov 1 13:30:34 raspberrypi domoticz.sh[2749]: domoticz: Domoticz is starting up....
Nov 1 13:30:34 raspberrypi domoticz: Domoticz running...
Nov 1 13:30:34 raspberrypi systemd[1]: Started LSB: Home Automation System.
sudo /etc/init.d/domoticz.sh statusCode: Select all
Loaded: loaded (/etc/init.d/domoticz.sh)
Active: active (exited) since Wed 2017-11-01 13:30:34 CET; 1min 29s ago
Process: 2070 ExecStop=/etc/init.d/domoticz.sh stop (code=exited, status=0/SUCCESS)
Process: 2749 ExecStart=/etc/init.d/domoticz.sh start (code=exited, status=0/SUCCESS)
Nov 01 13:30:34 raspberrypi domoticz.sh[2749]: 2017-11-01 13:30:34.130 Domotic...zNov 01 13:30:34 raspberrypi domoticz[2754]: Domoticz is starting up....
Nov 01 13:30:34 raspberrypi domoticz.sh[2749]: 2017-11-01 13:30:34.130 Build H...3Nov 01 13:30:34 raspberrypi domoticz.sh[2749]: 2017-11-01 13:30:34.131 Startup.../Nov 01 13:30:34 raspberrypi domoticz.sh[2749]: domoticz: Domoticz is starting u....Nov 01 13:30:34 raspberrypi domoticz[2755]: Domoticz running...
Nov 01 13:30:34 raspberrypi systemd[1]: Started LSB: Home Automation System.
Hint: Some lines were ellipsized, use -l to show in full.
miljume
When starting domoticz manually, I receive the following
root@raspberrypi:/home/pi# cd domoticz
root@raspberrypi:/home/pi/domoticz# ./domoticz
2017-11-01 18:40:46.634 Domoticz V3.8666 (c)2012-2017 GizMoCuz
2017-11-01 18:40:46.634 Build Hash: c95228b5, Date: 2017-10-31 13:45:30
2017-11-01 18:40:46.635 Startup Path: /home/pi/domoticz/
2017-11-01 18:40:46.685 Sunrise: 07:50:00 SunSet:15:33:00
2017-11-01 18:40:46.686 EventSystem: reset all events...
Segmentation fault- Dnpwwo
@miljume,
I'm surprised that there are no messages from either the Python Framework finding (or not finding) Python because that is normally the 1st thing it does.
Two things spring to mind:
- Can you remove and directories you have in the domoticz/plugins directory other than 'examples'
- Have a look under /domoticz/scripts for a .py file called something like Smarter_PIR.py and delete it if you find it
miljume
I have removed the directory called "AwoxSMP" so that only the examples folder is in the plugin directory. Can't find any file named Smarter _PIR or similar
But after reboot I still get:
I have tried removing domoticz entirely and reinstalling it several times but no change. Other things like Node RED is running fine so I think the SD card should not be corrupt. The problem is that the Pi is 4 hours drive away so I really would like to reinstall domoticz and get in running without having to reach the Pi physically ...
Anything else I can try?
2017-11-02 09:46:48.485 Domoticz V3.8688 (c)2012-2017 GizMoCuz
2017-11-02 09:46:48.485 Build Hash: bc0a53d5-modified, Date: 2017-11-01 21:52:08
2017-11-02 09:46:48.485 Startup Path: /home/pi/domoticz/
Segmentation fault
zak45
- Domoticz version: V2024.4
Have seen some others have segmentation fault....
Maybe you can try by installing the last stable version.
miljume
I have tried deleting domoticz folder and the symlinks I know about and installed a fresh copy (stable) with
But still same Segmentation fault
sudo curl -L install.domoticz.com | sudo bash-
ben92
hello, i upgrade my server from ubuntu 17.04 to 17.10 and i have segfault at startup.
if in CMakeList.txt, i remove the line " add_definitions(-DENABLE_PYTHON)" and compil domoticz, i can start domoticz ant it works !!
Python 3.7 is found with cmake -DCMAKE_BUILD_TYPE=Release .
can you help me ?
can you help me ?
dextm80
- Domoticz version: 4.10159
hi, i've melclouid python plugin installed, but since a few days this is error log:gysmo38 wrote: Sunday 12 March 2017 23:47 Thank a lot for creating Python plugin. It is perfect for me.
I create a first version of MELCloud plugin.
I create a Wiki page for instructions http://www.domoticz.com/wiki/Plugins/MELCloud.html
It is not finish but it work well.
any idea @gysmo38?2018-01-22 19:54:09.129 Error: (Mitsubishi Kirigamine) 'onHeartbeat' failed 'KeyError'.
2018-01-22 19:54:09.129 Error: (Mitsubishi Kirigamine) ----> Line 520 in /home/luigi/domoticz/plugins/Melcloud/plugin.py, function onHeartbeat
2018-01-22 19:54:09.129 Error: (Mitsubishi Kirigamine) ----> Line 227 in /home/luigi/domoticz/plugins/Melcloud/plugin.py, function onHeartbeat
Domoticz on AsRock j3455-ITX 8gb ram - Aeotec ZWave Usb Stick - RFLink 433Mhz
1x Fibaro Wall Plug
1x Fibaro Motion Sensor
x NeoCoolcam Wall Plug
Netatmo Weather Station - Netatmo Thermostat
Philips Hue Bridge
1x Fibaro Wall Plug
Philips Hue Bridge
